11-25-2018, 04:30 | #1 (permalink) |
Freak Poster Join Date: Sep 2015
Member: 2463805 Status: Offline Thanks Meter: 32 | Easy jtag plus card not found Tried reinstall box and card driver unfortunately that doesn't help to fix it. If Anyone had same issue please share your solution. Thanks |
11-25-2018, 11:23 | #2 (permalink) | |
Product Supporter Join Date: Jun 2002 Location: Belarus Age: 47
Member: 13148 Status: Offline Thanks Meter: 2,948 | Quote:
If you have cutted card, you need to restore it to original size. Some Chinese sellers cut the cards (at old box revision). You need to ramp up the card to use with new box. One of variants: neatly cut cards to Micro-SIM size at SIM cutter and use Mini-SIM adapter with it Last edited by layder; 11-25-2018 at 13:24. Reason: merge posts | |
The Following 3 Users Say Thank You to layder For This Useful Post: |
11-25-2018, 16:08 | #3 (permalink) |
Member: 2463805 Status: Offline Thanks Meter: 32 | Card is perfect Thanks for quick response. As you mentioned the card position I inserted same way and the card is original size. got error -9103 (Z3X card is not detected.please check card inside.) Might be 2 reason for it doesn't work Card reader driver 1. The card detected in device manager in first time. So no issues with card. Can you tell me which card reader driver is appropriate for v2 box because I installed Microsoft generic CCID driver. 2.Box card reader damaged because for old version box it's working. |
11-28-2018, 13:58 | #4 (permalink) |
Member: 2463805 Status: Offline Thanks Meter: 32 | Support team please verify I asked seller about the card problem, he said "Z3X team answered that your card is very old and you have to buy Z3X Replacement Smart-Card." But I don't agree because The old box bought in 2017-09-15, is that very old ? How it's possible if the card very old then Z3X team selling upgrade kit for the old box activated after activated 2017.07.07? Please kindly verify it is card really need to replace. Thank you |
11-28-2018, 16:11 | #5 (permalink) |
Member: 13148 Status: Offline Thanks Meter: 2,948 | post info from z3x shell -> hardware wizard -> show card info replace last 4 simbols at card serial to xxxx |
The Following 2 Users Say Thank You to layder For This Useful Post: |
11-28-2018, 20:18 | #7 (permalink) | |
the seller must add activation to your card free. if you have problems with him, mail me at PM SN of you card and SN of new box. also you can post 1 star to the seller because he is deceiving you | |
The Following User Says Thank You to layder For This Useful Post: |
