06-05-2017, 04:29 | #5 (permalink) |
No Life Poster Join Date: Oct 2007 Location: chennai Age: 38
Member: 616909 Status: Offline Sonork: 1672125 Thanks Meter: 648 | i have detected well but no solution in z3x section other prodect have solution Code: Coolpad 8297L-I00 dead EasyJtag Suite Classic ver.: 2.5.0.9 / wxWidgets 3.1.0-W-U started. OS ver.: Windows 7 (build 7601, Service Pack 1). Admin rights OK undefined Android Explorer ver.: 1.0.0.23 eMMC ODIN ver.: 1.0.11.2 Successfully connected to box on COM12 Box S/N: 010070222EE63D88, ,FW Ver.: 01.58 Box Working Mode: JTAG Box. Box Drivers version: 3.0.1.0, are OK Z3X Card Serial : AA1A-28FD , ver: 22 Z3X Card Activation [LG] : NOT ACTIVATED Z3X Card Activation [SAMS] : NOT ACTIVATED Z3X Card Activation [JTAG] : ACTIVATED Z3X EasyJtag Software ver. 2.5.0.9 Loading eMMC Addon Firmware... IO: 2800 mV Box S/N: 010070222EE63D88, ,FW Ver.: 01.58 CMD Pullup Level:2227 mV CMD Active Level:2423 mV Box IO Level:2800 mV CLK Rate:21000 khz HiPower mode is off! ---------- eMMC Device Information ---------- EMMC CID : 90014A4838473165050752C5DCCD525E EMMC CSD : D02701320F5903FFFFFFFFEF8A4040D2 EMMC Manufacturer ID: 0090 , OEM ID: 014A EMMC Date: 05/2015 Rev.0x7 EMMC NAME: H8G1e , S/N: 1388698829 EMMC NAME (HEX): 48384731652000 EMMC ROM1 (Main User Data) Capacity: 7456 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.7 (MMC 5.0) Boot configuration [PARTITION_CONFIG: 0x38] Boot from:ROM1 (Main User Area) Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x38. H/W reset function [RST_N_FUNCTION]: 0x00 High-capacity W protect group size [HC_WP_GRP_SIZE: 0x00000000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: H8G1e _1388698829_20170530_1238.extcsd ============================================= Extended CSD rev 1.7 (MMC 5.0) ============================================= Card Supported Command sets [S_CMD_SET: 0x01] HPI Features [HPI_FEATURE: 0x01]: implementation based on CMD13 Background operations support [BKOPS_SUPPORT: 0x01] Max Packet Read Cmd [MAX_PACKED_READS: 0x3f] Max Packet Write Cmd [MAX_PACKED_WRITES: 0x3f] Data TAG support [DATA_TAG_SUPPORT: 0x01] Data TAG Unit Size [TAG_UNIT_SIZE: 0x00] Tag Resources Size [TAG_RES_SIZE: 0x00] Context Management Capabilities [CONTEXT_CAPABILITIES: 0x78] Large Unit Size [LARGE_UNIT_SIZE_M1: 0x01] Extended partition attribute support [EXT_SUPPORT: 0x03] Generic CMD6 Timer [GENERIC_CMD6_TIME: 0x05] Power off notification [POWER_OFF_LONG_TIME: 0x64] Cache Size [CACHE_SIZE] is 1024 KiB ------------------------- eMMC v5+ ------------------------- Supported modes [SUPPORTED_MODES: 0x01] FFU features [FFU_FEATURES: 0x00] Operation codes timeout [OPERATION_CODE_TIMEOUT: 0x17] FFU Argument [FFU_ARG: 0x00006600] Number of FW sectors correctly programmed[NUM_OF_FW_SECT_CORR_PROG: 0] Vendor proprietary health report: [VENDOR_PROPRIETARY_HEALTH_REPORT[301]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[300]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[299]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[298]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[297]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[296]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[295]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[294]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[293]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[292]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[291]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[290]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[289]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[288]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[287]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[286]]:0xb0 [VENDOR_PROPRIETARY_HEALTH_REPORT[285]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[284]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[283]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[282]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[281]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[280]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[279]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[278]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[277]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[276]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[275]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[274]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[273]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[272]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[271]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[270]]:0x00 _(Device life time estimation type B [DEVICE_LIFE_TIME_EST_TYP_B: 0x0a] i.e. 90% - 100% device life time used _(Device life time estimation type B [DEVICE_LIFE_TIME_EST_TYP_A: 0x01] i.e. 0% - 10% device life time used Pre EOL information [PRE_EOL_INFO: 0x03] i.e. Urgent Optimal read size [OPTIMAL_READ_SIZE: 0x40] Optimal write size [OPTIMAL_WRITE_SIZE: 0x40] Optimal trim unit size [OPTIMAL_TRIM_UNIT_SIZE: 0x07] Device version [DEVICE_VERSION: 0x38 - 0x05] Firmware version: [FIRMWARE_VERSION[261]]: 0x00 [FIRMWARE_VERSION[260]]: 0x00 [FIRMWARE_VERSION[259]]: 0x00 [FIRMWARE_VERSION[258]]: 0x00 [FIRMWARE_VERSION[257]]: 0x00 [FIRMWARE_VERSION[256]]: 0x00 [FIRMWARE_VERSION[255]]: 0x00 [FIRMWARE_VERSION[254]]: 0x07 Power class for 200MHz, DDR at VCC= 3.6V [PWR_CL_DDR_200_360: 0x00] ------------------------------------------------------------- Generic CMD6 Timer [GENERIC_CMD6_TIME: 0x05] Power off notification [POWER_OFF_LONG_TIME: 0x64] Cache Size [CACHE_SIZE] is 1024 KiB Background operations status [BKOPS_STATUS: 0x00] 1st Initialisation Time after programmed sector [INI_TIMEOUT_AP: 0x0a] Power class for 52MHz, DDR at 3.6V [PWR_CL_DDR_52_360: 0x00] Power class for 52MHz, DDR at 1.95V [PWR_CL_DDR_52_195: 0x00] Power class for 200MHz at 3.6V [PWR_CL_200_360: 0x00] Power class for 200MHz, at 1.95V [PWR_CL_200_195: 0x00] Minimum Performance for 8bit at 52MHz in DDR mode: [MIN_PERF_DDR_W_8_52: 0x00] [MIN_PERF_DDR_R_8_52: 0x00] TRIM Multiplier [TRIM_MULT: 0x02] Secure Feature support [SEC_FEATURE_SUPPORT: 0x55] Boot Information [BOOT_INFO: 0x07] Device supports alternative boot method Device supports dual data rate during boot Device supports high speed timing during boot Boot partition size [BOOT_SIZE_MULTI: 0x20] Access size [ACC_SIZE: 0x06] High-capacity erase unit size [HC_ERASE_GRP_SIZE: 0x01] High-capacity erase timeout [ERASE_TIMEOUT_MULT: 0x02] Reliable write sector count [REL_WR_SEC_C: 0x10] High-capacity W protect group size [HC_WP_GRP_SIZE: 0x10] Sleep current (VCC) [S_C_VCC: 0x07] Sleep current (VCCQ) [S_C_VCCQ: 0x07] Sleep/awake timeout [S_A_TIMEOUT: 0x11] Sector Count [SEC_COUNT: 0x00e90000] Minimum Write Performance for 8bit: [MIN_PERF_W_8_52: 0x00] [MIN_PERF_R_8_52: 0x00] [MIN_PERF_W_8_26_4_52: 0x00] [MIN_PERF_R_8_26_4_52: 0x00] Minimum Write Performance for 4bit: [MIN_PERF_W_4_26: 0x00] [MIN_PERF_R_4_26: 0x00] Power classes registers: [PWR_CL_26_360: 0x00] [PWR_CL_52_360: 0x00] [PWR_CL_26_195: 0x00] [PWR_CL_52_195: 0x00] Partition switching timing [PARTITION_SWITCH_TIME: 0x01] Out-of-interrupt busy timing [OUT_OF_INTERRUPT_TIME: 0x0a] I/O Driver Strength [DRIVER_STRENGTH: 0x1f] Card Type [CARD_TYPE: 0x57] CSD structure version [CSD_STRUCTURE: 0x02] Command set [CMD_SET: 0x00] Command set revision [CMD_SET_REV: 0x00] Power class [POWER_CLASS: 0x00] High-speed interface timing [HS_TIMING: 0x00] Erased memory content [ERASED_MEM_CONT: 0x00] Boot configuration bytes [PARTITION_CONFIG: 0x38] No access to boot partition Boot config protection [BOOT_CONFIG_PROT: 0x00] Boot bus Conditions [BOOT_BUS_CONDITIONS: 0x00] High-density erase group definition [ERASE_GROUP_DEF: 0x00] Boot write protection status registers [BOOT_WP_STATUS]: 0x00 Boot Area Write protection [BOOT_WP]: 0x00 Power ReadOnly locking: possible Permanent ReadOnly locking: possible Read Only lock status: not locked User area write protection register [USER_WP]: 0x00 FW configuration [FW_CONFIG]: 0x00 RPMB Size [RPMB_SIZE_MULT]: 0x20 Write reliability setting register [WR_REL_SET]: 0x1f Write reliability parameter register [WR_REL_PARAM]: 0x05 Enable