05-05-2017, 10:22 | #1 (permalink) |
No Life Poster Join Date: Jan 2006 Location: Poland Age: 39
Member: 219917 Status: Offline Thanks Meter: 60 | Dying HTC's M9 EMMC chips Some time ago I notice that many HTC M9 with Hynix EMMC chips died without any reason. Some cannot be repaired because they cannot be flashed anymore (only reset sectors without any write), some can be repaired, but most of them back after short time with same problems. After latest EasyJTAG plus update there is possibility to read SMART info from this chips. How to read those informations axactly? Here is log from some M9 with broken EMMC: Code: 2017-05-05 10:54:57> eMMC_tool Suite ver. 1.0.0.45 2017-05-05 10:54:57> Microsoft Windows 7 (64 bit) build 7601 (6.1.7601.18015) 2017-05-05 10:54:57> 2017-05-05 10:54:57> Looking for EasyJTAG box... 2017-05-05 10:54:57> EasyJTAG API ver. 2008 2017-05-05 10:54:57> Setting IO Levels to 2.8V 2017-05-05 10:54:57> Setting frequence to 21 Mhz 2017-05-05 10:54:57> HiPower mode is OFF 2017-05-05 10:54:58> OpenUSB returned = 0 2017-05-05 10:54:58> Power Controller returned = 0 2017-05-05 10:54:58> EasyJTAG Box Serial = xxxxxxxxxxx 2017-05-05 10:55:04> Card Serial = xxxxxxxxx 2017-05-05 10:55:04> CardAttr = xxxxxxxxxxxxxxxxxxxxxxx 2017-05-05 10:55:04> EasyJTAG Box Firmware = 01.58 2017-05-05 10:55:04> 2017-05-05 10:55:11> Looking for EasyJTAG box... 2017-05-05 10:55:11> EasyJTAG API ver. 2008 2017-05-05 10:55:11> Setting IO Levels to 2.8V 2017-05-05 10:55:11> Setting frequence to 21 Mhz 2017-05-05 10:55:11> HiPower mode is OFF 2017-05-05 10:55:12> OpenUSB returned = 0 2017-05-05 10:55:12> Power Controller returned = 0 2017-05-05 10:55:12> EasyJTAG Box Serial = xxxxxxxxxxxxxxx 2017-05-05 10:55:12> EasyJTAG Box Firmware = 01.58 2017-05-05 10:55:12> HiPower mode is OFF 2017-05-05 10:55:12> CMD Pullup Level: 2062 mV 2017-05-05 10:55:12> CMD Active Level: 2547 mV 2017-05-05 10:55:12> eMMC Init returned = 0 2017-05-05 10:55:12> EMMC Device Information : 2017-05-05 10:55:12> EMMC CID: 90014A48424734650507B3A4DD612264 2017-05-05 10:55:12> EMMC CSD: D02701320F5903FFFFFFFFEF8A4040D2 2017-05-05 10:55:12> EMMC Manufacture Name: SKHYNIX 2017-05-05 10:55:12> EMMC Manufacture ID: 0x90 , OEM ID: 014A 2017-05-05 10:55:12> EMMC Manufacture Date: 2/2015 , Rev: 07 2017-05-05 10:55:12> EMMC NAME: HBG4e , S/N: B3A4DD61 , rev. 07 2017-05-05 10:55:12> EMMC NAME (HEX): 484247346505 2017-05-05 10:55:12> EMMC ROM 1 (Main User Data) Capacity: 29824 MB (000748000000) 2017-05-05 10:55:12> EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) 2017-05-05 10:55:12> EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) 2017-05-05 10:55:12> EMMC Permanent Write Protection: No 2017-05-05 10:55:12> EMMC Temporary Write Protection: No 2017-05-05 10:55:12> Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01) 2017-05-05 10:55:12> Boot configuration [PARTITION_CONFIG]: 0x00 , Boot