05-28-2021, 22:19 | #1 (permalink) |
No Life Poster Join Date: Feb 2003 Location: africa Age: 54
Member: 22284 Status: Offline Thanks Meter: 81 | Support help this a530f Hello i have A8 2018 sm-a530f which has the emmc files corrupted , i need to revive and when i connect to the Easy Jtag Plus i get the error Partition info not found ,guide repair procedures and below is the log data Setting interface to EasyJtag2/ISP Setting bus width to 1 Bit Setting frequence to 36 MHz CMD Pullup Level: 445 mV CMD Active Level: 1192 mV EMMC Device Information : EMMC CID: 150100424A5444345200523F424BB5A7 EMMC CSD: D02701320F5903FFF6DBFFEF8E40400D EMMC Manufacture : SAMSUNG , EMMC NAME: BJTD4R , HEX: 424A544434xx , S/N: 523F42xx , rev. 0x00 EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 11/2018 EMMC ROM 1 (Main User Data) Capacity: 29820 MB (000747C00000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 KB (000001000000) Counter: 0 , Response: Maybe not clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x01 , width 4bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: BJTD4R_523F424B_20210404_201644.extcsd EMMC Init completed. Scanning soft partitions Partition table not found Get firmware version Firmware info not found NOTE: I HAVE THE BACK UP FILE BUT I DO NOT KNOW WHICH FILES TO LOAD , MAY SOMEONE CHECK THE ATTACHMENT AND TELL ME WHICH FILES TO LOAD LIKE (Select eMMC Image file *.bin) from THIS BACK UP.MAY SOMEONE TELL ME FROM THE BACK UP WHICH ONE IS ( eMMC ROM1 Image file, eMMC ROM2 Image file, eMMC ROM3 Image file, eMMC GP1 Image file, eMMC ExtCSD file. IN THEIR ORDER. I GOT THE DUMP FILE CAN SOMEONE TELL WHICH FILES ARE ROM 1,ROM2,R0M3 and EXS |
