07-31-2020, 11:17 | #1 (permalink) |
No Life Poster Join Date: Sep 2006 Location: Allah is Greatest
Member: 358694 Status: Offline Sonork: 100.1597323 Thanks Meter: 994 | A260F not Detected Phone is complete on Setting interface to EasyJtag2/ISP_HiPower Setting bus width to 1 Bit HiPower mode is ON Setting frequence to 36 MHz CMD Pullup Level: 447 mV CMD Active Level: 1701 mV Can't init device. Reason: CMD Timeout Error |
08-01-2020, 09:34 | #2 (permalink) |
Product Supporter Join Date: Mar 2005 Location: China
Member: 129885 Status: Offline Sonork: 100:1603514 Thanks Meter: 6,202 | Hi , please provide a full log instead of parts. Did you attched USB power to phone PCB ? Try to use 2.8V IO and dont use HiPower mode. |
The Following User Says Thank You to NoName® For This Useful Post: |
08-04-2020, 17:35 | #3 (permalink) | |
Member: 358694 Status: Offline Sonork: 100.1597323 Thanks Meter: 994 | Quote:
eMMC_tool Suite ver. 1.6.3.0 (release date: 23.06.2020) Microsoft Windows 10 (64 bit) build 18362 (10.0.18362.959) Looking for EasyJTAG box... EasyJTAG API ver. 3401 EasyJTAG Box Serial = 55300000000 Card Serial = AA9C8FF8 EasyJTAG Box Firmware = 2.5204 Changelog: 23.06.2020 (ver 1.6.3.0) Fix: Bugs that have been found through your crash report Setting interface to EasyJtag2/ISP Setting bus width to 4 Bit Setting frequence to 4 MHz CMD Pullup Level: 474 mV CMD Active Level: 1605 mV Can't init device. Reason: OCR Ready Timeout Error [Check VCC or eMMC DEAD] I attached usb cable also but same.. and my phone is 100% working . i just want to remove kg locked | |
08-06-2020, 17:41 | #6 (permalink) |
Member: 358694 Status: Offline Sonork: 100.1597323 Thanks Meter: 994 | 8/6/2020 5:08:32 PM> Looking for EasyJTAG box... 8/6/2020 5:08:32 PM> EasyJTAG API ver. 3401 8/6/2020 5:08:32 PM> Setting IO Levels to 2.8V 8/6/2020 5:08:32 PM> Setting frequence to 36 MHz 8/6/2020 5:08:32 PM> EasyJTAG Box Serial = 55 8/6/2020 5:08:32 PM> EasyJTAG Box Firmware = 2.5204 8/6/2020 5:08:34 PM> Setting interface to EasyJtag2/ISP 8/6/2020 5:08:34 PM> Setting bus width to 1 Bit 8/6/2020 5:08:34 PM> Setting frequence to 36 MHz 8/6/2020 5:08:34 PM> CMD Pullup Level: 510 mV 8/6/2020 5:08:34 PM> CMD Active Level: 1621 mV 8/6/2020 5:08:34 PM> eMMC Init returned = 0 8/6/2020 5:08:34 PM> EMMC Device Information : 8/6/2020 5:08:34 PM> EMMC CID: 150100384754463452007639CA78C667 8/6/2020 5:08:34 PM> EMMC CSD: D02701320F5903FFF6DBFFEF8E40400D 8/6/2020 5:08:34 PM> EMMC Manufacture : SAMSUNG , EMMC NAME: 8GTF4R , HEX: 384754463452 , S/N: 7639CA78 , rev. 0x00 8/6/2020 5:08:34 PM> EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 12/2019 8/6/2020 5:08:34 PM> EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000) 8/6/2020 5:08:34 PM> EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) 8/6/2020 5:08:34 PM> EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 2 , Response: Not Clean 8/6/2020 5:08:34 PM> EMMC Permanent Write Protection: No 8/6/2020 5:08:34 PM> EMMC Temporary Write Protection: No 8/6/2020 5:08:34 PM> Extended CSD Information : 8/6/2020 5:08:34 PM> Extended CSD rev: 1.8 (MMC 5.1) 8/6/2020 5:08:34 PM> Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1) 8/6/2020 5:08:34 PM> Boot Bus Config: 0x01 , width 4bit 8/6/2020 5:08:34 PM> H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled 8/6/2020 5:08:34 PM> Supported partition features [PARTITIONING_SUPPORT]: 0x07 8/6/2020 5:08:34 PM> Device supports partitioning features 8/6/2020 5:08:34 PM> Device can have enhanced technological features in partitions and user data area 8/6/2020 5:08:34 PM> Device can have extended partitions attribute 8/6/2020 5:08:34 PM> Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 8/6/2020 5:08:34 PM> Backup saved: 8GTF4R_7639CA78_20200806_170834.extcsd 8/6/2020 5:08:34 PM> EMMC Init completed. 