07-07-2020, 05:08 | #1 (permalink) |
No Life Poster Join Date: Oct 2007 Location: Colombia
Member: 614683 Status: Offline Sonork: 100.1605379 Thanks Meter: 370 | EasyJTAG Classic 3.7.0.11 ISP connect problems bad update, this update is killing all isp connection |
07-07-2020, 06:45 | #3 (permalink) | |
Product Supporter Join Date: Jun 2002 Location: Belarus Age: 47
Member: 13148 Status: Offline Thanks Meter: 2,948 | Quote:
2) code of eMMC ISP connection not be changed at last 5-10 updates We add only new UFS core | |
The Following User Says Thank You to layder For This Useful Post: |
07-07-2020, 08:29 | #5 (permalink) | |
Member: 614683 Status: Offline Sonork: 100.1605379 Thanks Meter: 370 | Quote:
Other box detect phone normal but easy jtag, after update not. Something bad must have happened with that update, after that there have been a lot of isp problems in ufs and emmc. They should try to fix it and help the user Last edited by layder; 07-07-2020 at 09:25. Reason: merge posts | |
07-07-2020, 09:31 | #6 (permalink) | |
post it, please | |
07-07-2020, 09:53 | #7 (permalink) | |
Selected pinout: GEN2 ISP Pinout Change EasyJTAG Pinout OK Z3X EasyJtag Software ver. 3.6.2.3 Loading eMMC GEN2 Firmware... IO: 2800 mV Box S/N: 2EA1BDxxxxx, ,FW Ver.: 02.50 CMD Pullup Level:955 mV CMD Active Level:2443 mV Box IO Level:2800 mV CLK Rate:12000 kHz Bus Width:1bit,SDR HiPower mode is off! ---------- eMMC Device Information ---------- eMMC CID : 90014A68433861503001A1D1D0CEB669 eMMC CSD : D02700328F5903FFFFFFFFEF8E400043 eMMC Manufacturer ID: 0090 , OEM ID: 014A eMMC Date: 11/2019 Rev.0x1 eMMC NAME: hC8aP0 , S/N: 2714882254 eMMC NAME (HEX): 684338615030 EMMC ROM1 (Main User Data) Capacity: 59640 MB , 0x747C000 pages , 0xE8F800000 bytes EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 kB EMMC RPMB is programmed and written 1146 times EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x01 , width 4bits , Partition config [179]: 0x48. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: hC8aP0_2714882254_20200626_1237.extcsd ============================================= Extended CSD rev 1.8 (MMC 5.1) ============================================= Card Supported Command sets [S_CMD_SET: 0x01] HPI Features [HPI_FEATURE: 0x01]: implementation based on CMD13 Background operations support [BKOPS_SUPPORT: 0x01] Max Packet Read Cmd [MAX_PACKED_READS: 0x3f] Max Packet Write Cmd [MAX_PACKED_WRITES: 0x3f] Data TAG support [DATA_TAG_SUPPORT: 0x01] Data TAG Unit Size [TAG_UNIT_SIZE: 0x03] Tag Resources Size [TAG_RES_SIZE: 0x00] Context Management Capabilities [CONTEXT_CAPABILITIES: 0x05] Large Unit Size [LARGE_UNIT_SIZE_M1: 0x01] Extended partition attribute support [EXT_SUPPORT: 0x03] Generic CMD6 Timer [GENERIC_CMD6_TIME: 0x0a] Power off notification [POWER_OFF_LONG_TIME: 0x3c] Cache Size [CACHE_SIZE] is 2048 KiB ------------------------- eMMC v5+ ------------------------- Supported modes [SUPPORTED_MODES: 0x01] FFU features [FFU_FEATURES: 0x00] Operation codes timeout [OPERATION_CODE_TIMEOUT: 0x00] FFU Argument [FFU_ARG: 0xfffafff0] Number of FW sectors correctly programmed[NUM_OF_FW_SECT_CORR_PROG: 0] Vendor proprietary health report: [VENDOR_PROPRIETARY_HEALTH_REPORT[301]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[300]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[299]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[298]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[297]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[296]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[295]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[294]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[293]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[292]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[291]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[290]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[289]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[288]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[287]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[286]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[285]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[284]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[283]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[282]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[281]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[280]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[279]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[278]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[277]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[276]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[275]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[274]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[273]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[272]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[271]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[270]]:0x00 _(Device life time estimation type B [DEVICE_LIFE_TIME_EST_TYP_B: 0x01] i.e. 0% - 10% device life time used _(Device life time estimation type B [DEVICE_LIFE_TIME_EST_TYP_A: 0x00] Pre EOL information [PRE_EOL_INFO: 0x01] i.e. Normal Optimal read size [OPTIMAL_READ_SIZE: 0x20] Optimal write size [OPTIMAL_WRITE_SIZE: 0x20] Optimal trim unit size [OPTIMAL_TRIM_UNIT_SIZE: 0x01] Device version [DEVICE_VERSION: 0x43 - 0x0e] Firmware version: [FIRMWARE_VERSION[261]]: 0x00 [FIRMWARE_VERSION[260]]: 0x00 [FIRMWARE_VERSION[259]]: 0x00 [FIRMWARE_VERSION[258]]: 0x00 [FIRMWARE_VERSION[257]]: 0x32 [FIRMWARE_VERSION[256]]: 0x30 [FIRMWARE_VERSION[255]]: 0x30 [FIRMWARE_VERSION[254]]: 0x30 Power class for 200MHz, DDR at VCC= 3.6V [PWR_CL_DDR_200_360: 0x04] ------------------------------------------------------------- Generic CMD6 Timer [GENERIC_CMD6_TIME: 0x0a] Power off notification [POWER_OFF_LONG_TIME: 0x3c] Cache Size [CACHE_SIZE] is 2048 KiB Background operations status [BKOPS_STATUS: 0x00] 1st Initialisation Time after programmed sector [INI_TIMEOUT_AP: 0x0a] Power class for 52MHz, DDR at 3.6V [PWR_CL_DDR_52_360: 0x00] Power class for 52MHz, DDR at 1.95V [PWR_CL_DDR_52_195: 0x00] Power class for 200MHz at 3.6V [PWR_CL_200_360: 0x00] Power class for 200MHz, at 1.95V [PWR_CL_200_195: 0x00] Minimum Performance for 8bit at 52MHz in DDR mode: [MIN_PERF_DDR_W_8_52: 0x00] [MIN_PERF_DDR_R_8_52: 0x00] TRIM Multiplier [TRIM_MULT: 0x02] Secure Feature support [SEC_FEATURE_SUPPORT: 0x55] Boot Information [BOOT_INFO: 0x07] Device supports alternative boot method Device supports dual data rate during boot Device supports high speed timing during boot Boot partition size [BOOT_SIZE_MULTI: 0x20] Access size [ACC_SIZE: 0x07] High-capacity erase unit size [HC_ERASE_GRP_SIZE: 0x01] High-capacity erase timeout [ERASE_TIMEOUT_MULT: 0x02] Reliable write sector count [REL_WR_SEC_C: 0x01] High-capacity W protect group size [HC_WP_GRP_SIZE: 0x10] Sleep current (VCC) [S_C_VCC: 0x08] Sleep current (VCCQ) [S_C_VCCQ: 0x09] Sleep/awake timeout [S_A_TIMEOUT: 0x15] Sector Count [SEC_COUNT: 0x0747c000] Minimum Write Performance for 8bit: [MIN_PERF_W_8_52: 0x8c] [MIN_PERF_R_8_52: 0x8c] [MIN_PERF_W_8_26_4_52: 0x46] [MIN_PERF_R_8_26_4_52: 0x46] Minimum Write Performance for 4bit: [MIN_PERF_W_4_26: 0x1e] [MIN_PERF_R_4_26: 0x1e] Power classes registers: [PWR_CL_26_360: 0x00] [PWR_CL_52_360: 0x00] [PWR_CL_26_195: 0x00] [PWR_CL_52_195: 0x00] Partition switching timing [PARTITION_SWITCH_TIME: 0x01] Out-of-interrupt busy timing [OUT_OF_INTERRUPT_TIME: 0x0a] I/O Driver Strength [DRIVER_STRENGTH: 0x01] Card Type [CARD_TYPE: 0x57] CSD structure version [CSD_STRUCTURE: 0x02] Command set [CMD_SET: 0x00] Command set revision [CMD_SET_REV: 