background operations handshake [BKOPS_EN]: 0x00 H/W reset function [RST_N_FUNCTION]: 0x00 HPI management [HPI_MGMT]: 0x00 Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Max Enhanced Area Size [MAX_ENH_SIZE_MULT]: 0x0001d2 Partitions attribute [PARTITIONS_ATTRIBUTE]: 0x00 Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 General Purpose Partition Size [GP_SIZE_MULT_4]: 0x000000 [GP_SIZE_MULT_3]: 0x000000 [GP_SIZE_MULT_2]: 0x000000 [GP_SIZE_MULT_1]: 0x000000 Enhanced User Data Area Size [ENH_SIZE_MULT]: 0x000000 Enhanced User Data Start Address [ENH_START_ADDR]: 0x000000 Bad Block Management mode [SEC_BAD_BLK_MGMNT]: 0x00 Periodic Wake-up [PERIODIC_WAKEUP]: 0x00 Program CID/CSD in DDR mode support [PROGRAM_CID_CSD_DDR_SUPPORT]: 0x00 Native sector size [NATIVE_SECTOR_SIZE]: 0x01 Sector size emulation [USE_NATIVE_SECTOR]: 0x00 Sector size [DATA_SECTOR_SIZE]: 0x00 1st initialization after disabling sector size emulation [INI_TIMEOUT_EMU]: 0x0a Class 6 commands control [CLASS_6_CTRL]: 0x00 Number of addressed group to be released[DYNCAP_NEEDED]: 0x00 Exception events control [EXCEPTION_EVENTS_CTRL]: 0x0000 Exception events status [EXCEPTION_EVENTS_STATUS]: 0x0000 Extended Partitions Attribute [EXT_PARTITIONS_ATTRIBUTE]: 0x0000 Packed command status [PACKED_COMMAND_STATUS]: 0x00 Packed command failure index [PACKED_FAILURE_INDEX]: 0x00 Power Off Notification [POWER_OFF_NOTIFICATION]: 0x00 Control to turn the Cache ON/OFF [CACHE_CTRL]: 0x00 Partition table scan: GPT: present Found valid GPT with protective MBR; using GPT. Real (Hardware) Disk/Image size: E90000 sectors 7.3 GiB Soft (Partitioned) Disk/Image size: E8FFBC sectors 7.3 GiB Logical sector size: 0x200 bytes Disk identifier (GUID): 98101B32-BBE2-4BF2-A06E-2BB33D000C20 First usable sector: 34 Last usable sector: 15269854 Partition info successfully found --------------------------------------------- P0 (MODEM) [0x2000000 0x4000000] Size: 64.0MB P1 (SBL1) [0x6000000 0x80000] Size: 512.0KB P2 (SBL1BAK) [0x6080000 0x80000] Size: 512.0KB P3 (ABOOT) [0x6100000 0xf00000] Size: 15.0MB P4 (ABOOTBAK) [0x7000000 0xf00000] Size: 15.0MB P5 (RPM) [0x7f00000 0x80000] Size: 512.0KB P6 (RPMBAK) [0x7f80000 0x80000] Size: 512.0KB P7 (TZ) [0x8000000 0x80000] Size: 512.0KB P8 (TZBAK) [0x8080000 0x80000] Size: 512.0KB P9 (HYP) [0x8100000 0x80000] Size: 512.0KB P10 (HYPBAK) [0x8180000 0x80000] Size: 512.0KB P11 (PAD) [0x8200000 0x100000] Size: 1.0MB P12 (MODEMST1) [0x8300000 0x180000] Size: 1.500MB P13 (MODEMST2) [0x8480000 0x180000] Size: 1.500MB P14 (MISC) [0x8600000 0x100000] Size: 1.0MB P15 (FSC) [0x8700000 0x400] Size: 1.0KB P16 (SSD) [0x8700400 0x2000] Size: 8.0KB P17 (DDR) [0xa000000 0x8000] Size: 32.0KB P18 (FSG) [0xa008000 0x180000] Size: 1.500MB P19 (SEC) [0xa188000 0x4000] Size: 16.0KB P20 (BOOT) [0xa18c000 0x1400000] Size: 20.0MB P21 (PARAMS) [0xc000000 0x100000] Size: 1.0MB P22 (PANIC) [0xc100000 0x1400000] Size: 20.0MB P23 (AUTOBAK) [0xd500000 0xa00000] Size: 10.0MB P24 (SYSTEM) [0xe000000 0x80000000] Size: 2.0GB P25 (PERSIST) [0x8e000000 0xa00000] Size: 10.0MB P26 (CACHE) [0x8ea00000 0x8000000] Size: 128.0MB P27 (RECOVERY) [0x96a00000 0x1400000] Size: 20.0MB P28 (USERDATA) [0x97e00000 0x13a1fbe00] Size: 4.907GB ------ Android information ------ Detected LINUX(Android) SYSTEM : 0x000E000000 (2.0GB) Build ID: KTU84P Display Build ID: 4.4.137.00.T1.150519.KTU84P Release ID: 4.4.4 Device Model: Coolpad 8297L-I00 Device Name: Coolpad8297L-I00 Architecture ABI: armeabi-v7a Device manufacturer: YuLong Device Platform: msm8916 Product ID: Coolpad8297L-I00 Build Description: 1370200 --------------------------------------------- Done. |
12-20-2017, 13:26 | #6 (permalink) |
Freak Poster Join Date: May 2013
Member: 1935677 Status: Offline Thanks Meter: 22 | Coolpad 8297l-100 Hello experts, coolpad handset modal--8297l-100 hw ver =t1 sw ver= 4.4-150 handset problem hang on logo after flashing ygdp tool 3.98 100% ok but set dead , give me if dead boot solution ya give me qualicoom flash file ( qfil flash file ) the hand set show quallicoom hb usb qdloader port so, please give me working qfil file. Thanks in advance |
