01-01-2020, 15:19 | #1 (permalink) |
Freak Poster Join Date: Feb 2012 Location: iran
Member: 1724300 Status: Offline Thanks Meter: 42 | easy jtag plus not d COM6 USB\VID_1781&PID_AAAC&REV_0100&MI_00 EasyJTAG Command Port (COM6) COM1 ACPI\VEN_PNP&DEV_0501 Communications Port (COM1) Selected pinout: GEN2 High Speed Pinout Change EasyJTAG Pinout OK Z3X EasyJtag Software ver. 3.5.0.0 Loading eMMC GEN2 Firmware... IO: 2800 mV Initial pull results: clock: 0mV pin unconnected command: 0mV pin unconnected data0: 0mV pin unconnected data1: 0mV pin unconnected data2: 0mV pin unconnected data3: 0mV pin unconnected data4: 0mV pin unconnected data5: 0mV pin unconnected data6: 0mV pin unconnected data7: 0mV pin unconnected Box S/N: 0000000000000000, ,FW Ver.: 00.00 Warning: CMD Pullup Level (0 mV) too low , check cables etc.! CMD Active Level:0 mV Box IO Level:2800 mV CLK Rate:42000 kHz Bus Width:8bit,SDR HiPower mode is off! ---------- eMMC Device Information ---------- eMMC CID : 1501004B4A5330304D0361BB21F35047 eMMC CSD : D02701320F5903FFF6DBFFE78A404057 eMMC Manufacturer ID: 0015 , OEM ID: 0100 eMMC Date: 05/2013 Rev.0x3 eMMC NAME: KJS00M , S/N: 1639653875 eMMC NAME (HEX): 4B4A5330304D IC Name: Samsung , KMKJS000VM-B309/4GB+LPDDR2 8Gb(x32) @FBGA162 Can't init EMMC, Reason: DATA RCV CRC Error Check Data Line! Done. Can't init device, Reason: Unknown error (-30) Done. |
01-01-2020, 16:24 | #2 (permalink) |
Member: 1724300 Status: Offline Thanks Meter: 42 | EasyJtag_Release_v3.6.2.0 detected EasyJtag_Release_v3.6.2.0 detected Found 2 serial devices COM6 USB\VID_1781&PID_AAAC&REV_0100&MI_00 EasyJTAG Command Port (COM6) COM1 ACPI\VEN_PNP&DEV_0501 Communications Port (COM1) Selected pinout: GEN2 High Speed Pinout Change EasyJTAG Pinout OK Z3X EasyJtag Software ver. 3.6.2.0 Loading eMMC GEN2 Firmware... IO: 1800 mV Initial pull results: clock: 1051mV pin connected ok command: 1000mV pin connected ok data0: 1030mV pin connected ok data1: 1003mV pin connected ok data2: 1008mV pin connected ok data3: 1004mV pin connected ok data4: 999mV pin connected ok data5: 1007mV pin connected ok data6: 1007mV pin connected ok data7: 1005mV pin connected ok Box S/N: 4C5936CB3821B6BE, ,FW Ver.: 02.50 Box IO Level:1800 mV CLK Rate:42000 kHz Bus Width:8bit,SDR HiPower mode is off! ---------- eMMC Device Information ---------- eMMC CID : 1501004B4A5330304D0361BB21F35047 eMMC CSD : D02701320F5903FFF6DBFFE78A404057 eMMC Manufacturer ID: 0015 , OEM ID: 0100 eMMC Date: 05/2013 Rev.0x3 eMMC NAME: KJS00M , S/N: 1639653875 eMMC NAME (HEX): 4B4A5330304D IC Name: Samsung , KMKJS000VM-B309/4GB+LPDDR2 8Gb(x32) @FBGA162 EMMC ROM1 (Main User Data) Capacity: 3728 MB EMMC ROM2 (Boot Partition 1) Capacity: 1024 kB EMMC ROM3 (Boot Partition 2) Capacity: 1024 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB EMMC RPMB is not yet programmed (clear) or RPMB General failure EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.5 (MMC 4.41) Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x01 , width 4bits , Partition config [179]: 0x48. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00002000] Partitioning Support [PARTITIONING_SUPPORT]: 0x03 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: KJS00M_1639653875_20200101_1846.extcsd Partition info not found Done. Selected eMMC Interface Failed to load partition but not detect Easyjtag_emmc_plus_1.5.3.0 Easyjtag_emmc_plus_1.6.1.0 Easyjtag_emmc_plus_1.6.2.0 eMMC_tool Suite ver. 1.6.1.0 (release date: 30.06.2019) Microsoft Windows 10 (64 bit) build 17134 (10.0.17134.1038) Looking for EasyJTAG box... EasyJTAG API ver. 3307 EasyJTAG Box Serial = 4C5936CB3821B6BE Card Serial = AAAF53D9 EasyJTAG Box Firmware = 2.50 Changelog: 30.06.2019 (ver 1.6.1.0) Fix: Bugs that have been found through your crash report Setting interface to EasyJtag2/E-Socket Setting bus width to 1 Bit Setting frequence to 42 MHz Can't init device. Reason: DATA RCV Timeout Error Can't init device. Reason: DATA RCV Timeout Error Can't init device. Reason: DATA RCV Timeout Error Last edited by sajad0789; 01-01-2020 at 16:29. |