0x00] Power class [POWER_CLASS: 0x00] High-speed interface timing [HS_TIMING: 0x00] Erased memory content [ERASED_MEM_CONT: 0x00] Boot configuration bytes [PARTITION_CONFIG: 0x48] No access to boot partition Boot config protection [BOOT_CONFIG_PROT: 0x00] Boot bus Conditions [BOOT_BUS_CONDITIONS: 0x01] High-density erase group definition [ERASE_GROUP_DEF: 0x00] Boot write protection status registers [BOOT_WP_STATUS]: 0x00 Boot Area Write protection [BOOT_WP]: 0x00 Power ReadOnly locking: possible Permanent ReadOnly locking: possible Read Only lock status: not locked User area write protection register [USER_WP]: 0x10 FW configuration [FW_CONFIG]: 0x00 RPMB Size [RPMB_SIZE_MULT]: 0x80 Write reliability setting register [WR_REL_SET]: 0x1f Write reliability parameter register [WR_REL_PARAM]: 0x15 Enable background operations handshake [BKOPS_EN]: 0x00 H/W reset function [RST_N_FUNCTION]: 0x01 HPI management [HPI_MGMT]: 0x00 Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Max Enhanced Area Size [MAX_ENH_SIZE_MULT]: 0x000e8f Partitions attribute [PARTITIONS_ATTRIBUTE]: 0x00 Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 General Purpose Partition Size [GP_SIZE_MULT_4]: 0x000000 [GP_SIZE_MULT_3]: 0x000000 [GP_SIZE_MULT_2]: 0x000000 [GP_SIZE_MULT_1]: 0x000000 Enhanced User Data Area Size [ENH_SIZE_MULT]: 0x000000 Enhanced User Data Start Address [ENH_START_ADDR]: 0x000000 Bad Block Management mode [SEC_BAD_BLK_MGMNT]: 0x00 Periodic Wake-up [PERIODIC_WAKEUP]: 0x00 Program CID/CSD in DDR mode support [PROGRAM_CID_CSD_DDR_SUPPORT]: 0x01 Native sector size [NATIVE_SECTOR_SIZE]: 0x01 Sector size emulation [USE_NATIVE_SECTOR]: 0x00 Sector size [DATA_SECTOR_SIZE]: 0x00 1st initialization after disabling sector size emulation [INI_TIMEOUT_EMU]: 0x0a Class 6 commands control [CLASS_6_CTRL]: 0x00 Number of addressed group to be released[DYNCAP_NEEDED]: 0x00 Exception events control [EXCEPTION_EVENTS_CTRL]: 0x0000 Exception events status [EXCEPTION_EVENTS_STATUS]: 0x0000 Extended Partitions Attribute [EXT_PARTITIONS_ATTRIBUTE]: 0x0000 Packed command status [PACKED_COMMAND_STATUS]: 0x00 Packed command failure index [PACKED_FAILURE_INDEX]: 0x00 Power Off Notification [POWER_OFF_NOTIFICATION]: 0x00 Control to turn the Cache ON/OFF [CACHE_CTRL]: 0x00 Partition info successfully found ------ Android information ------ Detected LINUX(Android) SYSTEM : 0x0011000000 (4.687GB) Short EXT fs info: Size: 4.613GB Block size: 4.0KB Inode size: 256 Inodes: 302512 Short Android info: Unable to read prop.plist , code : 2 Backup saved: BuildProp_20200626_1237.txt --------------------------------------------- Detected USERDATA USERDATA : 0x019A300000 (51.828GB) Blocks Reading Error (0x19A300400 , 2 , Reason: DATA RCV Timeout Error ) Unable to mount USERDATA , code : 5 Userdata Superblock contents:: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 ................................; 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 ................................; 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 ................................; 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 ................................; 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 ................................; 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 ................................; 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 ................................; 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 ................................; Done. Checking security ... Running:Format FRP Partition... Z3X EasyJtag Software ver. 3.6.2.3 Loading eMMC GEN2 Firmware... IO: 2800 mV Box S/N: 2EA1BDB9B5F74404, ,FW Ver.: 02.50 CMD Pullup Level:463 mV CMD Active Level:2463 mV Box IO Level:2800 mV CLK Rate:12000 kHz Bus Width:1bit,SDR HiPower mode is off! ---------- eMMC Device Information ---------- eMMC CID : 90014A68433861503001A1D1D0CEB669 eMMC CSD : D02700328F5903FFFFFFFFEF8E400043 eMMC Manufacturer ID: 0090 , OEM ID: 014A eMMC Date: 11/2019 Rev.0x1 eMMC NAME: hC8aP0 , S/N: 2714882254 eMMC NAME (HEX): 684338615030 EMMC ROM1 (Main User Data) Capacity: 59640 MB , 0x747C000 pages , 0xE8F800000 bytes EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 kB EMMC RPMB is programmed and written 1146 times EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x01 , width 4bits , Partition config [179]: 0x48. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Partition info successfully found Formatting FRP... Detected LINUX(Android) PERSISTENT : 0x0010500000 (512.0KB) formatting... Done. Detected LINUX(Android) CACHE : 0x0189000000 (200.0MB) , formatting... Done. Detected LINUX(Android) USERDATA : 0x019A300000 (51.828GB) , formatting... Done. Done. Done. Checking security ... Running:Format FRP Partition... Z3X EasyJtag Software ver. 3.6.2.3 Loading eMMC GEN2 Firmware... IO: 2800 mV Box S/N: 2EA1BDB9B5F74404, ,FW Ver.: 02.50 CMD Pullup Level:465 mV CMD Active Level:2462 mV Box IO Level:2800 mV CLK Rate:12000 kHz Bus Width:1bit,SDR HiPower mode is off! ---------- eMMC Device Information ---------- eMMC CID : 90014A68433861503001A1D1D0CEB669 eMMC CSD : D02700328F5903FFFFFFFFEF8E400043 eMMC Manufacturer ID: 0090 , OEM ID: 014A eMMC Date: 11/2019 Rev.0x1 eMMC NAME: hC8aP0 , S/N: 2714882254 eMMC NAME (HEX): 684338615030 EMMC ROM1 (Main User Data) Capacity: 59640 MB , 0x747C000 pages , 0xE8F800000 bytes EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 kB EMMC RPMB is programmed and written 1146 times EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x01 , width 4bits , Partition config [179]: 0x48. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Partition info successfully found Formatting FRP... Detected LINUX(Android) CACHE : 0x0189000000 (200.0MB) , formatting... Done. Detected LINUX(Android) USERDATA : 0x019A300000 (51.828GB) , formatting... Done. Done. Done. Checking security ... Running:Format FRP Partition... Z3X EasyJtag Software ver. 3.6.2.3 Loading eMMC GEN2 Firmware... IO: 2800 mV Box S/N: 2EA1BDB9B5F74404, ,FW Ver.: 02.50 CMD Pullup Level:463 mV CMD Active Level:2462 mV Box IO Level:2800 mV CLK Rate:12000 kHz Bus Width:1bit,SDR HiPower mode is off! ---------- eMMC Device Information ---------- eMMC CID : 90014A68433861503001A1D1D0CEB669 eMMC CSD : D02700328F5903FFFFFFFFEF8E400043 eMMC Manufacturer ID: 0090 , OEM ID: 014A eMMC Date: 11/2019 Rev.0x1 eMMC NAME: hC8aP0 , S/N: 2714882254 eMMC NAME (HEX): 684338615030 EMMC ROM1 (Main User Data) Capacity: 59640 MB , 0x747C000 pages , 0xE8F800000 bytes EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 kB EMMC RPMB is programmed and written 1146 times EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x01 , width 4bits , Partition config [179]: 0x48. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Partition info successfully found Formatting FRP... Detected LINUX(Android) CACHE : 0x0189000000 (200.0MB) , formatting... Done. Detected LINUX(Android) USERDATA : 0x019A300000 (51.828GB) , formatting... Done. Done. Done. ------ Detected 32 partitions ------ P0 (BOTA0) [0x400000 0x400000] Size: 4.0MB P1 (BOTA1) [0x800000 0x800000] Size: 8.0MB P2 (EFS) [0x1000000 0x1400000] Size: 20.0MB P3 (SEC_EFS) [0x2400000 0x1400000] Size: 20.0MB P4 (CPEFS) [0x3800000 0x800000] Size: 8.0MB P5 (BOTA2) [0x4000000 0x800000] Size: 8.0MB P6 (CM) [0x4800000 0x800000] Size: 8.0MB P7 (M9KEFS1) [0x5000000 0x400000] Size: 4.0MB P8 (M9KEFS2) [0x5400000 0x400000] Size: 4.0MB P9 (M9KEFS3) [0x5800000 0x400000] Size: 4.0MB P10 (NAD_REFER) [0x5c00000 0x100000] Size: 1.0MB P11 (PARAM) [0x5d00000 0x800000] Size: 8.0MB P12 (UP_PARAM) [0x6500000 0x800000] Size: 8.0MB P13 (MISC) [0x6d00000 0x200000] Size: 2.0MB P14 (BOOT) [0x6f00000 0x2400000] Size: 36.0MB P15 (RECOVERY) [0x9300000 0x3500000] Size: 53.0MB P16 (DTB) [0xc800000 0x800000] Size: 8.0MB P17 (DTBO) [0xd000000 0x800000] Size: 8.0MB P18 (RADIO) [0xd800000 0x2d00000] Size: 45.0MB P19 (PERSISTENT) [0x10500000 0x80000] Size: 512.0KB P20 (STEADY) [0x10580000 0x400000] Size: 4.0MB P21 (VBMETA) [0x10980000 0x80000] Size: 512.0KB P22 (BOTA3) [0x10a00000 0x80000] Size: 512.0KB P23 (RESERVED2) [0x10a80000 0x580000] Size: 5.500MB P24 (SYSTEM) [0x11000000 0x12c000000] Size: 4.687GB P25 (VENDOR) [0x13d000000 0x26800000] Size: 616.0MB P26 (PRODUCT) [0x163800000 0x25800000] Size: 600.0MB P27 (CACHE) [0x189000000 0xc800000] Size: 200.0MB P28 (OMR) [0x195800000 0x3200000] Size: 50.0MB P29 (CP_DEBUG) [0x198a00000 0x500000] Size: 5.0MB P30 (NAD_FW) [0x198f00000 0x1400000] Size: 20.0MB P31 (USERDATA) [0x19a300000 0xcf5000000] Size: 51.828GB ------------------------------------ Checking security ... Z3X EasyJtag Software ver. 3.6.2.3 Skip loading eMMC Addon Firmware CMD Pullup Level:471 mV CMD Active Level:2453 mV Box IO Level:2800 mV CLK Rate:12000 kHz Bus Width:1bit,SDR Erasing 00800000 bytes from 05D00000 ...ROM1 Erase Done. Checking security ... Z3X EasyJtag Software ver. 3.6.2.3 Skip loading eMMC Addon Firmware CMD Pullup Level:469 mV CMD Active Level:2452 mV Box IO Level:2800 mV CLK Rate:12000 kHz Bus Width:1bit,SDR Erasing 02400000 bytes from 06F00000 ...ROM1 Erase Done. Checking security ... Z3X EasyJtag Software ver. 3.6.2.3 Skip loading eMMC Addon Firmware CMD Pullup Level:471 mV CMD Active Level:2454 mV Box IO Level:2800 mV CLK Rate:12000 kHz Bus Width:1bit,SDR Erasing 00400000 bytes from 10580000 ...ROM1 Erase Done. ------ Detected 32 partitions ------ P0 (BOTA0) [0x400000 0x400000] Size: 4.0MB P1 (BOTA1) [0x800000 0x800000] Size: 8.0MB P2 (EFS) [0x1000000 0x1400000] Size: 20.0MB P3 (SEC_EFS) [0x2400000 0x1400000] Size: 20.0MB P4 (CPEFS) [0x3800000 0x800000] Size: 8.0MB P5 (BOTA2) [0x4000000 0x800000] Size: 8.0MB P6 (CM) [0x4800000 0x800000] Size: 8.0MB P7 (M9KEFS1) [0x5000000 0x400000] Size: 4.0MB P8 (M9KEFS2) [0x5400000 0x400000] Size: 4.0MB P9 (M9KEFS3) [0x5800000 0x400000] Size: 4.0MB P10 (NAD_REFER) [0x5c00000 0x100000] Size: 1.0MB P11 (PARAM) [0x5d00000 0x800000] Size: 8.0MB P12 (UP_PARAM) [0x6500000 0x800000] Size: 8.0MB P13 (MISC) [0x6d00000 0x200000] Size: 2.0MB P14 (BOOT) [0x6f00000 0x2400000] Size: 36.0MB P15 (RECOVERY) [0x9300000 0x3500000] Size: 53.0MB P16 (DTB) [0xc800000 0x800000] Size: 8.0MB P17 (DTBO) [0xd000000 0x800000] Size: 8.0MB P18 (RADIO) [0xd800000 0x2d00000] Size: 45.0MB P19 (PERSISTENT) [0x10500000 0x80000] Size: 512.0KB P20 (STEADY) [0x10580000 0x400000] Size: 4.0MB P21 (VBMETA) [0x10980000 0x80000] Size: 512.0KB P22 (BOTA3) [0x10a00000 0x80000] Size: 512.0KB P23 (RESERVED2) [0x10a80000 0x580000] Size: 5.500MB P24 (SYSTEM) [0x11000000 0x12c000000] Size: 4.687GB P25 (VENDOR) [0x13d000000 0x26800000] Size: 616.0MB P26 (PRODUCT) [0x163800000 0x25800000] Size: 600.0MB P27 (CACHE) [0x189000000 0xc800000] Size: 200.0MB P28 (OMR) [0x195800000 0x3200000] Size: 50.0MB P29 (CP_DEBUG) [0x198a00000 0x500000] Size: 5.0MB P30 (NAD_FW) [0x198f00000 0x1400000] Size: 20.0MB P31 (USERDATA) [0x19a300000 0xcf5000000] Size: 51.828GB ------------------------------------ Checking security ... Z3X EasyJtag Software ver. 3.6.2.3 Skip loading eMMC Addon Firmware CMD Pullup Level:469 mV CMD Active Level:2454 mV Box IO Level:2800 mV CLK Rate:12000 kHz Bus Width:1bit,SDR Erasing 00800000 bytes from 05D00000 ...ROM1 Erase Done. Checking security ... Z3X EasyJtag Software ver. 3.6.2.3 Skip loading eMMC Addon Firmware CMD Pullup Level:469 mV CMD Active Level:2452 mV Box IO Level:2800 mV CLK Rate:12000 kHz Bus Width:1bit,SDR Erasing 02400000 bytes from 06F00000 ...ROM1 Erase Done. Checking security ... Z3X EasyJtag Software ver. 3.6.2.3 Skip loading eMMC Addon Firmware CMD Pullup Level:471 mV CMD Active Level:2454 mV Box IO Level:2800 mV CLK Rate:12000 kHz Bus Width:1bit,SDR Erasing 00400000 bytes from 10580000 ...ROM1 Erase Done. ------ Detected 32 partitions ------ P0 (BOTA0) [0x400000 0x400000] Size: 4.0MB P1 (BOTA1) [0x800000 0x800000] Size: 8.0MB P2 (EFS) [0x1000000 0x1400000] Size: 20.0MB P3 (SEC_EFS) [0x2400000 0x1400000] Size: 20.0MB P4 (CPEFS) [0x3800000 0x800000] Size: 8.0MB P5 (BOTA2) [0x4000000 0x800000] Size: 8.0MB P6 (CM) [0x4800000 0x800000] Size: 8.0MB P7 (M9KEFS1) [0x5000000 0x400000] Size: 4.0MB P8 (M9KEFS2) [0x5400000 0x400000] Size: 4.0MB P9 (M9KEFS3) [0x5800000 0x400000] Size: 4.0MB P10 (NAD_REFER) [0x5c00000 0x100000] Size: 1.0MB P11 (PARAM) [0x5d00000 0x800000] Size: 8.0MB P12 (UP_PARAM) [0x6500000 0x800000] Size: 8.0MB P13 (MISC) [0x6d00000 0x200000] Size: 2.0MB P14 (BOOT) [0x6f00000 0x2400000] Size: 36.0MB P15 (RECOVERY) [0x9300000 0x3500000] Size: 53.0MB P16 (DTB) [0xc800000 0x800000] Size: 8.0MB P17 (DTBO) [0xd000000 0x800000] Size: 8.0MB P18 (RADIO) [0xd800000 0x2d00000] Size: 45.0MB P19 (PERSISTENT) [0x10500000 0x80000] Size: 512.0KB P20 (STEADY) [0x10580000 0x400000] Size: 4.0MB P21 (VBMETA) [0x10980000 0x80000] Size: 512.0KB P22 (BOTA3) [0x10a00000 0x80000] Size: 512.0KB P23 (RESERVED2) [0x10a80000 0x580000] Size: 5.500MB P24 (SYSTEM) [0x11000000 0x12c000000] Size: 4.687GB P25 (VENDOR) [0x13d000000 0x26800000] Size: 616.0MB P26 (PRODUCT) [0x163800000 0x25800000] Size: 600.0MB P27 (CACHE) [0x189000000 0xc800000] Size: 200.0MB P28 (OMR) [0x195800000 0x3200000] Size: 50.0MB P29 (CP_DEBUG) [0x198a00000 0x500000] Size: 5.0MB P30 (NAD_FW) [0x198f00000 0x1400000] Size: 20.0MB P31 (USERDATA) [0x19a300000 0xcf5000000] Size: 51.828GB ------------------------------------ Selected pinout: GEN2 ISP Pinout Change EasyJTAG Pinout OK Selected pinout: GEN2 High Speed Pinout Change EasyJTAG Pinout OK Selected pinout: GEN2 High Speed Pinout Change EasyJTAG Pinout OK Z3X EasyJtag Software ver. 3.6.2.3 Loading eMMC GEN2 Firmware... IO: 2800 mV Initial pull results: clock: 1652mV pin connected ok command: 1656mV pin connected ok data0: 1661mV pin connected ok data1: 1660mV pin connected ok data2: 1663mV pin connected ok data3: 1666mV pin connected ok data4: 1665mV pin connected ok data5: 1660mV pin connected ok data6: 1666mV pin connected ok data7: 1663mV pin connected ok Box S/N: 2EA1BDB9B5F74404, ,FW Ver.: 02.50 Box IO Level:2800 mV CLK Rate:42000 kHz Bus Width:8bit,SDR HiPower mode is off! ---------- eMMC Device Information ---------- eMMC CID : 150100435554413432004605C06D568B eMMC CSD : D02701320F5903FFF6DBFFEF8E40400D eMMC Manufacturer ID: 0015 , OEM ID: 0100 eMMC Date: 05/2019 Rev.0x0 eMMC NAME: CUTA42 , S/N: 1174782061 eMMC NAME (HEX): 435554413432 EMMC ROM1 (Main User Data) Capacity: 59640 MB , 0x747C000 pages , 0xE8F800000 bytes EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 kB EMMC RPMB is programmed and written 2945 times EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x01 , width 4bits , Partition config [179]: 0x48. