Can't init EMMC, Reason: DATA RCV Timeout Error 1 Attachment(s) this error comes when i work with Samsung mobiles other brand oppo vivo mi working good please tell me some solution Z3X EasyJtag Software ver. 3.7.0.20 Loading eMMC GEN2 Firmware... IO: 1800 mV Box S/N: 8C30F9F3F3B1121F, ,FW Ver.: 02.53 CMD Pullup Level:1804 mV CMD Active Level:1826 mV Box IO Level:1800 mV CLK Rate:12000 kHz Bus Width:1bit,SDR HiPower mode is off! ---------- eMMC Device Information ---------- eMMC CID : 15010051333133424200B5FBB8842497 eMMC CSD : D02701320F5903FFF6DBFFEF8E40400D eMMC Manufacturer ID: 0015 , OEM ID: 0100 eMMC Date: 02/2017 Rev.0x0 eMMC NAME: Q313BB , S/N: 3053172868 eMMC NAME (HEX): 513331334242 Can't init EMMC, Reason: DATA RCV Timeout Error Check Data Line! Done. Can't init device, Reason: Initialization failed Done. Z3X EasyJtag Software ver. 3.7.0.20 Loading eMMC GEN2 Firmware... IO: 2800 mV Box S/N: 8C30F9F3F3B1121F, ,FW Ver.: 02.53 CMD Pullup Level:1818 mV CMD Active Level:2119 mV Box IO Level:2800 mV CLK Rate:12000 kHz Bus Width:1bit,SDR HiPower mode is off! Can't init device, Reason: CMD Timeout Error Done. Thank You |
Try to use pull-up resistors |
all connection is ok i have attached two 100 Oms pull-up resistors 1.8v to cmd and data this error comes when i work with Samsung |
Try connect witout vcc and vccq connection, select hipower mode and connect usb power cable to phone |
If ISP not work correctly - desolder chips and use sockets https://forum.gsmhosting.com/vbb/f67.../#post14298347 |