from: no boot 2017-05-05 10:55:12> Boot Bus Config: 0x00 , width 1bit 2017-05-05 10:55:12> H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled 2017-05-05 10:55:12> Supported partition features [PARTITIONING_SUPPORT]: 0x07 2017-05-05 10:55:12> Device supports partitioning features 2017-05-05 10:55:12> Device can have enhanced technological features in partitions and user data area 2017-05-05 10:55:12> Device can have extended partitions attribute 2017-05-05 10:55:12> Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 2017-05-05 10:55:12> Backup saved: HBG4e_B3A4DD61_20170505_105512.extcsd 2017-05-05 10:55:12> EMMC Init completed. 2017-05-05 10:55:12> 2017-05-05 10:55:12> Reading S.M.A.R.T Report ... 2017-05-05 10:55:12> 2017-05-05 10:55:12> Supported modes [493]: 0x01 2017-05-05 10:55:12> FFU is supported by the device 2017-05-05 10:55:12> Vendor Specific Mode (VSM) is not supported by the device 2017-05-05 10:55:12> FFU Features [492]: 0x00 2017-05-05 10:55:12> Device does not support MODE_OPERATION_CODES field 2017-05-05 10:55:12> Operation Codes Timeout [491]: 0x17 838,86 s 2017-05-05 10:55:12> FFU Argument [497_490]: 0x00006600 2017-05-05 10:55:12> Number of FW sectors correctly programmed [302_305]: 0x00000000 2017-05-05 10:55:12> Vendor Proprietary Health Report [301_270]: 2017-05-05 10:55:12> VENDOR_PROPRIETARY_HEALTH_REPORT [301]: 0x00 2017-05-05 10:55:12> VENDOR_PROPRIETARY_HEALTH_REPORT [300]: 0x00 2017-05-05 10:55:13> VENDOR_PROPRIETARY_HEALTH_REPORT [299]: 0x00 2017-05-05 10:55:13> VENDOR_PROPRIETARY_HEALTH_REPORT [298]: 0xEE 2017-05-05 10:55:13> VENDOR_PROPRIETARY_HEALTH_REPORT [297]: 0x00 2017-05-05 10:55:13> VENDOR_PROPRIETARY_HEALTH_REPORT [296]: 0x00 2017-05-05 10:55:13> VENDOR_PROPRIETARY_HEALTH_REPORT [295]: 0x00 2017-05-05 10:55:13> VENDOR_PROPRIETARY_HEALTH_REPORT [294]: 0xEE 2017-05-05 10:55:13> VENDOR_PROPRIETARY_HEALTH_REPORT [293]: 0x00 2017-05-05 10:55:13> VENDOR_PROPRIETARY_HEALTH_REPORT [292]: 0x00 2017-05-05 10:55:13> VENDOR_PROPRIETARY_HEALTH_REPORT [291]: 0x00 2017-05-05 10:55:13> VENDOR_PROPRIETARY_HEALTH_REPORT [290]: 0xEE 2017-05-05 10:55:13> VENDOR_PROPRIETARY_HEALTH_REPORT [289]: 0x00 2017-05-05 10:55:13> VENDOR_PROPRIETARY_HEALTH_REPORT [288]: 0x00 2017-05-05 10:55:13> VENDOR_PROPRIETARY_HEALTH_REPORT [287]: 0x00 2017-05-05 10:55:13> VENDOR_PROPRIETARY_HEALTH_REPORT [286]: 0xEE 2017-05-05 10:55:13> VENDOR_PROPRIETARY_HEALTH_REPORT [285]: 0x00 2017-05-05 10:55:13> VENDOR_PROPRIETARY_HEALTH_REPORT [284]: 0x00 2017-05-05 10:55:13> VENDOR_PROPRIETARY_HEALTH_REPORT [283]: 0x00 2017-05-05 10:55:13> VENDOR_PROPRIETARY_HEALTH_REPORT [282]: 0x00 2017-05-05 10:55:13> VENDOR_PROPRIETARY_HEALTH_REPORT [281]: 0x00 2017-05-05 10:55:13> VENDOR_PROPRIETARY_HEALTH_REPORT [280]: 0x00 2017-05-05 10:55:13> VENDOR_PROPRIETARY_HEALTH_REPORT [279]: 0x00 2017-05-05 10:55:13> VENDOR_PROPRIETARY_HEALTH_REPORT [278]: 0x00 2017-05-05 