12-22-2018, 12:22 | #1 (permalink) |
Junior Member Join Date: Jun 2016
Member: 2585827 Status: Offline Thanks Meter: 6 | EMMC BootArea Write Protection: Permanent for ROM2/ROM3 i have tow b214 emmc when detected on easy plus give me error EMMC BootArea Write Protection: Permanent for ROM2/ROM3 this emmc have problem ?how solve this problems ? Code: Setting interface to EasyJtag2/E-Socket Setting bus width to 8 Bit Setting frequence to 42 Mhz EMMC Device Information : EMMC CID: 150100464E31324D420672BFF2729335 EMMC CSD: D02701320F5903FFF6DBFFEF8E40400D EMMC Manufacture : SAMSUNG , EMMC NAME: FN12MB , HEX: 464E31324D42 , S/N: 72BFF272 , rev. 0x06 EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 9/2016 EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 512 KB (000000080000) EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC BootArea Write Protection: Permanent for ROM2/ROM3 Extended CSD Information : Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01) Boot configuration [PARTITION_CONFIG]: 0x00 , Boot from: no boot Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: FN12MB_72BFF272_20181222_144518.extcsd EMMC Init completed. Scanning soft partitions Partition table not found Get firmware version Firmware info not found |
12-22-2018, 14:35 | #2 (permalink) | |
Product Supporter Join Date: Jun 2002 Location: Belarus Age: 47
Member: 13148 Status: Offline Thanks Meter: 2,948 | Quote:
I have A001 eMMC and A003 eMMC. How I can update firmware on it? Second: it's a eMMC Write Protecttion - You can't erase/write ROM2/3 OTP register - One Time Programing eMMC registers | |
The Following 4 Users Say Thank You to layder For This Useful Post: |
