Old 09-16-2020, 15:06   #1 (permalink)
rohit.sharma73's Avatar
Member: 2097870
Sonork: FINDING....
Thanks Meter: 65
Easyjtag ufs 2 in 1 problem
THIS VER SETUP INFO ALL OK EMMC NOTE 6 PRO
EasyJtag_Release_v3.7.0.11
BUT SECOND VER NOT DETECT EMMC ALWAYS SHOW THIS EROOR
easyjtag_emmc_plus_1.6.2.0.. NOT DETECT CHIP
Changelog:
23.06.2020 (ver 1.6.3.0)
Fix: Bugs that have been found through your crash report
Setting interface to EasyJtag2/E-Socket
Setting bus width to 8 Bit
Setting frequence to 14 MHz
Can't init device. Reason: OCR Ready Timeout Error [Check VCC or eMMC DEAD]
Canceled
HOW TO PREOBLEM I TRY 2 EMMC PLZ SOL
---------- eMMC Device Information ----------
eMMC CID : 90014A68433861503E034E91959CC56F
eMMC CSD : D02700328F5903FFFFFFFFEF8E400043
eMMC Manufacturer ID: 0090 , OEM ID: 014A
eMMC Date: 12/2018 Rev.0x3
eMMC NAME: hC8aP> , S/N: 1
eMMC NAME (HEX): 68433861503E
EMMC ROM1 (Main User Data) Capacity: 59640 MB
EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB
EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB
EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 kB
EMMC RPMB is programmed and written 34864 times
EMMC Permanent Write Protection: No
EMMC Temporary Write Protection: No
EMMC Password Locked: No
Extended CSD rev 1.8 (MMC 5.1)
Boot configuration [PARTITION_CONFIG: 0x38] Boot from:ROM1 (Main User Area)
Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x38.
H/W reset function [RST_N_FUNCTION]: 0x01
High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000]
Partitioning Support [PARTITIONING_SUPPORT]: 0x07
Device support partitioning feature
Device can have enhanced tech.
Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00
Backup saved: hC8aP>_1318163868_20200916_1930.extcsd
Caution: invalid backup GPT header, but valid main header!
EFI Table seems to be corrupted (sizeOfPartitionEntries!=128) sizeOfPartitionEntries = 0
Warning! One or more CRCs don't match. You should repair the disk!
Caution: Found protective or hybrid MBR and corrupt GPT.
Real (Hardware) Disk/Image size: 747C000 sectors 58.2 GiB
Soft (Partitioned) Disk/Image size: 747BFBC sectors 58.2 GiB
Disk identifier (GUID): DF23EAD0-5FDF-6B0C-3C17-478DA0FB3092
Logical sector size: 0x200 bytes ,First/Last usable sector: 34,122142686
Partition info successfully found
------ Detected 64 partitions ------
P0 (SWITCH) [0x5000 0x2000] Size: 8.0KB
P1 (DPO) [0x7000 0x2000] Size: 8.0KB
P2 (FSC) [0x9000 0x2000] Size: 8.0KB
P3 (LIMITS) [0xb000 0x8000] Size: 32.0KB
P4 (SSD) [0x13000 0x8000] Size: 32.0KB
P5 (SEC) [0x1b000 0x5000] Size: 20.0KB
P6 (VBMETA) [0x20000 0x10000] Size: 64.0KB
P7 (VBMETABAK) [0x30000 0x10000] Size: 64.0KB
P8 (STORSEC) [0x40000 0x20000] Size: 128.0KB
P9 (STORSECBAK) [0x60000 0x20000] Size: 128.0KB
P10 (APDP) [0x80000 0x40000] Size: 256.0KB
P11 (MSADP) [0xc0000 0x40000] Size: 256.0KB
P12 (KEYSTORE) [0x100000 0x80000] Size: 512.0KB
P13 (FRP) [0x180000 0x80000] Size: 512.0KB
P14 (RPM) [0x200000 0x80000] Size: 512.0KB
