07-13-2020, 15:10 | #1 (permalink) |
No Life Poster Join Date: Nov 2014
Member: 2289628 Status: Offline Thanks Meter: 226 | Failed to create Repartition How to enable Repartition option ? Code: eMMC_tool Suite ver. 1.6.3.0 (release date: 23.06.2020) Microsoft Windows 10 (64 bit) build 19041 (10.0.19041.329) Looking for EasyJTAG box... EasyJTAG API ver. 3401 EasyJTAG Box Serial = 06942E3DA29E480D Card Serial = AA79A19D EasyJTAG Box Firmware = 2.5201 Changelog: 23.06.2020 (ver 1.6.3.0) Fix: Bugs that have been found through your crash report Setting interface to EasyJtag2/E-Socket Setting bus width to 8 Bit Setting frequence to 42 MHz EMMC Device Information : EMMC CID: 15010052345A314D42029D125470620F EMMC CSD: D02701320F5903FFF6DBFFEF92404009 EMMC Manufacture : SAMSUNG , EMMC NAME: R4Z1MB , HEX: 52345A314D42 , S/N: 9D125470 , rev. 0x02 EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 6/2015 EMMC ROM 1 (Main User Data) Capacity: 29820 MB (000747C00000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 2048 KB (000000200000) EMMC RPMB (Replay Protected Memory Block) Capacity: 128 KB (000000020000) Counter: 0 , Response: Clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01) Boot configuration [PARTITION_CONFIG]: 0x00 , Boot from: no boot Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: R4Z1MB_9D125470_20200713_184108.extcsd EMMC Init completed. Get firmware version Firmware info not found Opening file: MT6592_Android_scatter (new_format).txt The new format of scatter config_version: V1.1.1 platform: MT6592 preloader.bin Found 6 supported eMMC CID: name = 'R821MB' hex = 0x523832314D42 [SAMSUNG] KMR820001M-B609/16GB+LPDDR3 16Gb @BGA221 name = 'R8X1MB' hex = 0x523858314D42 [SAMSUNG] KMR8X0001M-B608/16GB @BGA221 name = 'HAG2e' hex = 0x484147326505 [SKHYNIX] eNAND_H26M52103FMR/16GB @FBGA169 eNAND_H9TQ17A8GTMCUR-KTM/16GB @BGA221 eNAND_H9TQ17A8GTMCUR-KUM/16GB @BGA221 eNAND_H9TQ17ABJTMCUR-KTM/16GB @BGA221 eNAND_H9TQ17ABJTMCUR-KUM/16GB @BGA221 name = 'R4Z1MB' hex = 0x52345A314D42 [SAMSUNG] name = 'R4Z1AB' hex = 0x52345A314142 [SAMSUNG] KMR4Z0001A-B803/32GB @BGA221 name = 'Q4Z3MB' hex = 0x51345A334D42 [SAMSUNG] KMQ4Z0013M-B809/32GB @BGA221 Warning: ROM2 has a small size The size of the last section has been updated Operation: Write by vendor (MediaTek) Partition name: PRELOADER Filename: preloader.bin , Offset: 000000000000 , filesize: 123848 bytes eMMC switching to ROM2 Erasing partition... Writing partition... Done writing partition. Write speed: 1308.42 KB/s Partition name: MBR Filename: mbr.bin , Offset: 000000000000 , filesize: 524288 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 6607.88 KB/s Partition name: PRELOADER Error: Could not open file: C:\Program Files\Z3X\EASYJTAGPLUS\Temp\preloader.bin Partition name: EBR1 Filename: ebr1.bin , Offset: 000000080000 , filesize: 524288 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 3804.41 KB/s Partition name: PRO_INFO Filename: pro_info.bin , Offset: 000000100000 , filesize: 3145728 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 8638.51 KB/s Partition name: NVRAM Filename: nvram.bin , Offset: 000000400000 , filesize: 5242880 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 9457.32 KB/s Partition name: PROTECT_F Filename: protect_f.bin , Offset: 000000900000 , filesize: 10485760 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 11122.87 KB/s Partition name: PROTECT_S Filename: protect_s.bin , Offset: 000001300000 , filesize: 10485760 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 19629.56 KB/s Partition name: SECCFG Filename: seccfg.bin , Offset: 000001D00000 , filesize: 262144 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 3073.47 KB/s Partition name: UBOOT Filename: uboot.bin , Offset: 000001D40000 , filesize: 393216 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 7579.47 KB/s Partition name: BOOTIMG Filename: bootimg.bin , Offset: 000001DA0000 , filesize: 10485760 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 19745.26 KB/s Partition name: RECOVERY Filename: recovery.bin , Offset: 0000027A0000 , filesize: 10485760 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 17387.23 KB/s Partition name: SEC_RO Filename: sec_ro.bin , Offset: 0000031A0000 , filesize: 6291456 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 17386.93 KB/s Partition name: MISC Filename: misc.bin , Offset: 0000037A0000 , filesize: 524288 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 