eMMC Toshiba read problem Hi everyone, I have this emmc of a Samsung N7505 that I need to read.
Unfortunately unlike others I get this error, the thing that seems strange to me is that it is recognized ...
I use the adapter Z3x 6in1 v1.0
What can it be?
Thanks Code:
Setting interface to EasyJtag2/E-Socket
Setting bus width to 1 Bit
Setting frequence to 1 MHz
EMMC Device Information :
EMMC CID: 1101003031364745320423D258EA81FB
EMMC CSD: D05E00320F5903FFFFFFFFEF924000D3
EMMC Manufacture : TOSHIBA , EMMC NAME: 016GE2 , HEX: 303136474532 , S/N: 23D258EA , rev. 0x04
EMMC Manufacture ID: 0x11 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 8/2014
EMMC ROM 1 (Main User Data) Capacity: 15028 MB (0003AB400000)
EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000)
EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 0 , Response: Clean
EMMC Permanent Write Protection: No
EMMC Temporary Write Protection: No
Extended CSD Information :
Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01)
Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1)
Boot Bus Config: 0x01 , width 4bit
H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled
Supported partition features [PARTITIONING_SUPPORT]: 0x07
Device supports partitioning features
Device can have enhanced technological features in partitions and user data area
Device can have extended partitions attribute
Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00
Backup saved: 016GE2_23D258EA_20200723_110022.extcsd
EMMC Init completed.
Warning: Health report is very BAD
Device Life Time Estimation (MLC) [269]: 0x00 Not defined
Device Life Time Estimation (SLC) [268]: 0x0B Exceeded its maximum estimated device life time
Pre EOL information [267]: 0x01 Normal
Scanning soft partitions
Error reading at address: 000000000000 , error: -1, CMD Timeout Error ... Retry #1
Error reading at address: 000000000000 , error: -3, DATA RCV Timeout Error ... Retry #2
Error reading at address: 000000000000 , error: -3, DATA RCV Timeout Error ... Retry #3
Error reading at address: 000000000000 , error: -3, DATA RCV Timeout Error ... Retry #4
Error reading at address: 000000000000 , error: -3, DATA RCV Timeout Error ... Retry #5
Too many errors. Reading has been stopped |
