04-06-2019, 14:54 | #1 (permalink) |
No Life Poster Join Date: Apr 2013 Location: $Kathmandu Nepal$
Member: 1911970 Status: Offline Sonork: 9741081772 Thanks Meter: 2,080 | Nokia 2 TA-1029 Emmc Dump Backup Success Code: Setting frequence to 21 Mhz CMD Pullup Level: 2072 mV CMD Active Level: 2619 mV EMMC Device Information : EMMC CID: 90014A483847346132A5189208BF840A EMMC CSD: D02701328F5903FFFFFFFFE78A400016 EMMC Manufacture : SKHYNIX , EMMC NAME: H8G4a2 , HEX: 483847346132 , S/N: 189208BF , rev. 0xA5 EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Date: 8/2017 EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x38 , Boot from: ROM1 (Main User Area) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: H8G4a2_189208BF_20190406_132019.extcsd EMMC Init completed. Get firmware version Brand = Unknown Manufacturer = FIH Device = Unknown Model = Unknown Phone platform = msm8909 CPU Abi = armeabi-v7a Android release = 7.1.1 Firmware version = 00WW_0_64A Firmware date = Sun Jan 7 18:45:49 CST 2018 Setting frequence to 21 Mhz CMD Pullup Level: 2062 mV CMD Active Level: 2619 mV EMMC Device Information : EMMC CID: 90014A483847346132A5189208BF840A EMMC CSD: D02701328F5903FFFFFFFFE78A400016 EMMC Manufacture : SKHYNIX , EMMC NAME: H8G4a2 , HEX: 483847346132 , S/N: 189208BF , rev. 0xA5 EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Date: 8/2017 EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x38 , Boot from: ROM1 (Main User Area) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: H8G4a2_189208BF_20190406_132031.extcsd EMMC Init completed. Operation: Reading from eMMC... Reading from: ROM1 , start: 0x000000000000 , size: 0x000020000000 Output file: C:\Users\Salina\Desktop\0\TA-1029\EMMC_H8G4a2_ROM1_000000000000_000020000000.bin eMMC switching to ROM1 Reading partition... Error reading at address: 000011400000 , error: -2, CMD CRC Error ... Retry #1 Done reading partition. Read speed: 946.74 Kb/s All done time: [00:09:20:306] Setting frequence to 21 Mhz CMD Pullup Level: 2052 mV CMD Active Level: 2619 mV EMMC Device Information : EMMC CID: 90014A483847346132A5189208BF840A EMMC CSD: D02701328F5903FFFFFFFFE78A400016 EMMC Manufacture : SKHYNIX , EMMC NAME: H8G4a2 , HEX: 483847346132 , S/N: 189208BF , rev. 0xA5 EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Date: 8/2017 EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x38 , Boot from: ROM1 (Main User Area) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: H8G4a2_189208BF_20190406_133007.extcsd EMMC Init completed. Operation: Reading from eMMC... Reading from: ROM2 , start: 0x000000000000 , size: 0x000000400000 Output file: C:\Users\Salina\Desktop\0\TA-1029\EMMC_H8G4a2_ROM2_000000000000_000000400000.bin eMMC switching to ROM2 Reading partition... Done reading partition. Read speed: 532.68 Kb/s All done time: [00:00:14:192] Setting frequence to 21 Mhz CMD Pullup Level: 2062 mV CMD Active Level: 2619 mV EMMC Device Information : EMMC CID: 90014A483847346132A5189208BF840A EMMC CSD: D02701328F5903FFFFFFFFE78A400016 EMMC Manufacture : SKHYNIX , EMMC NAME: H8G4a2 , HEX: 483847346132 , S/N: 189208BF , rev. 0xA5 EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Date: 8/2017 EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x38 , Boot from: ROM1 (Main User Area) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: H8G4a2_189208BF_20190406_133033.extcsd EMMC Init completed. Operation: Reading from eMMC... Reading from: ROM3 , start: 0x000000000000 , size: 0x000000400000 Output file: C:\Users\Salina\Desktop\0\TA-1029\EMMC_H8G4a2_ROM3_000000000000_000000400000.bin eMMC switching to ROM3 Reading partition... Done reading partition. Read speed: 532.81 Kb/s All done time: [00:00:14:186] |
The Following User Says Thank You to raisalina For This Useful Post: |
