12-30-2020, 16:08 | #1 (permalink) |
Insane Poster Join Date: Sep 2018 Location: India
Member: 2868909 Status: Offline Thanks Meter: 36 | "Can't init device, Reason: OCR Ready Timeout Error [Check VCC or eMMC DEAD]". I am facing an issue in connecting almost every samsung device via isp, tried on 5_6 samsung devices , but always get the same error "Can't init device, Reason: OCR Ready Timeout Error [Check VCC or eMMC DEAD]". Cross checked isp connection , tried hi power and without cable but always same issue . Is there any solution to this issue , should i try connecting 100 ohm resistance to data and 1.8v lines , will it affect my jtag plus box or is there any other solution for this problem. Any kinda guidance is highly appreciated , please do help i have 5_6 samsung devices with same issue. TY |
01-02-2021, 17:35 | #3 (permalink) | |
Member: 2868909 Status: Offline Thanks Meter: 36 | Quote: Anyways thanks again for your support master :-) | |
01-03-2021, 12:17 | #4 (permalink) |
Product Supporter Join Date: Jun 2002 Location: Belarus Age: 47
Member: 13148 Status: Offline Thanks Meter: 2,948 | it is very difficult to guarantee that the ISP connection will work on any device The problem is that if the device is turned off, the power supplied to the eMMC also starts other chips of the device, and they can interfere with the signals going to the eMMC. In the case of the HiPower CLK mode, the box also interferes with the fully functioning processor-memory bus. To do this, you need to check the "HiPower CLK mode" checkbox in the software, which increases the signal power of the CLK, so that data synchronization between the box and the eMMC is possible. Unfortunately, many users connecting a device powered by USB do not tick this box and write dozens of messages that nothing works for them. Not to mention the fact that they use long wires of different length and not use told GND wire. People do not understand the physics of the processes occurring in the wires, and at the same time do not fulfill the requirements for ISP connecting. That's why there are constant the same questions on the forum, why the ISP connection is not working |
The Following User Says Thank You to layder For This Useful Post: |
