06-25-2022, 13:28 | #1 (permalink) |
Junior Member Join Date: Dec 2007
Member: 649636 Status: Offline Thanks Meter: 2 | Z3x UFS/BGA 254 and KM2V8001CM chip read problem Anybody solution ? I try socket solution - remove 47 Ohm resistor and solder 22ohm, no change, still error. Phone - tested 2x A52 5G (A526B) |
06-25-2022, 13:32 | #2 (permalink) |
Member: 649636 Status: Offline Thanks Meter: 2 | Code: Z3X EasyJtag EMMC File Manager v 1.22 Source: EasyJtag Port [UFS] Generation: GPT [QC/SAMS/BCM/INTEL/MTK] UFS Power Mode: LOW Scanner Thread Created.. Running EasyJtag UFS Mode... UFS ISP Mode: ON UFS Safe Mode: ON Initialize UFS Engine Fail. Code: -113/ERROR_UFS_UPIU_NOP_RESULT_FAIL Scanner Thread Terminated Elapsed: 00:00:08:552 Found 0 Partition(s).. Search Partitions Fail.. Check Socket/UFS Chip and Try Again.. Source: Qualcomm 9008 EMMC/UFS/AUTO Generation: GPT [QC/SAMS/BCM/INTEL/MTK] Box Voltage set to: 1800 mV Scanner Thread Created.. Config: 1011111111101111 Setup HiPower CLK: OFF Connecting To EasyJtag Plus Box: 1800mV/21MHz/AUTO EasyJtag Plus Box Found! Result: 0/OK EasyJtag Plus Box FirmWare: 2.53.2 Box Bus Width = 8 BIT Box Hardware = EasyJtag 2nd Generation Use Qlm 9008 (EDL) Mode.. Please Connect Qlm Device in 9008 (EDL) Mode.. Selected Primary Memory Type: AUTO Waiting For Device.. Found Device: Path: \\?\usb#vid_05c6&pid_9008#6&5280d8e&0&2#{86e0d1e0-8089-11d0-9ce4-08003e301f73} Desc: Qualcomm HS-USB QDLoader 9008 HWID: USB\VID_05C6&PID_9008&REV_0000 Name: Qualcomm HS-USB QDLoader 9008 (COM5) Vendor: Qualcomm Incorporated Trying Connect to Device.. Open Port OK Sahara OK, Get Data.. Read Qualcomm CPU Info OK S/N: 0x6C0C0FBC HW ID: 0x001630E100200000 -> SAMSUNG HASH: 0x4F855D6F545C16AA0C3040108640E91418F12CA54B3F2A505F41B16D5B7B933866AB0E4CAC8519FAFC33BD4C021F6C53 PBL : 0x00000001 HASH TYPE: SHA384 DEV HASH: 0x0000003BF6A6 CPU : Undefined CPU: 001630E100200000 Loader Not Found. Break.. Try Select Manually.. Init Device Fail. Break.. Scanner Thread Terminated Elapsed: 00:00:00:848 Found 0 Partition(s).. Search Partitions Fail.. Check Qlm Device and Try Again.. |
02-16-2023, 11:40 | #3 (permalink) |
Major Poster Join Date: Jun 2014 Location: indonesia
Member: 2213131 Status: Offline Thanks Meter: 6 | same problem Source: EasyJtag Port [UFS] Generation: GPT [QC/SAMS/BCM/INTEL/MTK] UFS Power Mode: HIGH Scanner Thread Created.. Running EasyJtag UFS Mode... UFS ISP Mode: ON UFS Safe Mode: ON Initialize UFS Engine Fail. Code: -113/ERROR_UFS_UPIU_NOP_RESULT_FAIL Scanner Thread Terminated Elapsed: 00:00:08:437 Found 0 Partition(s).. Search Partitions Fail.. Check Socket/UFS Chip and Try Again.. |
02-16-2023, 16:17 | #5 (permalink) |
Member: 2213131 Status: Offline Thanks Meter: 6 | ufs bga 254 micron Running EasyJtag UFS Mode... UFS ISP Mode: OFF UFS Safe Mode: ON Initialize UFS Engine Fail. Code: -112/ERROR_UFS_UPIU_BOOT_FAIL Scanner Thread Terminated Elapsed: 00:00:06:236 Found 0 Partition(s).. Search Partitions Fail.. Check Socket/UFS Chip and Try Again.. Source: EasyJtag Port [UFS] Generation: GPT [QC/SAMS/BCM/INTEL/MTK] UFS Power Mode: HIGH Scanner Thread Created.. Running EasyJtag UFS Mode... UFS ISP Mode: OFF UFS Safe Mode: ON Initialize UFS Engine Fail. Code: -112/ERROR_UFS_UPIU_BOOT_FAIL Scanner Thread Terminated Elapsed: 00:00:12:589 Found 0 Partition(s).. Search Partitions Fail.. Check Socket/UFS Chip and Try Again.. |
02-26-2023, 14:41 | #6 (permalink) |
Product Supporter Join Date: Jun 2002 Location: Belarus Age: 47
Member: 13148 Status: Offline Thanks Meter: 2,952 | |