5545.80 KB/s Partition name: LOGO Filename: logo.bin , Offset: 000003820000 , filesize: 8388608 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 16771.02 KB/s Partition name: EXPDB Filename: expdb.bin , Offset: 000004020000 , filesize: 16646144 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 20230.10 KB/s Partition name: ANDROID Filename: android.bin , Offset: 000005000000 , filesize: 1577058304 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 20835.47 KB/s Partition name: CACHE Filename: cache.bin , Offset: 000063000000 , filesize: 134217728 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 23773.63 KB/s Writing DL_Info... Writing DL_Info done Partition USRDATA : formatting as EXT4. Please wait ... Formatting completed Operation: Writing BootConfig ... Reg: 179 Value: 0x48 Reg: 177 Value: 0x00 Reg: 162 Value: 0x01 Done All done time: [00:01:55:085] Setting interface to EasyJtag2/E-Socket Setting bus width to 8 Bit Setting frequence to 42 MHz EMMC Device Information : EMMC CID: 15010052345A314D42029D125470620F EMMC CSD: D02701320F5903FFF6DBFFEF92404009 EMMC Manufacture : SAMSUNG , EMMC NAME: R4Z1MB , HEX: 52345A314D42 , S/N: 9D125470 , rev. 0x02 EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 6/2015 EMMC ROM 1 (Main User Data) Capacity: 29820 MB (000747C00000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 2048 KB (000000200000) EMMC RPMB (Replay Protected Memory Block) Capacity: 128 KB (000000020000) Counter: 0 , Response: Clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01) Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: R4Z1MB_9D125470_20200713_184647.extcsd EMMC Init completed. Get firmware version GPT header is not found GPT header is not found Brand = Infinix Manufacturer = Infinix Device = Infinix_X509 Model = Infinix X509 CPU Abi = armeabi-v7a Mediatek platform = MT6592 Android release = 4.4.2 Firmware version = X509-J5800-KK-20150826 Firmware date = Thu Aug 27 13:16:01 CST 2015 Operation: Find table from emmc Vendor: Mediatek Platform: MT6592 Searching GPT ... GPT header is not found Searching PMT (MediaTek) ... PMT not found Partition table not found Operation: Reading S.M.A.R.T Report ... Device Life Time Estimation (MLC) [269]: 0x01 0% - 10% device life time used Device Life Time Estimation (SLC) [268]: 0x01 0% - 10% device life time used Pre EOL information [267]: 0x01 Normal Optimal Read Size [266]: 0x00 Not defined Optimal Write Size [265]: 0x18 96 KB Optimal Trim Unit Size [264]: 0x01 4 KB |
07-13-2020, 15:36 | #2 (permalink) |
No Life Poster Join Date: Aug 2017 Location: India
Member: 2746336 Status: Offline Sonork: NULL Thanks Meter: 47 | Same problem is happening after updating to the latest version of easy jtag classic, many problems in this tool after firmware upgrade of easy jtag plus box, old version was running very smoothly and was able to repair many emmc, but now this box is not repairing any phones, please team fix it fast..... |
07-13-2020, 16:12 | #3 (permalink) | |
Member: 2289628 Status: Offline Thanks Meter: 226 | Quote:
Even I tried on some different model with microscope but still I face that big dinosaur error from the beginning of the box history. Even this eMMC failed to create partition on Medusa Pro. Otherwise Easy Jtag Team work is flawless. I want to confirm from Mr.Layder what is the reason of this error ? | |
07-13-2020, 16:29 | #5 (permalink) | |
Product Supporter Join Date: Jun 2002 Location: Belarus Age: 47
Member: 13148 Status: Offline Thanks Meter: 2,948 | Quote:
CMD - "Command" pin Box work with eMMC via CMD line, and use CLOCK line for sinchronize command If signal level not normally detect, or device CPU pull down CMD line or eMMC DEAD - we have CMD timeout error if you have problems with detectiton you can change IO levels at program interface, reduce freqence, add pull-up resistors as at ISP pictures for CMD DATA (100-200 Ohm) | |
07-13-2020, 16:32 | #6 (permalink) | |
We add new algo for ISP levels detection | |
The Following User Says Thank You to layder For This Useful Post: |
07-13-2020, 17:16 | #7 (permalink) | |
MBR for old MediaTek GPT for new MediaTek Then how to re-partition/revive this device ? If I write full dump and write preloader or full flash then mobile will boot up or no ? help me here how to rid of this emmc ? | |
07-13-2020, 20:29 | #8 (permalink) | |
Member: 2746336 Status: Offline Sonork: NULL Thanks Meter: 47 | Quote:
