05-07-2017, 08:26 | #1 (permalink) |
Junior Member Join Date: Apr 2017
Member: 2703674 Status: Offline Thanks Meter: 11 | Do I need to change EMMC? my phone hangs on logo and I have two questions : 1_where is userdata files (pics,videos,sounds,...) in EMMC File Mnager? 2_for repairing phone I need change EMMC or no? thanks in advance log : EasyJtag Suite Classic ver.: 2.5.0.9 / wxWidgets 3.1.0-W-U started. OS ver.: Windows 7 (build 7601, Service Pack 1), 64-bit edition. Admin rights OK undefined Android Explorer ver.: 1.0.0.23 eMMC ODIN ver.: 1.0.11.2 Successfully connected to box on COM275 Box S/N: 1700E0047114C7F6, ,FW Ver.: 01.58 Box Working Mode: JTAG Box. Box Drivers version: 3.0.1.0, are OK Z3X Card Serial : AA88-CC67 , ver: 22 Z3X Card Activation [LG] : NOT ACTIVATED Z3X Card Activation [SAMS] : NOT ACTIVATED Z3X Card Activation [JTAG] : ACTIVATED Z3X EasyJtag Software ver. 2.5.0.9 Loading eMMC Addon Firmware... IO: 2800 mV Box S/N: 1700E0047114C7F6, ,FW Ver.: 01.58 CMD Pullup Level:3165 mV CMD Active Level:2939 mV Box IO Level:2800 mV CLK Rate:14000 khz HiPower mode is off! ---------- eMMC Device Information ---------- EMMC CID : 90014A4834473164048600A338A83196 EMMC CSD : D02701320F5903FFFFFFFFE78A4040E2 EMMC Manufacturer ID: 0090 , OEM ID: 014A EMMC Date: 03/2014 Rev.0x86 EMMC NAME: H4G1d , S/N: 10696872 EMMC NAME (HEX): 48344731642000 EMMC ROM1 (Main User Data) Capacity: 3696 MB EMMC ROM2 (Boot Partition 1) Capacity: 2048 kB EMMC ROM3 (Boot Partition 2) Capacity: 2048 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 2048 kB EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.5 (MMC 4.41) Boot configuration [PARTITION_CONFIG: 0x38] Boot from:ROM1 (Main User Area) Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x38. H/W reset function [RST_N_FUNCTION]: 0x00 High-capacity W protect group size [HC_WP_GRP_SIZE: 0x00000000] Partitioning Support [PARTITIONING_SUPPORT]: 0x03 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: H4G1d _ 10696872_20170507_1139.extcsd --------------------------------------------- Done. |
05-07-2017, 13:19 | #2 (permalink) |
No Life Poster Join Date: Apr 2003 Location: Torun, Poland Age: 40
Member: 25996 Status: Offline Thanks Meter: 253 | Read the eMMC again with partiton details marked. Then, if everything is fine you should see a list of partitons and an userdata one (usually the biggest one, often at the very end of the list). Once you'll have that, you can just select userdata preset and read only that partiton if you need to get userdata or you can use explorer feature for easy jtag plus to browse it and read only the files you need directly. In case of repair, for me this looks fine, properly identified, no write protection, phone might just need reflashing with new firmware and that might be all. What phone is it exacly? |
The Following User Says Thank You to KrzychuG For This Useful Post: |
05-07-2017, 15:33 | #3 (permalink) |
Member: 2703674 Status: Offline Thanks Meter: 11 | Phone is G615-U10 and I need access /storage/sdcard0/DCIM but I can't find storage partition !!! Screeshot : https://forum.gsmhosting.com/vbb/****************************/?85p74b8dgavwy4q and for repairing I don't have any dump file (phone doesn't enter fastboot and recovery mode for flashing) ,Please give me if you have it thanks in advance Last edited by zer0nemswc; 05-07-2017 at 15:42. |
05-07-2017, 16:43 | #4 (permalink) |
Member: 25996 Status: Offline Thanks Meter: 253 | For data, check /media, then probably 0/ and DCIM should be there. For dump i can't help, but you might try to look for firmware file, extract update.app with this and flash partiton images to apropriate partitons on the eMMC. In general, you should flash aboot, boot, recovery, rpm, sbl1, sdi and tz which should give you phone booting to at least recovery mode and allow to fully reflash the device via SD card with same firmware. The problem might still be elsewere tho. |
05-08-2017, 08:25 | #5 (permalink) |
Member: 2703674 Status: Offline Thanks Meter: 11 | I only can write BOOT.img and RECOVERY.img and when I select other files (ABOOT,RPM,SBL1,SDI,TZ) to write : log: Checking NAND Image : C:\Users\Parham\Desktop\BackUp\G615-u10\ABOOT.img Autodetected RAW data Partition info successfully found File are not page aligned! Unable to write such file!<----<<< In which section extactly can I flash such files? thanks alot |
05-10-2017, 17:18 | #7 (permalink) |
Member: 25996 Status: Offline Thanks Meter: 253 | Not sure how you tried it, but try like this: 1. Check "read soft partitons" 2. Detect eMMC Card - this should print you partitions on the eMMC. 3. In "presets" menu (marked as 1 on screenshot) select partition you want to flash. 4. In "image" menu (marked as 2) select partion image you want to flash. 5. Press "write emmc card" If this goes fine repeat the process for other files. If that won't help, you can yet try "write by vendor option in easy-jtag plus a select qualcomm/hisilicon, then "try to read table from emmc" and fill the partitons you want to flash with files you extracted from APP. then you probably will have to look for some dump or make dump using second phone. |