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: CUTA42_1174782061_20200618_0058.extcsd ============================================= Extended CSD rev 1.8 (MMC 5.1) ============================================= Card Supported Command sets [S_CMD_SET: 0x01] HPI Features [HPI_FEATURE: 0x01]: implementation based on CMD13 Background operations support [BKOPS_SUPPORT: 0x01] Max Packet Read Cmd [MAX_PACKED_READS: 0x3f] Max Packet Write Cmd [MAX_PACKED_WRITES: 0x3f] Data TAG support [DATA_TAG_SUPPORT: 0x01] Data TAG Unit Size [TAG_UNIT_SIZE: 0x03] Tag Resources Size [TAG_RES_SIZE: 0x00] Context Management Capabilities [CONTEXT_CAPABILITIES: 0x05] Large Unit Size [LARGE_UNIT_SIZE_M1: 0x07] Extended partition attribute support [EXT_SUPPORT: 0x03] Generic CMD6 Timer [GENERIC_CMD6_TIME: 0x0a] Power off notification [POWER_OFF_LONG_TIME: 0x3c] Cache Size [CACHE_SIZE] is 65536 KiB ------------------------- eMMC v5+ ------------------------- Supported modes [SUPPORTED_MODES: 0x03] FFU features [FFU_FEATURES: 0x00] Operation codes timeout [OPERATION_CODE_TIMEOUT: 0x00] FFU Argument [FFU_ARG: 0xc7810000] Number of FW sectors correctly programmed[NUM_OF_FW_SECT_CORR_PROG: 0] Vendor proprietary health report: [VENDOR_PROPRIETARY_HEALTH_REPORT[301]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[300]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[299]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[298]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[297]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[296]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[295]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[294]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[293]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[292]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[291]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[290]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[289]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[288]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[287]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[286]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[285]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[284]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[283]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[282]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[281]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[280]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[279]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[278]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[277]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[276]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[275]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[274]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[273]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[272]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[271]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[270]]:0x00 _(Device life time estimation type B [DEVICE_LIFE_TIME_EST_TYP_B: 0x01] i.e. 0% - 10% device life time used _(Device life time estimation type B [DEVICE_LIFE_TIME_EST_TYP_A: 0x01] i.e. 0% - 10% device life time used Pre EOL information [PRE_EOL_INFO: 0x01] i.e. Normal Optimal read size [OPTIMAL_READ_SIZE: 0x00] Optimal write size [OPTIMAL_WRITE_SIZE: 0x30] Optimal trim unit size [OPTIMAL_TRIM_UNIT_SIZE: 0x01] Device version [DEVICE_VERSION: 0x00 - 0x00] Firmware version: [FIRMWARE_VERSION[261]]: 0x00 [FIRMWARE_VERSION[260]]: 0x00 [FIRMWARE_VERSION[259]]: 0x00 [FIRMWARE_VERSION[258]]: 0x00 [FIRMWARE_VERSION[257]]: 0x00 [FIRMWARE_VERSION[256]]: 0x00 [FIRMWARE_VERSION[255]]: 0x00 [FIRMWARE_VERSION[254]]: 0x01 Power class for 200MHz, DDR at VCC= 3.6V [PWR_CL_DDR_200_360: 0x00] ------------------------------------------------------------- Generic CMD6 Timer [GENERIC_CMD6_TIME: 0x0a] Power off notification [POWER_OFF_LONG_TIME: 0x3c] Cache Size [CACHE_SIZE] is 65536 KiB Background operations status [BKOPS_STATUS: 0x00] 1st Initialisation Time after programmed sector [INI_TIMEOUT_AP: 0x1e] Power class for 52MHz, DDR at 3.6V [PWR_CL_DDR_52_360: 0x00] Power class for 52MHz, DDR at 1.95V [PWR_CL_DDR_52_195: 0x00] Power class for 200MHz at 3.6V [PWR_CL_200_360: 0x00] Power class for 200MHz, at 1.95V [PWR_CL_200_195: 0x00] Minimum Performance for 8bit at 52MHz in DDR mode: [MIN_PERF_DDR_W_8_52: 0x4b] [MIN_PERF_DDR_R_8_52: 0x00] TRIM Multiplier [TRIM_MULT: 0x02] Secure Feature support [SEC_FEATURE_SUPPORT: 0x55] Boot Information [BOOT_INFO: 0x07] Device supports alternative boot method Device supports dual data rate during boot Device supports high speed timing during boot Boot partition size [BOOT_SIZE_MULTI: 0x20] Access size [ACC_SIZE: 0x07] High-capacity erase unit size [HC_ERASE_GRP_SIZE: 0x01] High-capacity erase timeout [ERASE_TIMEOUT_MULT: 0x01] Reliable write sector count [REL_WR_SEC_C: 0x01] High-capacity W protect group size [HC_WP_GRP_SIZE: 0x10] Sleep current (VCC) [S_C_VCC: 0x07] Sleep current (VCCQ) [S_C_VCCQ: 0x07] Sleep/awake timeout [S_A_TIMEOUT: 0x11] Sector Count [SEC_COUNT: 0x0747c000] Minimum Write Performance for 8bit: [MIN_PERF_W_8_52: 0x4c] [MIN_PERF_R_8_52: 0x00] [MIN_PERF_W_8_26_4_52: 0x47] [MIN_PERF_R_8_26_4_52: 0x00] Minimum Write Performance for 4bit: [MIN_PERF_W_4_26: 0x2b] [MIN_PERF_R_4_26: 0x00] Power classes registers: [PWR_CL_26_360: 0x00] [PWR_CL_52_360: 0x00] [PWR_CL_26_195: 0x00] [PWR_CL_52_195: 0x00] Partition switching timing [PARTITION_SWITCH_TIME: 0x02] Out-of-interrupt busy timing [OUT_OF_INTERRUPT_TIME: 0x0a] I/O Driver Strength [DRIVER_STRENGTH: 0x1f] Card Type [CARD_TYPE: 0x57] CSD structure version [CSD_STRUCTURE: 0x02] Command set [CMD_SET: 0x00] Command set revision [CMD_SET_REV: 0x00] Power class [POWER_CLASS: 0x00] High-speed interface timing [HS_TIMING: 0x00] Erased memory content [ERASED_MEM_CONT: 0x00] Boot configuration bytes [PARTITION_CONFIG: 0x48] No access to boot partition Boot config protection [BOOT_CONFIG_PROT: 0x00] Boot bus Conditions [BOOT_BUS_CONDITIONS: 0x01] High-density erase group definition [ERASE_GROUP_DEF: 0x00] Boot write protection status registers [BOOT_WP_STATUS]: 0x00 Boot Area Write protection [BOOT_WP]: 0x00 Power ReadOnly locking: possible Permanent ReadOnly locking: possible Read Only lock status: not locked User area write protection register [USER_WP]: 0x10 FW configuration [FW_CONFIG]: 0x00 RPMB Size [RPMB_SIZE_MULT]: 0x80 Write reliability setting register [WR_REL_SET]: 0x1f Write reliability parameter register [WR_REL_PARAM]: 0x14 Enable background operations handshake [BKOPS_EN]: 0x00 H/W reset function [RST_N_FUNCTION]: 0x01 HPI management [HPI_MGMT]: 0x00 Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Max Enhanced Area Size [MAX_ENH_SIZE_MULT]: 0x0009b5 Partitions attribute [PARTITIONS_ATTRIBUTE]: 0x00 Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 General Purpose Partition Size [GP_SIZE_MULT_4]: 0x000000 [GP_SIZE_MULT_3]: 0x000000 [GP_SIZE_MULT_2]: 0x000000 [GP_SIZE_MULT_1]: 0x000000 Enhanced User Data Area Size [ENH_SIZE_MULT]: 0x000000 Enhanced User Data Start Address [ENH_START_ADDR]: 0x000000 Bad Block Management mode [SEC_BAD_BLK_MGMNT]: 0x00 Periodic Wake-up [PERIODIC_WAKEUP]: 0x00 Program CID/CSD in DDR mode support [PROGRAM_CID_CSD_DDR_SUPPORT]: 0x01 Native sector size [NATIVE_SECTOR_SIZE]: 0x00 Sector size emulation [USE_NATIVE_SECTOR]: 0x00 Sector size [DATA_SECTOR_SIZE]: 0x00 1st initialization after disabling sector size emulation [INI_TIMEOUT_EMU]: 0x00 Class 6 commands control [CLASS_6_CTRL]: 0x00 Number of addressed group to be released[DYNCAP_NEEDED]: 0x00 Exception events control [EXCEPTION_EVENTS_CTRL]: 0x0000 Exception events status [EXCEPTION_EVENTS_STATUS]: 0x0000 Extended Partitions Attribute [EXT_PARTITIONS_ATTRIBUTE]: 0x0000 Packed command status [PACKED_COMMAND_STATUS]: 0x00 Packed command failure index [PACKED_FAILURE_INDEX]: 0x00 Power Off Notification [POWER_OFF_NOTIFICATION]: 0x00 Control to turn the Cache ON/OFF [CACHE_CTRL]: 0x00 Partition info successfully found ------ Android information ------ Detected LINUX(Android) SYSTEM : 0x0011000000 (4.687GB) Short EXT fs info: Size: 4.613GB Block size: 4.0KB Inode size: 256 Inodes: 302512 Short Android info: Unable to read prop.plist , code : 2 Backup saved: BuildProp_20200618_0058.txt --------------------------------------------- Detected USERDATA USERDATA : 0x0197300000 (51.875GB) Unable to mount USERDATA , code : 95 Userdata Superblock contents:: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 ................................; 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 ................................; 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 ................................; 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 ................................; 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 ................................; 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 ................................; 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 ................................; 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 ................................; Done. Checking security ... Running:Repair extCSD... Z3X EasyJtag Software ver. 3.6.2.3 Skip loading eMMC Addon Firmware Box IO Level:2800 mV CLK Rate:14000 kHz ------------Parsing extCSD------------ ============================================= Extended CSD rev 1.8 (MMC 5.1) ============================================= Card Supported Command sets [S_CMD_SET: 0x01] HPI Features [HPI_FEATURE: 0x01]: implementation based on CMD13 Background operations support [BKOPS_SUPPORT: 0x01] Max Packet Read Cmd [MAX_PACKED_READS: 0x3f] Max Packet Write Cmd [MAX_PACKED_WRITES: 0x3f] Data TAG support [DATA_TAG_SUPPORT: 0x01] Data TAG Unit Size [TAG_UNIT_SIZE: 0x03] Tag Resources Size [TAG_RES_SIZE: 0x00] Context Management Capabilities [CONTEXT_CAPABILITIES: 0x05] Large Unit Size [LARGE_UNIT_SIZE_M1: 0x07] Extended partition attribute support [EXT_SUPPORT: 0x03] Generic CMD6 Timer [GENERIC_CMD6_TIME: 0x0a] Power off notification [POWER_OFF_LONG_TIME: 0x3c] Cache Size [CACHE_SIZE] is 65536 KiB ------------------------- eMMC v5+ ------------------------- Supported modes [SUPPORTED_MODES: 0x03] FFU features [FFU_FEATURES: 0x00] Operation codes timeout [OPERATION_CODE_TIMEOUT: 0x00] FFU Argument [FFU_ARG: 0xc7810000] Number of FW sectors correctly programmed[NUM_OF_FW_SECT_CORR_PROG: 0] Vendor proprietary health report: [VENDOR_PROPRIETARY_HEALTH_REPORT[301]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[300]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[299]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[298]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[297]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[296]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[295]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[294]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[293]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[292]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[291]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[290]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[289]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[288]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[287]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[286]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[285]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[284]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[283]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[282]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[281]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[280]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[279]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[278]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[277]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[276]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[275]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[274]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[273]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[272]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[271]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[270]]:0x00 _(Device life time estimation type B [DEVICE_LIFE_TIME_EST_TYP_B: 0x01] i.e. 0% - 10% device life time used _(Device life time estimation type B [DEVICE_LIFE_TIME_EST_TYP_A: 0x01] i.e. 0% - 10% device life time used Pre EOL information [PRE_EOL_INFO: 0x01] i.e. Normal Optimal read size [OPTIMAL_READ_SIZE: 0x00] Optimal write size [OPTIMAL_WRITE_SIZE: 0x30] Optimal trim unit size [OPTIMAL_TRIM_UNIT_SIZE: 0x01] Device version [DEVICE_VERSION: 0x00 - 0x00] Firmware version: [FIRMWARE_VERSION[261]]: 0x00 [FIRMWARE_VERSION[260]]: 0x00 [FIRMWARE_VERSION[259]]: 0x00 [FIRMWARE_VERSION[258]]: 0x00 [FIRMWARE_VERSION[257]]: 0x00 [FIRMWARE_VERSION[256]]: 0x00 [FIRMWARE_VERSION[255]]: 0x00 [FIRMWARE_VERSION[254]]: 0x01 Power class for 200MHz, DDR at VCC= 3.6V [PWR_CL_DDR_200_360: 0x00] ------------------------------------------------------------- Generic CMD6 Timer [GENERIC_CMD6_TIME: 0x0a] Power off notification [POWER_OFF_LONG_TIME: 0x3c] Cache Size [CACHE_SIZE] is 65536 KiB Background operations status [BKOPS_STATUS: 0x00] 1st Initialisation Time after programmed sector [INI_TIMEOUT_AP: 0x1e] Power class for 52MHz, DDR at 3.6V [PWR_CL_DDR_52_360: 0x00] Power class for 52MHz, DDR at 1.95V [PWR_CL_DDR_52_195: 0x00] Power class for 200MHz at 3.6V [PWR_CL_200_360: 0x00] Power class for 200MHz, at 1.95V [PWR_CL_200_195: 0x00] Minimum Performance for 8bit at 52MHz in DDR mode: [MIN_PERF_DDR_W_8_52: 0x4b] [MIN_PERF_DDR_R_8_52: 0x00] TRIM Multiplier [TRIM_MULT: 0x02] Secure Feature support [SEC_FEATURE_SUPPORT: 0x55] Boot Information [BOOT_INFO: 0x07] Device supports alternative boot method Device supports dual data rate during boot Device supports high speed timing during boot Boot partition size [BOOT_SIZE_MULTI: 0x20] Access size [ACC_SIZE: 0x07] High-capacity erase unit size [HC_ERASE_GRP_SIZE: 0x01] High-capacity erase timeout [ERASE_TIMEOUT_MULT: 0x01] Reliable write sector count [REL_WR_SEC_C: 0x01] High-capacity W protect group size [HC_WP_GRP_SIZE: 0x10] Sleep current (VCC) [S_C_VCC: 0x07] Sleep current (VCCQ) [S_C_VCCQ: 0x07] Sleep/awake timeout [S_A_TIMEOUT: 0x11] Sector Count [SEC_COUNT: 0x0747c000] Minimum Write Performance for 8bit: [MIN_PERF_W_8_52: 0x4c] [MIN_PERF_R_8_52: 0x00] [MIN_PERF_W_8_26_4_52: 0x47] [MIN_PERF_R_8_26_4_52: 0x00] Minimum Write Performance for 4bit: [MIN_PERF_W_4_26: 0x2b] [MIN_PERF_R_4_26: 0x00] Power classes registers: [PWR_CL_26_360: 0x00] [PWR_CL_52_360: 0x00] [PWR_CL_26_195: 0x00] [PWR_CL_52_195: 0x00] Partition switching timing [PARTITION_SWITCH_TIME: 0x02] Out-of-interrupt busy timing [OUT_OF_INTERRUPT_TIME: 0x0a] I/O Driver Strength [DRIVER_STRENGTH: 0x1f] Card Type [CARD_TYPE: 0x57] CSD structure version [CSD_STRUCTURE: 0x02] Command set [CMD_SET: 0x00] Command set revision [CMD_SET_REV: 0x00] Power class [POWER_CLASS: 0x00] High-speed interface timing [HS_TIMING: 0x00] Erased memory content [ERASED_MEM_CONT: 0x00] Boot configuration bytes [PARTITION_CONFIG: 0x48] No access to boot partition Boot config protection [BOOT_CONFIG_PROT: 0x00] Boot bus Conditions [BOOT_BUS_CONDITIONS: 0x01] High-density erase group definition [ERASE_GROUP_DEF: 0x00] Boot write protection status registers [BOOT_WP_STATUS]: 0x00 Boot Area Write protection [BOOT_WP]: 0x00 Power ReadOnly locking: possible Permanent ReadOnly locking: possible Read Only lock status: not locked User area write protection register [USER_WP]: 0x10 FW configuration [FW_CONFIG]: 0x00 RPMB Size [RPMB_SIZE_MULT]: 0x80 Write reliability setting register [WR_REL_SET]: 0x1f Write reliability parameter register [WR_REL_PARAM]: 0x14 Enable background operations handshake [BKOPS_EN]: 0x00 H/W reset function [RST_N_FUNCTION]: 0x01 HPI management [HPI_MGMT]: 0x00 Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Max Enhanced Area Size [MAX_ENH_SIZE_MULT]: 0x0009b5 Partitions attribute [PARTITIONS_ATTRIBUTE]: 0x00 Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 General Purpose Partition Size [GP_SIZE_MULT_4]: 