04-25-2014, 12:47 | #1 (permalink) | |
No Life Poster Join Date: Nov 2006 Location: Germany
Member: 396421 Status: Offline Thanks Meter: 87 | direct eMMC connection failed. pinout wrong? i soldered directly some wires. IMG_0195.jpg I used this eMMC adapter from Multi-Com. IMG_0194.jpg When i try to connect eMMC via easyJTag i get this screen. Quote:
thx & br | |
The Following User Says Thank You to huzein For This Useful Post: |
04-27-2014, 17:52 | #5 (permalink) |
Member: 396421 Status: Offline Thanks Meter: 87 | with this adapter i could already establish eMMC connection when i soldered to pins on pcb. but also in this way i get very often this error message which i wrote in first post. something can be wrong with my adapter? too short wires? what this can be? |
04-28-2014, 11:44 | #6 (permalink) | |
Freak Poster Join Date: Sep 2012 Location: madrid spain
Member: 1815849 Status: Offline Thanks Meter: 17 | Quote:
tienes que poner el adaptador al reves | |
The Following User Says Thank You to a65333002 For This Useful Post: |
04-28-2014, 13:00 | #9 (permalink) | |
Member: 396421 Status: Offline Thanks Meter: 87 | i have done now as said and now it seems to be good but CMD Timeout Error appeared. Quote:
br | |
05-02-2014, 10:36 | #11 (permalink) |
Product Supporter Join Date: Mar 2005 Location: China
Member: 129885 Status: Offline Sonork: 100:1603514 Thanks Meter: 6,202 | Hi, check if all power domains connected together. I mean if chip have different points for VCC and VCCQ - they must connected together same - VSS points. I can give here photo how they are connected in adapter. |
05-02-2014, 11:22 | #12 (permalink) |
No Life Poster Join Date: Dec 2013 Location: Poland
Member: 2085623 Status: Offline Thanks Meter: 221 | I got same problem with multi-com.pl adapter emmc direct and i9300 can someone give here solution, my soldering is perfect and got same error like I see there, this is adapter problem or what ?? |
05-03-2014, 22:21 | #14 (permalink) | |
Member: 396421 Status: Offline Thanks Meter: 87 | Quote:
br Gesendet von meinem GT-I9100 mit Tapatalk | |
05-04-2014, 15:18 | #15 (permalink) |
Freak Poster Join Date: Feb 2008
Member: 695166 Status: Offline Thanks Meter: 24 | same problem Done. Z3X EasyJtag Software ver. 1.3.1.0 Loading eMMC Addon Firmware... IO: 1850 mV Box S/N: xxxxxxxxxxxxxxx, ,FW Ver.: 01.49 Warning: CMD Pullup Level (1196 mV) too low , check cables etc.!!! CMD Active Level:1619 mV Can't init EMMC, Reason: CMD Timeout Error =================================== Done. |
