06-27-2020, 07:12 | #16 (permalink) |
No Life Poster Join Date: Nov 2014
Member: 2289628 Status: Offline Thanks Meter: 226 | Galaxy G532G MediaTek port shwoing even after repair Bootloader Galaxy G532G wont boot up after write dump from server or even write PIT+BL files. I also tried dump of G532F but result is same. Only showing MediaTek Port on PC. Code: Setting interface to EasyJtag2/ISP Setting bus width to 1 Bit Setting frequence to 36 MHz CMD Pullup Level: 697 mV CMD Active Level: 1845 mV EMMC Device Information : EMMC CID: 90014A4838473475920116D2405B7463 EMMC CSD: D02701320F5903FFFFFFFFE78A40002B EMMC Manufacture : SKHYNIX , EMMC NAME: H8G4u , HEX: 483847347500 , S/N: 16D2405B , rev. 0x01 EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Date: 7/2017 EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 0 , Response: Maybe not clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01) Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x01 Backup saved: H8G4u_16D2405B_20200627_100121.extcsd EMMC Init completed. Get firmware version Firmware info not found Setting interface to EasyJtag2/ISP Setting bus width to 1 Bit Setting frequence to 36 MHz CMD Pullup Level: 698 mV CMD Active Level: 1845 mV EMMC Device Information : EMMC CID: 90014A4838473475920116D2405B7463 EMMC CSD: D02701320F5903FFFFFFFFE78A40002B EMMC Manufacture : SKHYNIX , EMMC NAME: H8G4u , HEX: 483847347500 , S/N: 16D2405B , rev. 0x01 EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Date: 7/2017 EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 0 , Response: Maybe not clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01) Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x01 Backup saved: H8G4u_16D2405B_20200627_100129.extcsd EMMC Init completed. Operation: Universal Factory Format Please, wait ... Successfully Setting interface to EasyJtag2/ISP Setting bus width to 1 Bit Setting frequence to 36 MHz CMD Pullup Level: 697 mV CMD Active Level: 1845 mV EMMC Device Information : EMMC CID: 90014A4838473475920116D2405B7463 EMMC CSD: D02701320F5903FFFFFFFFE78A40002B EMMC Manufacture : SKHYNIX , EMMC NAME: H8G4u , HEX: 483847347500 , S/N: 16D2405B , rev. 0x01 EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Date: 7/2017 EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 0 , Response: Maybe not clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01) Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x01 Backup saved: H8G4u_16D2405B_20200627_100152.extcsd EMMC Init completed. Opening file: GRANDPPLTE_CIS_SER.pit Pit: GRANDPPLTE_CIS_SER.pit Entry count: 34 The size of the last section has been updated BL_G532GDXU1AQK1_CL12551713_QB15688219_REV00_user_low_ship_MULTI_CERT.tar.md5 The list of files in the firmware: preloader.img lk.bin param.bin trustzone.bin efuse.img Setting interface to EasyJtag2/ISP Setting bus width to 1 Bit Setting frequence to 36 MHz CMD Pullup Level: 698 mV CMD Active Level: 1846 mV EMMC Device Information : EMMC CID: 90014A4838473475920116D2405B7463 EMMC CSD: D02701320F5903FFFFFFFFE78A40002B EMMC Manufacture : SKHYNIX , EMMC NAME: H8G4u , HEX: 483847347500 , S/N: 16D2405B , rev. 0x01 EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Date: 7/2017 EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 0 , Response: Maybe not clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01) Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x01 Backup saved: H8G4u_16D2405B_20200627_100203.extcsd EMMC Init completed. Operation: Write by vendor (Samsung) Creating GPT-partitioninig Writing PrimaryGPT at address: 000000000000 Writing BackupGPT at address: 0001D1FFBE00 Writing PIT at address: 000000004400 GPT-partitioning done Unpacking file: preloader.img Unpacking file: lk.bin Unpacking file: efuse.img Unpacking file: trustzone.bin Unpacking file: param.bin Partition name: BOOTLOADER Filename: preloader.img , Offset: 000000000000 , filesize: 170240 bytes eMMC switching to ROM2 Erasing partition... Writing partition... Done writing partition. Write speed: 548.55 KB/s Partition name: LK Filename: lk.bin , Offset: 000001000000 , filesize: 590336 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1878.61 KB/s Partition name: EFUSE Filename: efuse.img , Offset: 000001B80000 , filesize: 768 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 33.67 KB/s Partition name: TEE1 Filename: trustzone.bin , Offset: 000001C00000 , filesize: 324352 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 2338.40 KB/s Partition name: PARAM Filename: param.bin , Offset: 000005000000 , filesize: 747520 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 3551.93 KB/s Partition EFS : formatting as EXT4. Please wait ... Formatting completed Partition CACHE : formatting as EXT4. Please wait ... Formatting completed Partition HIDDEN : formatting as EXT4. Please wait ... Formatting completed Partition USERDATA : formatting as EXT4. Please wait ... Formatting completed Check BootConfig for the selected vendor All done time: [00:00:19:857] Setting interface to EasyJtag2/ISP Setting bus width to 1 Bit Setting frequence to 36 MHz CMD Pullup Level: 699 mV CMD Active Level: 1844 mV EMMC Device Information : EMMC CID: 90014A4838473475920116D2405B7463 EMMC CSD: D02701320F5903FFFFFFFFE78A40002B EMMC Manufacture : SKHYNIX , EMMC NAME: H8G4u , HEX: 483847347500 , S/N: 16D2405B , rev. 0x01 EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Date: 7/2017 EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 0 , Response: Maybe not clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01) Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x01 Backup saved: H8G4u_16D2405B_20200627_100248.extcsd EMMC Init completed. Filename: H8G4u_16D2405B_20200627_093145.extcsd Operation: Writing BootConfig ... Reg: 179 Value: 0x48 Reg: 177 Value: 0x00 Reg: 162 Value: 0x01 Done Operation: Reading S.M.A.R.T Report ... Device Life Time Estimation (MLC) [269]: 0x01 0% - 10% device life time used Device Life Time Estimation (SLC) [268]: 0x01 0% - 10% device life time used Pre EOL information [267]: 0x01 Normal Optimal Read Size [266]: 0x40 256 KB Optimal Write Size [265]: 0x40 256 KB Optimal Trim Unit Size [264]: 0x07 28 KB |
06-27-2020, 12:35 | #19 (permalink) |
No Life Poster Join Date: Aug 2011
Member: 1630066 Status: Offline Sonork: 520074 Thanks Meter: 215 | download file from here it is tested file https://tii.ai/haVHNSC full erase emmc even rom2 and rom3 than write this file |
The Following User Says Thank You to ilyasrao For This Useful Post: |
06-27-2020, 13:09 | #20 (permalink) | |
Member: 2289628 Status: Offline Thanks Meter: 226 | Quote:
Its too late now because customer has taken the mobile from me. He dont have much time. | |