0x000000 [GP_SIZE_MULT_3]: 0x000000 [GP_SIZE_MULT_2]: 0x000000 [GP_SIZE_MULT_1]: 0x000000 Enhanced User Data Area Size [ENH_SIZE_MULT]: 0x000000 Enhanced User Data Start Address [ENH_START_ADDR]: 0x000000 Bad Block Management mode [SEC_BAD_BLK_MGMNT]: 0x00 Periodic Wake-up [PERIODIC_WAKEUP]: 0x00 Program CID/CSD in DDR mode support [PROGRAM_CID_CSD_DDR_SUPPORT]: 0x01 Native sector size [NATIVE_SECTOR_SIZE]: 0x00 Sector size emulation [USE_NATIVE_SECTOR]: 0x00 Sector size [DATA_SECTOR_SIZE]: 0x00 1st initialization after disabling sector size emulation [INI_TIMEOUT_EMU]: 0x00 Class 6 commands control [CLASS_6_CTRL]: 0x00 Number of addressed group to be released[DYNCAP_NEEDED]: 0x00 Exception events control [EXCEPTION_EVENTS_CTRL]: 0x0000 Exception events status [EXCEPTION_EVENTS_STATUS]: 0x0000 Extended Partitions Attribute [EXT_PARTITIONS_ATTRIBUTE]: 0x0000 Packed command status [PACKED_COMMAND_STATUS]: 0x00 Packed command failure index [PACKED_FAILURE_INDEX]: 0x00 Power Off Notification [POWER_OFF_NOTIFICATION]: 0x00 Control to turn the Cache ON/OFF [CACHE_CTRL]: 0x00 ------------Done parsing------------ Writing as extCSD 5.1 Done. Checking security ... Z3X EasyJtag Software ver. 3.6.2.3 Skip loading eMMC Addon Firmware Input file : C:\Users\jmr\Desktop\backup a307g bit 3\EMMC_CUTA42_ROM1_000000000000_000020000000.bin Writing 0020000000 bytes to 0000000000... ROM1 (USER ROM) Done, time taken: 44 sec. Average Write Speed: 12090 kB/s Checking security ... Z3X EasyJtag Software ver. 3.6.2.3 Skip loading eMMC Addon Firmware Input file : C:\Users\jmr\Desktop\backup a307g bit 3\EMMC_CUTA42_ROM2_000000000000_000000400000.bin Writing 0000400000 bytes to 0000000000 ...ROM2 (BOOT1 ROM) Done, time taken: 0.644 sec. Average Write Speed: 6543 kB/s Checking security ... Z3X EasyJtag Software ver. 3.6.2.3 Skip loading eMMC Addon Firmware Input file : C:\Users\jmr\Desktop\backup a307g bit 3\EMMC_CUTA42_ROM3_000000000000_000000400000.bin Writing 0000400000 bytes to 0000000000 ...ROM3 (BOOT2 ROM) Done, time taken: 0.641 sec. Average Write Speed: 6553 kB/s Checking security ... Running:Repair extCSD... Z3X EasyJtag Software ver. 3.6.2.3 Skip loading eMMC Addon Firmware Box IO Level:2800 mV CLK Rate:14000 kHz ------------Parsing extCSD------------ ============================================= Extended CSD rev 1.8 (MMC 5.1) ============================================= Card Supported Command sets [S_CMD_SET: 0x01] HPI Features [HPI_FEATURE: 0x01]: implementation based on CMD13 Background operations support [BKOPS_SUPPORT: 0x01] Max Packet Read Cmd [MAX_PACKED_READS: 0x3f] Max Packet Write Cmd [MAX_PACKED_WRITES: 0x3f] Data TAG support [DATA_TAG_SUPPORT: 0x01] Data TAG Unit Size [TAG_UNIT_SIZE: 0x03] Tag Resources Size [TAG_RES_SIZE: 0x00] Context Management Capabilities [CONTEXT_CAPABILITIES: 0x05] Large Unit Size [LARGE_UNIT_SIZE_M1: 0x07] Extended partition attribute support [EXT_SUPPORT: 0x03] Generic CMD6 Timer [GENERIC_CMD6_TIME: 0x0a] Power off notification [POWER_OFF_LONG_TIME: 0x3c] Cache Size [CACHE_SIZE] is 65536 KiB ------------------------- eMMC v5+ ------------------------- Supported modes [SUPPORTED_MODES: 0x03] FFU features [FFU_FEATURES: 0x00] Operation codes timeout [OPERATION_CODE_TIMEOUT: 0x00] FFU Argument [FFU_ARG: 0xc7810000] Number of FW sectors correctly programmed[NUM_OF_FW_SECT_CORR_PROG: 0] Vendor proprietary health report: [VENDOR_PROPRIETARY_HEALTH_REPORT[301]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[300]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[299]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[298]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[297]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[296]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[295]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[294]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[293]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[292]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[291]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[290]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[289]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[288]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[287]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[286]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[285]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[284]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[283]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[282]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[281]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[280]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[279]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[278]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[277]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[276]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[275]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[274]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[273]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[272]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[271]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[270]]:0x00 _(Device life time estimation type B [DEVICE_LIFE_TIME_EST_TYP_B: 0x01] i.e. 0% - 10% device life time used _(Device life time estimation type B [DEVICE_LIFE_TIME_EST_TYP_A: 0x01] i.e. 0% - 10% device life time used Pre EOL information [PRE_EOL_INFO: 0x01] i.e. Normal Optimal read size [OPTIMAL_READ_SIZE: 0x00] Optimal write size [OPTIMAL_WRITE_SIZE: 0x30] Optimal trim unit size [OPTIMAL_TRIM_UNIT_SIZE: 0x01] Device version [DEVICE_VERSION: 0x00 - 0x00] Firmware version: [FIRMWARE_VERSION[261]]: 0x00 [FIRMWARE_VERSION[260]]: 0x00 [FIRMWARE_VERSION[259]]: 0x00 [FIRMWARE_VERSION[258]]: 0x00 [FIRMWARE_VERSION[257]]: 0x00 [FIRMWARE_VERSION[256]]: 0x00 [FIRMWARE_VERSION[255]]: 0x00 [FIRMWARE_VERSION[254]]: 0x01 Power class for 200MHz, DDR at VCC= 3.6V [PWR_CL_DDR_200_360: 0x00] ------------------------------------------------------------- Generic CMD6 Timer [GENERIC_CMD6_TIME: 0x0a] Power off notification [POWER_OFF_LONG_TIME: 0x3c] Cache Size [CACHE_SIZE] is 65536 KiB Background operations status [BKOPS_STATUS: 0x00] 1st Initialisation Time after programmed sector [INI_TIMEOUT_AP: 0x1e] Power class for 52MHz, DDR at 3.6V [PWR_CL_DDR_52_360: 0x00] Power class for 52MHz, DDR at 1.95V [PWR_CL_DDR_52_195: 0x00] Power class for 200MHz at 3.6V [PWR_CL_200_360: 0x00] Power class for 200MHz, at 1.95V [PWR_CL_200_195: 0x00] Minimum Performance for 8bit at 52MHz in DDR mode: [MIN_PERF_DDR_W_8_52: 0x4b] [MIN_PERF_DDR_R_8_52: 0x00] TRIM Multiplier [TRIM_MULT: 0x02] Secure Feature support [SEC_FEATURE_SUPPORT: 0x55] Boot Information [BOOT_INFO: 0x07] Device supports alternative boot method Device supports dual data rate during boot Device supports high speed timing during boot Boot partition size [BOOT_SIZE_MULTI: 0x20] Access size [ACC_SIZE: 0x07] High-capacity erase unit size [HC_ERASE_GRP_SIZE: 0x01] High-capacity erase timeout [ERASE_TIMEOUT_MULT: 0x01] Reliable write sector count [REL_WR_SEC_C: 0x01] High-capacity W protect group size [HC_WP_GRP_SIZE: 0x10] Sleep current (VCC) [S_C_VCC: 0x07] Sleep current (VCCQ) [S_C_VCCQ: 0x07] Sleep/awake timeout [S_A_TIMEOUT: 0x11] Sector Count [SEC_COUNT: 0x0747c000] Minimum Write Performance for 8bit: [MIN_PERF_W_8_52: 0x4c] [MIN_PERF_R_8_52: 0x00] [MIN_PERF_W_8_26_4_52: 0x47] [MIN_PERF_R_8_26_4_52: 0x00] Minimum Write Performance for 4bit: [MIN_PERF_W_4_26: 0x2b] [MIN_PERF_R_4_26: 0x00] Power classes registers: [PWR_CL_26_360: 0x00] [PWR_CL_52_360: 0x00] [PWR_CL_26_195: 0x00] [PWR_CL_52_195: 0x00] Partition switching timing [PARTITION_SWITCH_TIME: 