10:55:13> VENDOR_PROPRIETARY_HEALTH_REPORT [277]: 0x00 2017-05-05 10:55:13> VENDOR_PROPRIETARY_HEALTH_REPORT [276]: 0x00 2017-05-05 10:55:13> VENDOR_PROPRIETARY_HEALTH_REPORT [275]: 0x00 2017-05-05 10:55:13> VENDOR_PROPRIETARY_HEALTH_REPORT [274]: 0x00 2017-05-05 10:55:13> VENDOR_PROPRIETARY_HEALTH_REPORT [273]: 0x00 2017-05-05 10:55:13> VENDOR_PROPRIETARY_HEALTH_REPORT [272]: 0x00 2017-05-05 10:55:13> VENDOR_PROPRIETARY_HEALTH_REPORT [271]: 0x00 2017-05-05 10:55:13> VENDOR_PROPRIETARY_HEALTH_REPORT [270]: 0x00 2017-05-05 10:55:13> Device Life Time Estimation Type B [269]: 0x0B 2017-05-05 10:55:13> Exceeded its maximum estimated device life time 2017-05-05 10:55:13> Device Life Time Estimation Type A [268]: 0x01 2017-05-05 10:55:13> 0% - 10% device life time used 2017-05-05 10:55:13> Pre EOL information [267]: 0x03 2017-05-05 10:55:13> Urgent 2017-05-05 10:55:13> 2017-05-05 10:55:13> Optimal Read Size [266]: 0x40 256 KB 2017-05-05 10:55:13> Optimal Write Size [265]: 0x40 256 KB 2017-05-05 10:55:13> Optimal Trim Unit Size [264]: 0x07 28 KB 2017-05-05 10:55:13> 2017-05-05 10:55:13> Device Version [263_262]: 0x05 - 0x42 2017-05-05 10:55:13> Firmware version [261_254]: 2017-05-05 10:55:13> FIRMWARE_VERSION [261]: 0x00 2017-05-05 10:55:13> FIRMWARE_VERSION [260]: 0x00 2017-05-05 10:55:13> FIRMWARE_VERSION [259]: 0x00 2017-05-05 10:55:13> FIRMWARE_VERSION [258]: 0x00 2017-05-05 10:55:13> FIRMWARE_VERSION [257]: 0x00 2017-05-05 10:55:13> FIRMWARE_VERSION [256]: 0x00 2017-05-05 10:55:13> FIRMWARE_VERSION [255]: 0x00 2017-05-05 10:55:13> FIRMWARE_VERSION [254]: 0x07 2017-05-05 10:55:13> 2017-05-05 10:55:13> Done 2017-05-05 10:55:13> Device Life Time Estimation Type B [269]: 0x0B 2017-05-05 10:55:13> Exceeded its maximum estimated device life time but have no idea what is LifeTime Type B exactly. How to use all of this informations? |
05-06-2017, 01:03 | #2 (permalink) | |
Product Supporter Join Date: Mar 2005 Location: China
Member: 129885 Status: Offline Sonork: 100:1603514 Thanks Meter: 6,202 | Quote:
According to HYNIX PDF on that chips - TYPE B is MLC Cells Health Status.Exceeded its maximum estimated device life time means that device used all reserved backup cells for bad block relocation. Normally it need replacement or firmware upgrade for reseting counters. At this moment procedures for that are private and nothin we can do ;-( | |
The Following User Says Thank You to NoName® For This Useful Post: |
05-08-2017, 10:03 | #3 (permalink) |
Member: 219917 Status: Offline Thanks Meter: 60 | That's ok. Chip is changed to other one and phone is working again. Good information we can check it and make decision to replace EMMC or try to fix bootloader. I have question about contacts restoring yet. I have try read contacts from this phone but program said "bad file". File for SMS not exist inside telephony folder. Did Android 7 store contacts and SMS in other way? |