8/6/2020 5:08:34 PM> 8/6/2020 5:08:35 PM> Get firmware version 8/6/2020 5:08:35 PM> 8/6/2020 5:08:42 PM> Setting IO Levels to 2.8V 8/6/2020 5:08:50 PM> 8/6/2020 5:08:50 PM> Too many errors. Enabling ResetBox mode 8/6/2020 5:08:50 PM> 8/6/2020 5:08:56 PM> Error: Except: Mount [VENDOR] failed PartType: LINUX 8/6/2020 5:09:02 PM> Error: Except: Mount [ODM] failed PartType: LINUX 8/6/2020 5:09:09 PM> Error: Except: Mount [cache] failed PartType: LINUX 8/6/2020 5:09:15 PM> Error: Except: Mount [HIDDEN] failed PartType: LINUX 8/6/2020 5:09:22 PM> Error: Except: Mount [omr] failed PartType: LINUX 8/6/2020 5:09:47 PM> Error reading at address: 000000000000 , error: -1, CMD Timeout Error ... Retry #1 8/6/2020 5:09:53 PM> Error reading at address: 000000000000 , error: -1, CMD Timeout Error ... Retry #2 8/6/2020 5:10:00 PM> Error reading at address: 000000000000 , error: -1, CMD Timeout Error ... Retry #3 8/6/2020 5:10:06 PM> Error reading at address: 000000000000 , error: -1, CMD Timeout Error ... Retry #4 8/6/2020 5:10:12 PM> Error reading at address: 000000000000 , error: -1, CMD Timeout Error ... Retry #5 8/6/2020 5:10:19 PM> Too many errors. Reading has been stopped today i got another phone and it conected only once. then again same. i try with bit 1 and low frequescy and with usb cable and with 2.8 but same.. someone told me i should modified my addapter. is it true Last edited by alamgarh; 08-06-2020 at 17:46. |
08-07-2020, 19:55 | #7 (permalink) |
Member: 358694 Status: Offline Sonork: 100.1597323 Thanks Meter: 994 | Can I say A260F is not supported..... Or what... Because I didn't even see a single report of A260F One if my friend suggested me UFI... But I don't want to spend too much money only because of one phone.. I hope easy jtag team will give us a way to solve this problem.. Another thing I want to make sure.. When I try to connect phone after that phone doesn't power on.. Then I change the CLK and CMD resistor and it becomes on.. Today I got same situation.. I try to connect another phone and after trying now phone is again dead not power on... Why it's happining like this... Should I change resistors again.. |
08-07-2020, 20:53 | #8 (permalink) |
No Life Poster Join Date: Mar 2018 Location: Future.... ✌️
Member: 2825953 Status: Offline Thanks Meter: 246 | I have the same problem, the A260F phone is Hard lock by Operator cannot flash any Combination or Any Official Firmware. 8/4/2020 10:19:21 PM> Looking for EasyJTAG box... 8/4/2020 10:19:21 PM> EasyJTAG API ver. 3401 8/4/2020 10:19:22 PM> OpenUSB returned = 0 8/4/2020 10:19:22 PM> EasyJTAG Box Serial = F6F272D292237F2E 8/4/2020 10:19:24 PM> Card Serial = AA2778BA 8/4/2020 10:19:24 PM> EasyJTAG Box Firmware = 2.5204 8/4/2020 10:19:24 PM> 8/4/2020 10:32:48 PM> Looking for EasyJTAG box... 8/4/2020 10:32:48 PM> EasyJTAG API ver. 3401 8/4/2020 10:32:48 PM> Setting IO Levels to 1.8V 8/4/2020 10:32:48 PM> Setting frequence to 1 MHz 8/4/2020 10:32:48 PM> EasyJTAG Box Serial = F6F272D292237F2E 8/4/2020 10:32:48 PM> EasyJTAG Box Firmware = 2.5204 8/4/2020 10:32:49 PM> Setting interface to EasyJtag2/ISP 8/4/2020 10:32:50 PM> Setting bus width to 1 Bit 8/4/2020 10:32:50 PM> Setting frequence to 1 MHz 8/4/2020 10:32:50 PM> CMD Pullup Level: 466 mV 8/4/2020 10:32:50 PM> CMD Active Level: 1201 mV 8/4/2020 10:32:50 PM> eMMC Init returned = 0 8/4/2020 10:32:50 PM> EMMC Device Information : 8/4/2020 10:32:50 PM> EMMC CID: 150100384754463452004DBDFAAEC6EB 8/4/2020 10:32:50 PM> EMMC CSD: D02701320F5903FFF6DBFFEF8E40400D 8/4/2020 10:32:50 PM> EMMC Manufacture : SAMSUNG , EMMC NAME: 8GTF4R , HEX: 384754463452 , S/N: 4DBDFAAE , rev. 0x00 8/4/2020 10:32:50 PM> EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 