0x02] Out-of-interrupt busy timing [OUT_OF_INTERRUPT_TIME: 0x0a] I/O Driver Strength [DRIVER_STRENGTH: 0x1f] Card Type [CARD_TYPE: 0x57] CSD structure version [CSD_STRUCTURE: 0x02] Command set [CMD_SET: 0x00] Command set revision [CMD_SET_REV: 0x00] Power class [POWER_CLASS: 0x00] High-speed interface timing [HS_TIMING: 0x00] Erased memory content [ERASED_MEM_CONT: 0x00] Boot configuration bytes [PARTITION_CONFIG: 0x48] No access to boot partition Boot config protection [BOOT_CONFIG_PROT: 0x00] Boot bus Conditions [BOOT_BUS_CONDITIONS: 0x01] High-density erase group definition [ERASE_GROUP_DEF: 0x00] Boot write protection status registers [BOOT_WP_STATUS]: 0x00 Boot Area Write protection [BOOT_WP]: 0x00 Power ReadOnly locking: possible Permanent ReadOnly locking: possible Read Only lock status: not locked User area write protection register [USER_WP]: 0x10 FW configuration [FW_CONFIG]: 0x00 RPMB Size [RPMB_SIZE_MULT]: 0x80 Write reliability setting register [WR_REL_SET]: 0x1f Write reliability parameter register [WR_REL_PARAM]: 0x14 Enable background operations handshake [BKOPS_EN]: 0x00 H/W reset function [RST_N_FUNCTION]: 0x01 HPI management [HPI_MGMT]: 0x00 Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Max Enhanced Area Size [MAX_ENH_SIZE_MULT]: 0x0009b5 Partitions attribute [PARTITIONS_ATTRIBUTE]: 0x00 Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 General Purpose Partition Size [GP_SIZE_MULT_4]: 0x000000 [GP_SIZE_MULT_3]: 0x000000 [GP_SIZE_MULT_2]: 0x000000 [GP_SIZE_MULT_1]: 0x000000 Enhanced User Data Area Size [ENH_SIZE_MULT]: 0x000000 Enhanced User Data Start Address [ENH_START_ADDR]: 0x000000 Bad Block Management mode [SEC_BAD_BLK_MGMNT]: 0x00 Periodic Wake-up [PERIODIC_WAKEUP]: 0x00 Program CID/CSD in DDR mode support [PROGRAM_CID_CSD_DDR_SUPPORT]: 0x01 Native sector size [NATIVE_SECTOR_SIZE]: 0x00 Sector size emulation [USE_NATIVE_SECTOR]: 0x00 Sector size [DATA_SECTOR_SIZE]: 0x00 1st initialization after disabling sector size emulation [INI_TIMEOUT_EMU]: 0x00 Class 6 commands control [CLASS_6_CTRL]: 0x00 Number of addressed group to be released[DYNCAP_NEEDED]: 0x00 Exception events control [EXCEPTION_EVENTS_CTRL]: 0x0000 Exception events status [EXCEPTION_EVENTS_STATUS]: 0x0000 Extended Partitions Attribute [EXT_PARTITIONS_ATTRIBUTE]: 0x0000 Packed command status [PACKED_COMMAND_STATUS]: 0x00 Packed command failure index [PACKED_FAILURE_INDEX]: 0x00 Power Off Notification [POWER_OFF_NOTIFICATION]: 0x00 Control to turn the Cache ON/OFF [CACHE_CTRL]: 0x00 ------------Done parsing------------ Writing as extCSD 5.1 Done. ------ Detected 32 partitions ------ P0 (BOTA0) [0x400000 0x400000] Size: 4.0MB P1 (BOTA1) [0x800000 0x800000] Size: 8.0MB P2 (EFS) [0x1000000 0x1400000] Size: 20.0MB P3 (SEC_EFS) [0x2400000 0x1400000] Size: 20.0MB P4 (CPEFS) [0x3800000 0x800000] Size: 8.0MB P5 (BOTA2) [0x4000000 0x800000] Size: 8.0MB P6 (CM) [0x4800000 0x800000] Size: 8.0MB P7 (M9KEFS1) [0x5000000 0x400000] Size: 4.0MB P8 (M9KEFS2) [0x5400000 0x400000] Size: 4.0MB P9 (M9KEFS3) [0x5800000 0x400000] Size: 4.0MB P10 (NAD_REFER) [0x5c00000 0x100000] Size: 1.0MB P11 (PARAM) [0x5d00000 0x800000] Size: 8.0MB P12 (UP_PARAM) [0x6500000 0x800000] Size: 8.0MB P13 (MISC) [0x6d00000 0x200000] Size: 2.0MB P14 (BOOT) [0x6f00000 0x2400000] Size: 36.0MB P15 (RECOVERY) [0x9300000 0x3500000] Size: 53.0MB P16 (DTB) [0xc800000 0x800000] Size: 8.0MB P17 (DTBO) [0xd000000 0x800000] Size: 8.0MB P18 (RADIO) [0xd800000 0x2d00000] Size: 45.0MB P19 (PERSISTENT) [0x10500000 0x80000] Size: 512.0KB P20 (STEADY) [0x10580000 0x400000] Size: 4.0MB P21 (VBMETA) [0x10980000 0x80000] Size: 512.0KB P22 (BOTA3) [0x10a00000 0x80000] Size: 512.0KB P23 (RESERVED2) [0x10a80000 0x580000] Size: 5.500MB P24 (SYSTEM) [0x11000000 0x12c000000] Size: 4.687GB P25 (VENDOR) [0x13d000000 0x26800000] Size: 616.0MB P26 (PRODUCT) [0x163800000 0x25800000] Size: 600.0MB P27 (CACHE) [0x189000000 0xc800000] Size: 200.0MB P28 (OMR) [0x195800000 0x3200000] Size: 50.0MB P29 (CP_DEBUG) [0x198a00000 0x500000] Size: 5.0MB P30 (NAD_FW) [0x198f00000 0x1400000] Size: 20.0MB P31 (USERDATA) [0x19a300000 0xcf5000000] Size: 51.828GB ------------------------------------ Checking security ... Z3X EasyJtag Software ver. 3.6.2.3 Skip loading eMMC Addon Firmware Input file : C:\Users\jmr\Desktop\a30s bit 1\dump a30s bit 1\EMMC_CUTA42_1026013831_ROM1_0x1000000_EFS_0x1400 000.bin Writing 0001400000 bytes to 0001000000... ROM1 (USER ROM) Done, time taken: 1 sec. Average Write Speed: 17418 kB/s ------ Detected 32 partitions ------ P0 (BOTA0) [0x400000 0x400000] Size: 4.0MB P1 (BOTA1) [0x800000 0x800000] Size: 8.0MB P2 (EFS) [0x1000000 0x1400000] Size: 20.0MB P3 (SEC_EFS) [0x2400000 0x1400000] Size: 20.0MB P4 (CPEFS) [0x3800000 0x800000] Size: 8.0MB P5 (BOTA2) [0x4000000 0x800000] Size: 8.0MB P6 (CM) [0x4800000 0x800000] Size: 8.0MB P7 (M9KEFS1) [0x5000000 0x400000] Size: 4.0MB P8 (M9KEFS2) [0x5400000 0x400000] Size: 4.0MB P9 (M9KEFS3) [0x5800000 0x400000] Size: 4.0MB P10 (NAD_REFER) [0x5c00000 0x100000] Size: 1.0MB P11 (PARAM) [0x5d00000 0x800000] Size: 8.0MB P12 (UP_PARAM) [0x6500000 0x800000] Size: 8.0MB P13 (MISC) [0x6d00000 0x200000] Size: 2.0MB P14 (BOOT) [0x6f00000 0x2400000] Size: 36.0MB P15 (RECOVERY) [0x9300000 0x3500000] Size: 53.0MB P16 (DTB) [0xc800000 0x800000] Size: 8.0MB P17 (DTBO) [0xd000000 0x800000] Size: 8.0MB P18 (RADIO) [0xd800000 0x2d00000] Size: 45.0MB P19 (PERSISTENT) [0x10500000 0x80000] Size: 512.0KB P20 (STEADY) [0x10580000 0x400000] Size: 4.0MB P21 (VBMETA) [0x10980000 0x80000] Size: 512.0KB P22 (BOTA3) [0x10a00000 0x80000] Size: 512.0KB P23 (RESERVED2) [0x10a80000 0x580000] Size: 5.500MB P24 (SYSTEM) [0x11000000 0x12c000000] Size: 4.687GB P25 (VENDOR) [0x13d000000 0x26800000] Size: 616.0MB P26 (PRODUCT) [0x163800000 0x25800000] Size: 600.0MB P27 (CACHE) [0x189000000 0xc800000] Size: 200.0MB P28 (OMR) [0x195800000 0x3200000] Size: 50.0MB P29 (CP_DEBUG) [0x198a00000 0x500000] Size: 5.0MB P30 (NAD_FW) [0x198f00000 0x1400000] Size: 20.0MB P31 (USERDATA) [0x19a300000 0xcf5000000] Size: 51.828GB ------------------------------------ Checking security ... Z3X EasyJtag Software ver. 3.6.2.3 Skip loading eMMC Addon Firmware Input file : C:\Users\jmr\Desktop\a30s bit 1\dump a30s bit 1\EMMC_CUTA42_1026013831_ROM1_0x2400000_SEC_EFS_0x 1400000.bin Writing 0001400000 bytes to 0002400000... ROM1 (USER ROM) Done, time taken: 1 sec. Average Write Speed: 16994 kB/s ------ Detected 32 partitions ------ P0 (BOTA0) [0x400000 0x400000] Size: 4.0MB P1 (BOTA1) [0x800000 0x800000] Size: 8.0MB P2 (EFS) [0x1000000 0x1400000] Size: 20.0MB P3 (SEC_EFS) [0x2400000 0x1400000] Size: 20.0MB P4 (CPEFS) [0x3800000 0x800000] Size: 8.0MB P5 (BOTA2) [0x4000000 0x800000] Size: 8.0MB P6 (CM) [0x4800000 0x800000] Size: 8.0MB P7 (M9KEFS1) [0x5000000 0x400000] Size: 4.0MB P8 (M9KEFS2) [0x5400000 0x400000] Size: 4.0MB P9 (M9KEFS3) [0x5800000 0x400000] Size: 4.0MB P10 (NAD_REFER) [0x5c00000 0x100000] Size: 1.0MB P11 (PARAM) [0x5d00000 0x800000] Size: 8.0MB P12 (UP_PARAM) [0x6500000 0x800000] Size: 8.0MB P13 (MISC) [0x6d00000 0x200000] Size: 2.0MB P14 (BOOT) [0x6f00000 0x2400000] Size: 36.0MB P15 (RECOVERY) [0x9300000 0x3500000] Size: 53.0MB P16 (DTB) [0xc800000 0x800000] Size: 8.0MB P17 (DTBO) [0xd000000 0x800000] Size: 8.0MB P18 (RADIO) [0xd800000 0x2d00000] Size: 45.0MB P19 (PERSISTENT) [0x10500000 0x80000] Size: 512.0KB P20 (STEADY) [0x10580000 0x400000] Size: 4.0MB P21 (VBMETA) [0x10980000 0x80000] Size: 512.0KB P22 (BOTA3) [0x10a00000 0x80000] Size: 512.0KB P23 (RESERVED2) [0x10a80000 0x580000] Size: 5.500MB P24 (SYSTEM) [0x11000000 0x12c000000] Size: 4.687GB P25 (VENDOR) [0x13d000000 0x26800000] Size: 616.0MB P26 (PRODUCT) [0x163800000 0x25800000] Size: 600.0MB P27 (CACHE) [0x189000000 