Old 06-27-2020, 07:12   #16 (permalink)
hafiz4saqib's Avatar
Member: 2289628
Thanks Meter: 226
Galaxy G532G MediaTek port shwoing even after repair Bootloader
Galaxy G532G wont boot up after write dump from server or even write PIT+BL files.
I also tried dump of G532F but result is same.
Only showing MediaTek Port on PC.
Setting interface to EasyJtag2/ISP
Setting bus width to 1 Bit
Setting frequence to 36 MHz
CMD Pullup Level: 697 mV
CMD Active Level: 1845 mV
EMMC Device Information :
EMMC CID: 90014A4838473475920116D2405B7463
EMMC CSD: D02701320F5903FFFFFFFFE78A40002B
EMMC Manufacture : SKHYNIX , EMMC NAME: H8G4u , HEX: 483847347500 , S/N: 16D2405B , rev. 0x01
EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Date: 7/2017
   EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000)
   EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000)
   EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 0 , Response: Maybe not clean
EMMC Permanent Write Protection: No
EMMC Temporary Write Protection: No
Extended CSD Information :
Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01)
Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1)
Boot Bus Config: 0x00 , width 1bit
H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled
Supported partition features [PARTITIONING_SUPPORT]: 0x07
Device supports partitioning features
Device can have enhanced technological features in partitions and user data area
Device can have extended partitions attribute
Partition Settings [PARTITION_SETTING_COMPLETED]: 0x01
Backup saved: H8G4u_16D2405B_20200627_100121.extcsd
EMMC Init completed.
Get firmware version
Firmware info not found
CMD Pullup Level: 698 mV
Backup saved: H8G4u_16D2405B_20200627_100129.extcsd
Operation: Universal Factory Format
Please, wait ...
Successfully
Backup saved: H8G4u_16D2405B_20200627_100152.extcsd
Opening file: GRANDPPLTE_CIS_SER.pit
Pit: GRANDPPLTE_CIS_SER.pit
Entry count: 34
The size of the last section has been updated
BL_G532GDXU1AQK1_CL12551713_QB15688219_REV00_user_low_ship_MULTI_CERT.tar.md5
The list of files in the firmware:
preloader.img
lk.bin
param.bin
trustzone.bin
efuse.img
CMD Active Level: 1846 mV
Backup saved: H8G4u_16D2405B_20200627_100203.extcsd
Operation: Write by vendor (Samsung)
Creating GPT-partitioninig
Writing PrimaryGPT at address: 000000000000
Writing BackupGPT at address: 0001D1FFBE00
Writing PIT at address: 000000004400
GPT-partitioning done
Unpacking file: preloader.img
Unpacking file: lk.bin
Unpacking file: efuse.img
Unpacking file: trustzone.bin
Unpacking file: param.bin
Partition name: BOOTLOADER
Filename: preloader.img , Offset: 000000000000 , filesize: 170240 bytes
eMMC switching to ROM2
Erasing partition...
Writing partition...
Done writing partition. Write speed: 548.55 KB/s
Partition name: LK
Filename: lk.bin , Offset: 000001000000 , filesize: 590336 bytes
eMMC switching to ROM1
Done writing partition. Write speed: 1878.61 KB/s
Partition name: EFUSE
Filename: efuse.img , Offset: 000001B80000 , filesize: 768 bytes
Done writing partition. Write speed: 33.67 KB/s
Partition name: TEE1
Filename: trustzone.bin , Offset: 000001C00000 , filesize: 324352 bytes
Done writing partition. Write speed: 2338.40 KB/s
Partition name: PARAM
Filename: param.bin , Offset: 000005000000 , filesize: 747520 bytes
Done writing partition. Write speed: 3551.93 KB/s
Partition EFS : formatting as EXT4. Please wait ...
Formatting completed
Partition CACHE : formatting as EXT4. Please wait ...
Partition HIDDEN : formatting as EXT4. Please wait ...
Partition USERDATA : formatting as EXT4. Please wait ...
Check BootConfig for the selected vendor
All done   time: [00:00:19:857]
CMD Pullup Level: 699 mV
CMD Active Level: 1844 mV
Backup saved: H8G4u_16D2405B_20200627_100248.extcsd
Filename: H8G4u_16D2405B_20200627_093145.extcsd
Operation: Writing BootConfig ...
Reg: 179  Value: 0x48
Reg: 177  Value: 0x00
Reg: 162  Value: 0x01
Done
Operation: Reading S.M.A.R.T Report ...
Device Life Time Estimation (MLC) [269]: 0x01   0% - 10% device life time used
Device Life Time Estimation (SLC) [268]: 0x01   0% - 10% device life time used
Pre EOL information [267]: 0x01   Normal
Optimal Read Size [266]: 0x40   256 KB
Optimal Write Size [265]: 0x40   256 KB
Optimal Trim Unit Size [264]: 0x07   28 KB
Old 06-27-2020, 11:16   #17 (permalink)
Member: 1972033
Thanks Meter: 32
do u have old info ??
Old 06-27-2020, 11:38   #18 (permalink)
Member: 2289628
Thanks Meter: 226
Right now!! I dont have.
If I get then I will share here.
Old 06-27-2020, 12:35   #19 (permalink)
Member: 1630066
Sonork: 520074
Thanks Meter: 215
download file from here it is tested file https://tii.ai/haVHNSC
full erase emmc even rom2 and rom3 than write this file
The Following User Says Thank You to ilyasrao For This Useful Post:
Old 06-27-2020, 13:09   #20 (permalink)
Member: 2289628
Thanks Meter: 226
Thanks for your help.
Its too late now because customer has taken the mobile from me. He dont have much time.
Page generated in 0.15511 seconds with 8 queries
