05-05-2017, 23:50 | #1 (permalink) |
Junior Member Join Date: May 2017
Member: 2714160 Status: Offline Thanks Meter: 1 | eMMC 221 Detection Problem with Easy Jtag Box I have the following wired DATA0 <-> DAT0 CLK <-> CLKm CMD <-> CMD 1V8 <-> VCCQ 3V3 <-> VCC GND <-> VSS I've tried 50, 100, 330 pull up resistors on DATA0 and CMD lines, but every time I get the following output when trying to detect eMMC (KMQ310013B-B419). I've also tried varying the voltage and clock rates since I don't have the datasheet. FW Ver.: 01.55 CMD Pullup Level: 1773 mV CMD Active Level: 2691 mV Box IO Level: 2800 mV CLK Rate: 21000 khz HiPower mode is off! Can't init device, Reason: CMD Timeout Error Done. Any thoughts that might be going wrong? Wrong ground? Wrong pinout? |
The Following User Says Thank You to eight968 For This Useful Post: |
