04-08-2015, 05:33 | #1 (permalink) |
Freak Poster Join Date: Jan 2005 Location: Chandigarh ,UT ,India Age: 48
Member: 107258 Status: Offline Thanks Meter: 15 | Data Recovery - Options And Suggestions For HTC One X [ Tegra ] This is one of your aspiring reseller .I plan to carry and resell Z3X Soon .Anyways coming to the point i Have a data recovery case from a client .This is a HTC PJ46100 [ Tegra ] . In The Z3X Shell i Could not see any selection for this .Anyways In The Support section i have downloaded everything for Tegra One X HTC .The Two pinouts are as below . HTC One X Tegra Side A HTC One X Tegra Side B Question : I Am Using The Following Adapter By Moorc .Its called the " Jpin ISP Adapter " . The Photo is as following under .Even If i Connect The USB Cable to this adapter do i still need to connect usb power to HTC Tegra Board "This is stated in your pinout image " . Also is 3.3V required or 2.8V .As this Board Seems To output 2.8V .The Other Voltage 1.8V is All OK .The eMMc Seems To Be The " KMK2U000VM " .What i Like To Do is Read The eMMc To Extract User Data .Can you tell me which partition will have this Or i need to read full dump .Currently we have to " Recover Data " . Once This is Done i Will Look into the option of "Repair/Recover " . Image of My Moorc Adapter |
04-09-2015, 19:05 | #3 (permalink) |
Product Supporter Join Date: May 2011
Member: 1569669 Status: Offline Thanks Meter: 257 | Hi, You don't need to plug usb cable. Connect VCCQ to 1.8V on adapter, VCC to 2.8V on adapter, solder CLK, CMD, DAT0 lines. Don't forget to make short as shown on the pinout. !!!! Also possible mfg mistake in this adapter, sometimes 2.8/1.8 outputs are swapped. So, measure real voltages on the adapter. If Identify eMMC fail also try to plug usb cable into phone then remove it. Regards Viktor |
04-10-2015, 02:41 | #4 (permalink) |
Freak Poster Join Date: Sep 2009 Location: Indonesia
Member: 1112585 Status: Offline Sonork: 100.1645028 Thanks Meter: 91 | for data recovery, you can read all EMMC or just the most big OS partitions. tips.! read +- 10MB & open in WinHEX / Forensics & interpret As Disk. you will find User Data Partitions. |
04-10-2015, 09:46 | #5 (permalink) | ||
Member: 107258 Status: Offline Thanks Meter: 15 | Quote:
OK so no need to connect power to board .The pinout picture says we indeed need to .What do you mean by " Don't forget to make short as shown on the pinout." . Thanks i will test real voltages before i try the adapter thanks for the heads up .It will be my first Jtag/eMMC and i am so nervous lol Quote:
well i have a datarecovery center in chandigarh [ india ] .This will not work in other tools rstudio etc ? . | ||
04-11-2015, 12:40 | #6 (permalink) |
Member: 1112585 Status: Offline Sonork: 100.1645028 Thanks Meter: 91 | of course 10mb is not usable for D.R since the data needed not reside there.! that +-10MB read is only for to find MBR/GPT (EFI PART...samsung.?) & may be 1MB enough. if you know where userdata partition reside, you can read from that address (userdata partitions start Addsess.) and you can mount that image on linux (FAT32, Ntfs, ext3/4.) & just copy the data normally. or if the userdata partitions FAT32 you can use ImDisk on Windows. if partitions structure damage, rstudio etc become handy. and you must read the hole EMMC. |
04-11-2015, 13:44 | #7 (permalink) | |
No Life Poster Join Date: Dec 2006 Location: GSM WORLD
Member: 412843 Status: Offline Sonork: 100.1604902 Thanks Meter: 497 | Quote:
How To Recognize DDR aboot boot cache recovery rpm sbl1 userdata ETC ETC ETC By WinHex | |
04-11-2015, 15:56 | #8 (permalink) |
Member: 1112585 Status: Offline Sonork: 100.1645028 Thanks Meter: 91 | open the partition & compare it with good known magic number and or header. or you can use logic. almost userdata partition is BIG & formatted with universal filesystem (FAT32.?) it is, so it can be accessed in different variety of platform / devices. for FAT32, magic number UŠ (HEX 55AA) if you use rstudio etc, ignore all of that Technical details & just open the image & menu scan. sample sam part from physical sector 0 & easy jtag have facilities Read Soft Partitions. use it.! |
