Register | FAQ | Donate | Forum Rules | Root any Device | ★iPhone Unlock★ | [ Easy-JTAG ] | Direct Unlock Source | Search | Today's Posts | Mark Forums Read |
![]() | #1 (permalink) | |
No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Nov 2006
Member: 396421 Status: Offline Thanks Meter: 87 | direct eMMC connection failed. pinout wrong? i soldered directly some wires. IMG_0195.jpg I used this eMMC adapter from Multi-Com. IMG_0194.jpg When i try to connect eMMC via easyJTag i get this screen. Quote:
thx & br | |
The Following User Says Thank You to huzein For This Useful Post: |
![]() | #5 (permalink) |
Member: 396421 Status: Offline Thanks Meter: 87 | with this adapter i could already establish eMMC connection when i soldered to pins on pcb. but also in this way i get very often this error message which i wrote in first post. something can be wrong with my adapter? too short wires? what this can be? |
![]() | #6 (permalink) | |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Sep 2012
Member: 1815849 Status: Offline Thanks Meter: 11 | Quote:
tienes que poner el adaptador al reves | |
The Following User Says Thank You to a65333002 For This Useful Post: |
![]() | #9 (permalink) | |
Member: 396421 Status: Offline Thanks Meter: 87 | i have done now as said and now it seems to be good but CMD Timeout Error appeared. Quote:
br | |
![]() | #11 (permalink) |
Product Supporter ![]() ![]() ![]() Join Date: Mar 2005 Location: China
Member: 129885 Status: Offline Sonork: 100:1603514 Thanks Meter: 6,186 | Hi, check if all power domains connected together. I mean if chip have different points for VCC and VCCQ - they must connected together same - VSS points. I can give here photo how they are connected in adapter. |
![]() | #12 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Dec 2013 Location: Poland
Member: 2085623 Status: Offline Thanks Meter: 221 | I got same problem with multi-com.pl adapter emmc direct and i9300 can someone give here solution, my soldering is perfect and got same error like I see there, this is adapter problem or what ?? |
![]() | #14 (permalink) | |
Member: 396421 Status: Offline Thanks Meter: 87 | Quote:
br Gesendet von meinem GT-I9100 mit Tapatalk | |
![]() | #15 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Feb 2008
Member: 695166 Status: Offline Thanks Meter: 24 | same problem Done. Z3X EasyJtag Software ver. 1.3.1.0 Loading eMMC Addon Firmware... IO: 1850 mV Box S/N: xxxxxxxxxxxxxxx, ,FW Ver.: 01.49 Warning: CMD Pullup Level (1196 mV) too low , check cables etc.!!! CMD Active Level:1619 mV Can't init EMMC, Reason: CMD Timeout Error =================================== Done. |
