EASY JTAG PLUS UFS BGA 254/ISP 2in1 NOT WORKING WITH ANY UFS CHIP UFS BGA 254/ISP 2in1 ISP Pinout line do not work!! I have tried many ufs ic and is not working with good BGA 153 etc ISP or Any Ufs CHIP. Any SOLUTION?? |
Same problem here. I thought was wrong pinout in my case. Could you provide your pinout, please? |
Hello, it seems something wrong with your BGA254 socket. Can you make a clear hi quality photos of both sides and post a log sample ? |
Log: Code: EasyJtag Suite Classic ver.: 3.7.0.17 / wxWidgets 3.1.3-W-U started. |
EasyJtag Suite Classic ver.: 3.7.0.11 / wxWidgets 3.1.3-W-U started. OS ver.: Windows 10 (build 18363), 64-bit edition. Admin rights FAIL Android Explorer ver:1.0.0.13 Autorun Agent ver:1.0.0.0 Crash Reporting ver:1.4.0.3 eMMC Odin ver:1.0.0.6 QUALCOMM Direct ver:1.0.6936.8894 EasyJTAG SPI Plugin ver:1.1.1.13 Android ADB API ver:2.0.0.0 FTDI API ver:3.2.4.0 LibUSB API ver:1.2.6.0 Visual C++ Runtime ver:10.0.30319.1 Setting box Pinout ... Box Drivers version: 10.0.18362.1 Z3X Card Serial : AAD3-6500 , ver: 22 Z3X Card Activation [JTAGPLUS] : ACTIVATED Z3X Card Activation [LG] : NOT ACTIVATED Z3X Card Activation [SAMS] : ACTIVATED Z3X Card Activation [JTAG] : ACTIVATED For more information press F1 to open local help or visit our wiki Found 2 serial devices COM3 USB\VID_1781&PID_AAAC&REV_0100&MI_00 USB Serial Device (COM3) COM1 ACPI\VEN_PNP&DEV_0501 Communications Port (COM1) Selected pinout: GEN2 ISP Pinout Change EasyJTAG Pinout OK Z3X EasyJtag Software ver. 3.7.0.11 UFS Socket Info. Serial: 0123CDF31E336EBBEE Description: EasyJTAG UFS Socket BGA-254 by EasyJTAG 11.01.20 Can't open link, Code: -56, Reason: BOX: Chip not connected Done. Z3X EasyJtag Software ver. 3.7.0.11 UFS Socket Info. Serial: 0123CDF31E336EBBEE Description: EasyJTAG UFS Socket BGA-254 by EasyJTAG 11.01.20 Can't open link, Code: -56, Reason: BOX: Chip not connected Done. When VCC is not connected on Chip Box Drivers version: 10.0.18362.1 Z3X Card Serial : AAD3-6500 , ver: 22 Z3X Card Activation [JTAGPLUS] : ACTIVATED Z3X Card Activation [LG] : NOT ACTIVATED Z3X Card Activation [SAMS] : ACTIVATED Z3X Card Activation [JTAG] : ACTIVATED For more information press F1 to open local help or visit our wiki Found 2 serial devices COM3 USB\VID_1781&PID_AAAC&REV_0100&MI_00 USB Serial Device (COM3) COM1 ACPI\VEN_PNP&DEV_0501 Communications Port (COM1) Selected pinout: GEN2 ISP Pinout Change EasyJTAG Pinout OK Z3X EasyJtag Software ver. 3.7.0.11 Can't open link, Code: -51, Reason: BOX: Socket not detected Done. Z3X EasyJtag Software ver. 3.7.0.11 Can't open link, Code: -51, Reason: BOX: Socket not detected Done. Z3X EasyJtag Software ver. 3.7.0.11 Can't open link, Code: -51, Reason: BOX: Socket not detected Done. This log is when I solder VCC to Chip, Then Socket is NOT Detected at all withn Easy Jtag Plus Box. My UFS BGA 254/ISP Socket is the Same as in the Images of the Above Posters Socket |
Link to UFS BGA24/ISP SOCKET : https://drive.google.com/drive/my-drive https://drive.google.com/drive/my-drive |
Still Not Working, ANY SOLUTION FROM EASY JTAG SUPPORT?? Found 2 serial devices COM3 USB\VID_1781&PID_AAAC&REV_0100&MI_00 USB Serial Device (COM3) COM1 ACPI\VEN_PNP&DEV_0501 Communications Port (COM1) Selected pinout: GEN2 ISP Pinout Change EasyJTAG Pinout OK Z3X EasyJtag Software ver. 3.7.0.11 UFS Socket Info. Serial: 0123CDF31E336EBBEE Description: EasyJTAG UFS Socket BGA-254 by EasyJTAG 11.01.20 Can't open link, Code: -56, Reason: BOX: Chip not connected Done. Z3X EasyJtag Software ver. 3.7.0.11 UFS Socket Info. Serial: 0123CDF31E336EBBEE Description: EasyJTAG UFS Socket BGA-254 by EasyJTAG 11.01.20 Can't open link, Code: -56, Reason: BOX: Chip not connected Done. Z3X EasyJtag Software ver. 3.7.0.11 UFS Socket Info. Serial: 0123CDF31E336EBBEE Description: EasyJTAG UFS Socket BGA-254 by EasyJTAG 11.01.20 Can't open link, Code: -56, Reason: BOX: Chip not connected Done. |
this link to owner (no you) drive |
And my case, Layder? |
Solved. Changed Conductor wire (enamelled). Code: Source: EasyJtag Port [UFS] |
please post pic Quote:
Got a Poblem with EasyJTAG and bga 254 Hello, i need some help, i have my box updated with the last firmware, and when i try to read a UFS Chip with EasyJtag Plus Suite i get the message UFS Init Failed, error: 0; what i read in other post is that i have to download an old version of Classic Suite and open it pressing the left ctrl key so if flash the box with an old firmware and then it works with the old classic suite, i need to make it work with the last easyjtag plus suite, can anybody please help me? this is obviously a firmware error. I bought this box and the bga254 adaptor and they weren't cheap, plus my customer is waiting for couple weeks |
Layder, what's wrong with my UFS BGA 254 ISP Socket I Still Can't detect Any Ufs Chip via ISP. Or is my Socket Faulty from factory |