P15 (RPMBAK) [0x280000 0x80000] Size: 512.0KB
P16 (HYP) [0x300000 0x80000] Size: 512.0KB
P17 (HYPBAK) [0x380000 0x80000] Size: 512.0KB
P18 (PMIC) [0x400000 0x80000] Size: 512.0KB
P19 (PMICBAK) [0x480000 0x80000] Size: 512.0KB
P20 (CMNLIB) [0x500000 0x100000] Size: 1.0MB
P21 (CMNLIBBAK) [0x600000 0x100000] Size: 1.0MB
P22 (CMNLIB64) [0x700000 0x100000] Size: 1.0MB
P23 (CMNLIB64BAK) [0x800000 0x100000] Size: 1.0MB
P24 (ABL) [0x900000 0x100000] Size: 1.0MB
P25 (ABLBAK) [0xa00000 0x100000] Size: 1.0MB
P26 (DIP) [0xb00000 0x100000] Size: 1.0MB
P27 (DDR) [0xc00000 0x100000] Size: 1.0MB
P28 (TOOLSFV) [0xd00000 0x100000] Size: 1.0MB
P29 (DEVCFGBAK) [0xe00000 0x100000] Size: 1.0MB
P30 (DEVCFG) [0xf00000 0x100000] Size: 1.0MB
P31 (TZ) [0x1000000 0x400000] Size: 4.0MB
P32 (TZBAK) [0x1400000 0x400000] Size: 4.0MB
P33 (MDTPSECAPP) [0x1800000 0x400000] Size: 4.0MB
P34 (MDTPSECAPPBAK) [0x1c00000 0x400000] Size: 4.0MB
P35 (KEYMASTER) [0x2000000 0x100000] Size: 1.0MB
P36 (KEYMASTERBAK) [0x2100000 0x100000] Size: 1.0MB
P37 (BLUETOOTH) [0x2200000 0x100000] Size: 1.0MB
P38 (STI) [0x2300000 0x200000] Size: 2.0MB
P39 (XBL) [0x2500000 0x380000] Size: 3.500MB
P40 (XBLBAK) [0x2880000 0x380000] Size: 3.500MB
P41 (MISC) [0x2c00000 0x400000] Size: 4.0MB
P42 (DEVINFO) [0x3000000 0x800000] Size: 8.0MB
P43 (LOGFS) [0x3800000 0x800000] Size: 8.0MB
P44 (FSG) [0x4000000 0x800000] Size: 8.0MB
P45 (MODEMST1) [0x4800000 0x800000] Size: 8.0MB
P46 (MODEMST2) [0x5000000 0x800000] Size: 8.0MB
P47 (DSP) [0x5800000 0x1000000] Size: 16.0MB
P48 (BK1) [0x6800000 0x1800000] Size: 24.0MB
P49 (MDTP) [0x8000000 0x2000000] Size: 32.0MB
P50 (BK2) [0xa000000 0x2000000] Size: 32.0MB
P51 (SPLASH) [0xc000000 0x4000000] Size: 64.0MB
P52 (PERSIST) [0x10000000 0x2000000] Size: 32.0MB
P53 (PERSISTBAK) [0x12000000 0x2000000] Size: 32.0MB
P54 (LOGDUMP) [0x14000000 0x4000000] Size: 64.0MB
P55 (MODEM) [0x18000000 0xc000000] Size: 192.0MB
P56 (RAWDUMP) [0x24000000 0x8000000] Size: 128.0MB
P57 (BOOT) [0x2c000000 0x4000000] Size: 64.0MB
P58 (RECOVERY) [0x30000000 0x4000000] Size: 64.0MB
P59 (CACHE) [0x34000000 0x10000000] Size: 256.0MB
P60 (SYSTEM) [0x44000000 0xc0000000] Size: 3.0GB
P61 (VENDOR) [0x104000000 0x80000000] Size: 2.0GB
P62 (CUST) [0x184000000 0x34000000] Size: 832.0MB
P63 (USERDATA) [0x1b8000000 0xcd77fbe00] Size: 51.366GB
------ Android information ------
Detected LINUX(Android) SYSTEM : 0x0044000000 (3.0GB)
Unable to mount SYSTEM , code : 95
Detected USERDATA USERDATA : 0x01B8000000 (51.366GB)
Unable to mount USERDATA , code : 95
Userdata Superblock contents::
00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 ................................;
Done.
Old 09-16-2020, 15:07   #2 (permalink)
Member: 2097870
Sonork: FINDING....
Thanks Meter: 65
bga-254-2-in-1- I USE
Old 09-17-2020, 20:28   #3 (permalink)
layder's Avatar
Member: 13148
Thanks Meter: 2,948
post info abous UFS name (Marking)
Page generated in 0.15430 seconds with 8 queries
