07-02-2020, 09:22 | #1 (permalink) |
No Life Poster Join Date: Sep 2011 Location: Dhaka,Bangldesh
Member: 1659078 Status: Offline Sonork: Mahidi Munna Thanks Meter: 199 | dear team see my log and help me please Setting interface to EasyJtag2/ISP_HiPower Setting bus width to 1 Bit HiPower mode is ON Setting frequence to 24 MHz CMD Pullup Level: 2098 mV CMD Active Level: 2720 mV EMMC Device Information : EMMC CID: 90014A68423861503E03C652F5C12699 EMMC CSD: D02700328F5903FFFFFFFFEF8E400043 EMMC Manufacture : SKHYNIX , EMMC NAME: hB8aP> , HEX: 68423861503E , S/N: C652F5C1 , rev. 0x03 EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Date: 2/2019 EMMC ROM 1 (Main User Data) Capacity: 29816 MB (000747800000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 KB (000001000000) Counter: 189737 , Response: Not Clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x38 , Boot from: ROM1 (Main User Area) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x01 Backup saved: hB8aP__C652F5C1_20200702_142137.extcsd EMMC Init completed. Warning: Health report is very BAD Device Life Time Estimation (MLC) [269]: 0x01 0% - 10% device life time used Device Life Time Estimation (SLC) [268]: 0x00 Not defined Pre EOL information [267]: 0x03 Urgent |
07-02-2020, 11:28 | #2 (permalink) |
Product Supporter Join Date: Jun 2002 Location: Belarus Age: 47
Member: 13148 Status: Offline Thanks Meter: 2,948 | Pre EOL information [267]: 0x03 Urgent Pre EOL information: overall status for reserved blocks. Possible values are: 0x00 - Not defined. 0x01 - Normal: consumed less than 80% of the reserved blocks. 0x02 - Warning: consumed 80% of the reserved blocks. 0x03 - Urgent: consumed 90% of the reserved blocks. |
The Following 2 Users Say Thank You to layder For This Useful Post: |