0xc800000] Size: 200.0MB P28 (OMR) [0x195800000 0x3200000] Size: 50.0MB P29 (CP_DEBUG) [0x198a00000 0x500000] Size: 5.0MB P30 (NAD_FW) [0x198f00000 0x1400000] Size: 20.0MB P31 (USERDATA) [0x19a300000 0xcf5000000] Size: 51.828GB ------------------------------------ Checking security ... Z3X EasyJtag Software ver. 3.6.2.3 Skip loading eMMC Addon Firmware Input file : C:\Users\jmr\Desktop\a30s bit 1\dump a30s bit 1\EMMC_CUTA42_1026013831_ROM1_0x3800000_CPEFS_0x80 0000.bin Writing 0000800000 bytes to 0003800000... ROM1 (USER ROM) Done, time taken: 0.755 sec. Average Write Speed: 10951 kB/s ------ Detected 32 partitions ------ P0 (BOTA0) [0x400000 0x400000] Size: 4.0MB P1 (BOTA1) [0x800000 0x800000] Size: 8.0MB P2 (EFS) [0x1000000 0x1400000] Size: 20.0MB P3 (SEC_EFS) [0x2400000 0x1400000] Size: 20.0MB P4 (CPEFS) [0x3800000 0x800000] Size: 8.0MB P5 (BOTA2) [0x4000000 0x800000] Size: 8.0MB P6 (CM) [0x4800000 0x800000] Size: 8.0MB P7 (M9KEFS1) [0x5000000 0x400000] Size: 4.0MB P8 (M9KEFS2) [0x5400000 0x400000] Size: 4.0MB P9 (M9KEFS3) [0x5800000 0x400000] Size: 4.0MB P10 (NAD_REFER) [0x5c00000 0x100000] Size: 1.0MB P11 (PARAM) [0x5d00000 0x800000] Size: 8.0MB P12 (UP_PARAM) [0x6500000 0x800000] Size: 8.0MB P13 (MISC) [0x6d00000 0x200000] Size: 2.0MB P14 (BOOT) [0x6f00000 0x2400000] Size: 36.0MB P15 (RECOVERY) [0x9300000 0x3500000] Size: 53.0MB P16 (DTB) [0xc800000 0x800000] Size: 8.0MB P17 (DTBO) [0xd000000 0x800000] Size: 8.0MB P18 (RADIO) [0xd800000 0x2d00000] Size: 45.0MB P19 (PERSISTENT) [0x10500000 0x80000] Size: 512.0KB P20 (STEADY) [0x10580000 0x400000] Size: 4.0MB P21 (VBMETA) [0x10980000 0x80000] Size: 512.0KB P22 (BOTA3) [0x10a00000 0x80000] Size: 512.0KB P23 (RESERVED2) [0x10a80000 0x580000] Size: 5.500MB P24 (SYSTEM) [0x11000000 0x12c000000] Size: 4.687GB P25 (VENDOR) [0x13d000000 0x26800000] Size: 616.0MB P26 (PRODUCT) [0x163800000 0x25800000] Size: 600.0MB P27 (CACHE) [0x189000000 0xc800000] Size: 200.0MB P28 (OMR) [0x195800000 0x3200000] Size: 50.0MB P29 (CP_DEBUG) [0x198a00000 0x500000] Size: 5.0MB P30 (NAD_FW) [0x198f00000 0x1400000] Size: 20.0MB P31 (USERDATA) [0x19a300000 0xcf5000000] Size: 51.828GB ------------------------------------ Checking security ... Z3X EasyJtag Software ver. 3.6.2.3 Skip loading eMMC Addon Firmware Input file : C:\Users\jmr\Desktop\a30s bit 1\dump a30s bit 1\EMMC_CUTA42_1026013831_ROM1_0x5000000_M9KEFS1_0x 400000.bin Writing 0000400000 bytes to 0005000000... ROM1 (USER ROM) Done, time taken: 0.223 sec. Average Write Speed: 19152 kB/s ------ Detected 32 partitions ------ P0 (BOTA0) [0x400000 0x400000] Size: 4.0MB P1 (BOTA1) [0x800000 0x800000] Size: 8.0MB P2 (EFS) [0x1000000 0x1400000] Size: 20.0MB P3 (SEC_EFS) [0x2400000 0x1400000] Size: 20.0MB P4 (CPEFS) [0x3800000 0x800000] Size: 8.0MB P5 (BOTA2) [0x4000000 0x800000] Size: 8.0MB P6 (CM) [0x4800000 0x800000] Size: 8.0MB P7 (M9KEFS1) [0x5000000 0x400000] Size: 4.0MB P8 (M9KEFS2) [0x5400000 0x400000] Size: 4.0MB P9 (M9KEFS3) [0x5800000 0x400000] Size: 4.0MB P10 (NAD_REFER) [0x5c00000 0x100000] Size: 1.0MB P11 (PARAM) [0x5d00000 0x800000] Size: 8.0MB P12 (UP_PARAM) [0x6500000 0x800000] Size: 8.0MB P13 (MISC) [0x6d00000 0x200000] Size: 2.0MB P14 (BOOT) [0x6f00000 0x2400000] Size: 36.0MB P15 (RECOVERY) [0x9300000 0x3500000] Size: 53.0MB P16 (DTB) [0xc800000 0x800000] Size: 8.0MB P17 (DTBO) [0xd000000 0x800000] Size: 8.0MB P18 (RADIO) [0xd800000 0x2d00000] Size: 45.0MB P19 (PERSISTENT) [0x10500000 0x80000] Size: 512.0KB P20 (STEADY) [0x10580000 0x400000] Size: 4.0MB P21 (VBMETA) [0x10980000 0x80000] Size: 512.0KB P22 (BOTA3) [0x10a00000 0x80000] Size: 512.0KB P23 (RESERVED2) [0x10a80000 0x580000] Size: 5.500MB P24 (SYSTEM) [0x11000000 0x12c000000] Size: 4.687GB P25 (VENDOR) [0x13d000000 0x26800000] Size: 616.0MB P26 (PRODUCT) [0x163800000 0x25800000] Size: 600.0MB P27 (CACHE) [0x189000000 0xc800000] Size: 200.0MB P28 (OMR) [0x195800000 0x3200000] Size: 50.0MB P29 (CP_DEBUG) [0x198a00000 0x500000] Size: 5.0MB P30 (NAD_FW) [0x198f00000 0x1400000] Size: 20.0MB P31 (USERDATA) [0x19a300000 0xcf5000000] Size: 51.828GB ------------------------------------ Checking security ... Z3X EasyJtag Software ver. 3.6.2.3 Skip loading eMMC Addon Firmware Input file : C:\Users\jmr\Desktop\a30s bit 1\dump a30s bit 1\EMMC_CUTA42_1026013831_ROM1_0x5400000_M9KEFS2_0x 400000.bin Writing 0000400000 bytes to 0005400000... ROM1 (USER ROM) Done, time taken: 0.215 sec. Average Write Speed: 19152 kB/s ------ Detected 32 partitions ------ P0 (BOTA0) [0x400000 0x400000] Size: 4.0MB P1 (BOTA1) [0x800000 0x800000] Size: 8.0MB P2 (EFS) [0x1000000 0x1400000] Size: 20.0MB P3 (SEC_EFS) [0x2400000 0x1400000] Size: 20.0MB P4 (CPEFS) [0x3800000 0x800000] Size: 8.0MB P5 (BOTA2) [0x4000000 0x800000] Size: 8.0MB P6 (CM) [0x4800000 0x800000] Size: 8.0MB P7 (M9KEFS1) [0x5000000 0x400000] Size: 4.0MB P8 (M9KEFS2) [0x5400000 0x400000] Size: 4.0MB P9 (M9KEFS3) [0x5800000 0x400000] Size: 4.0MB P10 (NAD_REFER) [0x5c00000 0x100000] Size: 1.0MB P11 (PARAM) [0x5d00000 0x800000] Size: 8.0MB P12 (UP_PARAM) [0x6500000 0x800000] Size: 8.0MB P13 (MISC) [0x6d00000 0x200000] Size: 2.0MB P14 (BOOT) [0x6f00000 0x2400000] Size: 36.0MB P15 (RECOVERY) [0x9300000 0x3500000] Size: 53.0MB P16 (DTB) [0xc800000 0x800000] Size: 8.0MB P17 (DTBO) [0xd000000 0x800000] Size: 8.0MB P18 (RADIO) [0xd800000 0x2d00000] Size: 45.0MB P19 (PERSISTENT) [0x10500000 0x80000] Size: 512.0KB P20 (STEADY) [0x10580000 0x400000] Size: 4.0MB P21 (VBMETA) [0x10980000 0x80000] Size: 512.0KB P22 (BOTA3) [0x10a00000 0x80000] Size: 512.0KB P23 (RESERVED2) [0x10a80000 0x580000] Size: 5.500MB P24 (SYSTEM) [0x11000000 0x12c000000] Size: 4.687GB P25 (VENDOR) [0x13d000000 0x26800000] Size: 616.0MB P26 (PRODUCT) [0x163800000 0x25800000] Size: 600.0MB P27 (CACHE) [0x189000000 0xc800000] Size: 200.0MB P28 (OMR) [0x195800000 0x3200000] Size: 50.0MB P29 (CP_DEBUG) [0x198a00000 0x500000] Size: 5.0MB P30 (NAD_FW) [0x198f00000 0x1400000] Size: 20.0MB P31 (USERDATA) [0x19a300000 0xcf5000000] Size: 51.828GB ------------------------------------ Checking security ... Z3X EasyJtag Software ver. 3.6.2.3 Skip loading eMMC Addon Firmware Input file : C:\Users\jmr\Desktop\a30s bit 1\dump a30s bit 1\EMMC_CUTA42_1026013831_ROM1_0x5800000_M9KEFS3_0x 400000.bin Writing 0000400000 bytes to 0005800000... ROM1 (USER ROM) Done, time taken: 0.232 sec. Average Write Speed: 17848 kB/s ------ Detected 32 partitions ------ P0 (BOTA0) [0x400000 0x400000] Size: 4.0MB P1 (BOTA1) [0x800000 0x800000] Size: 8.0MB P2 (EFS) [0x1000000 0x1400000] Size: 20.0MB P3 (SEC_EFS) [0x2400000 0x1400000] Size: 20.0MB P4 (CPEFS) [0x3800000 0x800000] Size: 8.0MB P5 (BOTA2) [0x4000000 0x800000] Size: 8.0MB P6 (CM) [0x4800000 0x800000] Size: 8.0MB P7 (M9KEFS1) [0x5000000 0x400000] Size: 4.0MB P8 (M9KEFS2) [0x5400000 0x400000] Size: 4.0MB P9 (M9KEFS3) [0x5800000 0x400000] Size: 4.0MB P10 (NAD_REFER) [0x5c00000 0x100000] Size: 1.0MB P11 (PARAM) [0x5d00000 0x800000] Size: 8.0MB P12 (UP_PARAM) [0x6500000 0x800000] Size: 8.0MB P13 (MISC) [0x6d00000 0x200000] Size: 2.0MB P14 (BOOT) [0x6f00000 0x2400000] Size: 36.0MB P15 (RECOVERY) [0x9300000 0x3500000] Size: 53.0MB P16 (DTB) [0xc800000 0x800000] Size: 8.0MB P17 (DTBO) [0xd000000 0x800000] Size: 8.0MB P18 (RADIO) [0xd800000 0x2d00000] Size: 45.0MB P19 (PER | |
07-08-2020, 10:08 | #9 (permalink) | |
No Life Poster Join Date: Oct 2007 Location: Colombia
Member: 614683 Status: Offline Sonork: 100.1605379 Thanks Meter: 370 | Quote:
07-08-2020, 13:09 | #10 (permalink) | |
Product Supporter Join Date: Jun 2002 Location: Belarus Age: 47
Member: 13148 Status: Offline Thanks Meter: 2,948 | Quote:
2) create new topic with model name and describe problem 3) You message not corresponds to this topic Last edited by layder; 07-08-2020 at 13:35. | |