12/2019 8/4/2020 10:32:50 PM> EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000) 8/4/2020 10:32:50 PM> EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) 8/4/2020 10:32:50 PM> EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 2 , Response: Not Clean 8/4/2020 10:32:50 PM> EMMC Permanent Write Protection: No 8/4/2020 10:32:50 PM> EMMC Temporary Write Protection: No 8/4/2020 10:32:50 PM> Extended CSD Information : 8/4/2020 10:32:50 PM> Extended CSD rev: 1.8 (MMC 5.1) 8/4/2020 10:32:50 PM> Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1) 8/4/2020 10:32:50 PM> Boot Bus Config: 0x01 , width 4bit 8/4/2020 10:32:50 PM> H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled 8/4/2020 10:32:50 PM> Supported partition features [PARTITIONING_SUPPORT]: 0x07 8/4/2020 10:32:50 PM> Device supports partitioning features 8/4/2020 10:32:50 PM> Device can have enhanced technological features in partitions and user data area 8/4/2020 10:32:50 PM> Device can have extended partitions attribute 8/4/2020 10:32:50 PM> Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 8/4/2020 10:32:50 PM> Backup saved: 8GTF4R_4DBDFAAE_20200804_223250.extcsd 8/4/2020 10:32:50 PM> EMMC Init completed. 8/4/2020 10:32:50 PM> 8/4/2020 10:32:50 PM> Operation: Find table from emmc 8/4/2020 10:32:50 PM> 8/4/2020 10:32:50 PM> Vendor: Samsung 8/4/2020 10:32:50 PM> Searching GPT ... 8/4/2020 10:32:50 PM> GPT header is found and is valid 8/4/2020 10:32:50 PM> Checking for ROM2 ... 8/4/2020 10:33:01 PM> Error reading at address: 000000000000 , error: -3, DATA RCV Timeout Error ... Retry #1 8/4/2020 10:33:01 PM> Error result: -3 8/4/2020 10:33:02 PM> ROM2 is not blank 8/4/2020 10:33:02 PM> Checking for ROM3 ... 8/4/2020 10:33:13 PM> Error reading at address: 000000000000 , error: -3, DATA RCV Timeout Error ... Retry #1 8/4/2020 10:33:13 PM> Error result: -3 8/4/2020 10:33:14 PM> ROM3 is not blank 8/4/2020 10:33:14 PM> GPT header successfully parsed 8/4/2020 10:33:14 PM> 8/4/2020 10:33:14 PM> EFS backup is performed. Please wait... 8/4/2020 10:34:31 PM> Setting IO Levels to 1.8V 8/4/2020 10:34:33 PM> 8/4/2020 10:34:33 PM> Too many errors. Enabling ResetBox mode 8/4/2020 10:34:33 PM> 8/4/2020 10:34:44 PM> Exception: read_dir/ext_dir_open: [system/] 8/4/2020 10:34:55 PM> Exception: read_dir/get_inode: [efs/recovery] 8/4/2020 10:35:06 PM> Exception: read_dir/get_inode: [efs/FactoryApp/batt_after_manufactured] 8/4/2020 10:35:17 PM> Exception: read_dir/ext_dir_open: [system/] 8/4/2020 10:35:28 PM> Error reading at address: 000000C00000 , error: -3, DATA RCV Timeout Error ... Retry #1 8/4/2020 10:35:28 PM> Error result: -3 8/4/2020 10:35:39 PM> Error reading at address: 000000C00000 , error: -3, DATA RCV Timeout Error ... Retry #2 8/4/2020 10:35:39 PM> Error result: -3 8/4/2020 10:35:50 PM> Error reading at address: 000000C00000 , error: -3, DATA RCV Timeout Error ... Retry #3 8/4/2020 10:35:50 PM> Error result: -3 8/4/2020 10:36:02 PM> Too many errors. Reading has been stopped 8/4/2020 10:36:02 PM> Try the "Skip unreadable blocks" option 8/4/2020 10:36:02 PM> |
08-12-2020, 22:52 | #11 (permalink) |
Crazy Poster Join Date: Jul 2015 Location: Future Age: 29
Member: 2425358 Status: Offline Thanks Meter: 53 | Ur kg state is locked, u won't b able to flash anything bia odin since knox guard doesn't allow, For connection issue, jumpers should not longer more than 6cm.. connect ,give proper power , and set frequency to lowest,ie 9mhz or lower, it wil detect.. try different voltage with low freq.. i did with A307fn Sent from my vivo 1919 using Tapatalk |
The Following User Says Thank You to amaronX For This Useful Post: |
08-13-2020, 06:01 | #12 (permalink) | |
Can you help send me a picture of your connection please... | |
