07-23-2020, 10:09 | #1 (permalink) |
Junior Member Join Date: Apr 2016
Member: 2565480 Status: Offline Thanks Meter: 0 | eMMC Toshiba read problem Unfortunately unlike others I get this error, the thing that seems strange to me is that it is recognized ... I use the adapter Z3x 6in1 v1.0 What can it be? Thanks Code: Setting interface to EasyJtag2/E-Socket Setting bus width to 1 Bit Setting frequence to 1 MHz EMMC Device Information : EMMC CID: 1101003031364745320423D258EA81FB EMMC CSD: D05E00320F5903FFFFFFFFEF924000D3 EMMC Manufacture : TOSHIBA , EMMC NAME: 016GE2 , HEX: 303136474532 , S/N: 23D258EA , rev. 0x04 EMMC Manufacture ID: 0x11 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 8/2014 EMMC ROM 1 (Main User Data) Capacity: 15028 MB (0003AB400000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 0 , Response: Clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01) Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x01 , width 4bit H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: 016GE2_23D258EA_20200723_110022.extcsd EMMC Init completed. Warning: Health report is very BAD Device Life Time Estimation (MLC) [269]: 0x00 Not defined Device Life Time Estimation (SLC) [268]: 0x0B Exceeded its maximum estimated device life time Pre EOL information [267]: 0x01 Normal Scanning soft partitions Error reading at address: 000000000000 , error: -1, CMD Timeout Error ... Retry #1 Error reading at address: 000000000000 , error: -3, DATA RCV Timeout Error ... Retry #2 Error reading at address: 000000000000 , error: -3, DATA RCV Timeout Error ... Retry #3 Error reading at address: 000000000000 , error: -3, DATA RCV Timeout Error ... Retry #4 Error reading at address: 000000000000 , error: -3, DATA RCV Timeout Error ... Retry #5 Too many errors. Reading has been stopped |
