G615f dead boot HI G615F DEAD AFTER WRITE COMBINATION FOR BYPASS FRP eMMC_tool Suite ver. 1.6.4.0 (release date: 30.12.2020) Microsoft Windows 7 (64 bit) build 7601 (6.1.7601.18015) Looking for EasyJTAG box... EasyJTAG API ver. 3403 EasyJTAG Box Serial = 0A00E013F603DAEE Card Serial = AAEC997E EasyJTAG Box Firmware = 1.6300 Changelog: 30.12.2020 (ver 1.6.4.0) Add: New keys for Oppo unpack Fix: Fix LG Parser Fix: Bugs that have been found through your crash report Add: new version 2.0.0.0 (qualcomm, samsung) Failed to connect to the server HiPower mode is ON Setting frequence to 7 MHz CMD Pullup Level: 3258 mV CMD Active Level: 3196 mV EMMC Device Information : EMMC CID: 150100525831344D4200AC509B9484FA EMMC CSD: D02701320F5903FFF6DBFFEF8E40400C EMMC Manufacture : SAMSUNG , EMMC NAME: RX14MB , HEX: 525831344D42 , S/N: AC509B94 , rev. 0x00 EMMC ROM 1 (Main User Data) Capacity: 29820 MB (000747C00000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 0 , Response: Maybe not clean Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [179] / Boot Bus Config [177] / H/W Reset Function [162]: 0x48 / 0x04 / 0x01 Supported partition features [PARTITIONING_SUPPORT]: 0x07 Backup saved: RX14MB_AC509B94_20210220_183049.extcsd EMMC Init completed. Opening file: CSC_ODD_G615FODD2BTA1_CL17814974_QB28702658_REV00_ user_low_ship_MULTI_CERT.tar.md5 Unpacking PIT from CSC Pit: J7MAXLTE_SWA_INS.pit Entry count: 36 The size of the last section has been updated BL_G615FXXS2BTF2_CL17814974_QB32389218_REV00_user_ low_ship_MULTI_CERT.tar.md5 The list of files in the firmware: preloader.img.lz4 lk.bin.lz4 trustzone.bin.lz4 param.bin.lz4 efuse.img.lz4 AP_G615FXXS2BTF2_CL17814974_QB32389218_REV00_user_ low_ship_MULTI_CERT_meta.tar.md5 The list of files in the firmware: boot.img.lz4 recovery.img.lz4 system.img.lz4 meta-data/ meta-data/fota.zip CP_G615FXXS2BTE1_CP16009679_CL17814974_QB31706879_ REV00_user_low_ship_MULTI_CERT.tar.md5 The list of files in the firmware: md1rom.img CSC_ODD_G615FODD2BTA1_CL17814974_QB28702658_REV00_ user_low_ship_MULTI_CERT.tar.md5 The list of files in the firmware: j7maxlte_swa_ins.pit cache.img.lz4 hidden.img.lz4 HiPower mode is ON Setting frequence to 7 MHz CMD Pullup Level: 3289 mV CMD Active Level: 3196 mV EMMC Device Information : EMMC CID: 150100525831344D4200AC509B9484FA EMMC CSD: D02701320F5903FFF6DBFFEF8E40400C EMMC Manufacture : SAMSUNG , EMMC NAME: RX14MB , HEX: 525831344D42 , S/N: AC509B94 , rev. 0x00 EMMC ROM 1 (Main User Data) Capacity: 29820 MB (000747C00000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 0 , Response: Maybe not clean Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [179] / Boot Bus Config [177] / H/W Reset Function [162]: 0x48 / 0x04 / 0x01 Supported partition features [PARTITIONING_SUPPORT]: 0x07 Backup saved: RX14MB_AC509B94_20210220_183113.extcsd EMMC Init completed. Operation: Write by vendor (Samsung) Creating GPT-partitioninig Writing PrimaryGPT at address: 000000000000 Writing BackupGPT at address: 000747BFBE00 Writing PIT at address: 000000004400 GPT-partitioning done Unpacking file: preloader.img Unpacking Lz4: preloader.img.lz4 Unpacking file: lk.bin Unpacking Lz4: lk.bin.lz4 Unpacking file: efuse.img Unpacking Lz4: efuse.img.lz4 Unpacking file: trustzone.bin Unpacking Lz4: trustzone.bin.lz4 Unpacking file: param.bin Unpacking Lz4: param.bin.lz4 Unpacking file: recovery.img Unpacking Lz4: recovery.img.lz4 Unpacking file: boot.img Unpacking Lz4: boot.img.lz4 Unpacking file: md1rom.img Unpacking file: system.img Unpacking Lz4: system.img.lz4 Unpacking file: cache.img Unpacking Lz4: cache.img.lz4 Unpacking file: hidden.img Unpacking Lz4: hidden.img.lz4 Partition name: BOOTLOADER Filename: preloader.img , Offset: 000000000000 , filesize: 221440 bytes eMMC switching to ROM2 Erasing partition... Writing partition... Done writing partition. Write speed: 296.42 KB/s Partition name: LK Filename: lk.bin , Offset: 000000400000 , filesize: 1202320 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 533.66 KB/s Partition name: EFUSE Filename: efuse.img , Offset: 000000700000 , filesize: 768 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 23.09 KB/s Partition name: TEE1 Filename: trustzone.bin , Offset: 000001000000 , filesize: 436672 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 745.65 KB/s Partition name: PARAM Filename: param.bin , Offset: 000007800000 , filesize: 1658880 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 761.48 KB/s Partition name: RECOVERY Filename: recovery.img , Offset: 000008000000 , filesize: 19767568 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 779.75 KB/s Partition name: BOOT Filename: boot.img , Offset: 000009800000 , filesize: 12734736 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 775.81 KB/s Partition name: MD1IMG Filename: md1rom.img , Offset: 00000B000000 , filesize: 96253552 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 778.12 KB/s Partition name: SYSTEM Filename: system.img , Offset: 000013000000 , filesize: 2972671088 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Sparse image found v.1.0 Total chunks: 4549 Done writing partition. Write speed: 763.25 KB/s Partition name: CACHE Filename: cache.img , Offset: 0000D3000000 , filesize: 97321344 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Sparse image found v.1.0 Total chunks: 22 Done writing partition. Write speed: 774.95 KB/s Partition name: HIDDEN Filename: hidden.img , Offset: 0000EE000000 , filesize: 87089824 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Sparse image found v.1.0 Total chunks: 40 Done writing partition. Write speed: 772.12 KB/s Check BootConfig for the selected vendor All done time: [01:13:36:662] HiPower mode is ON Setting frequence to 7 MHz CMD Pullup Level: 3279 mV CMD Active Level: 3186 mV EMMC Device Information : EMMC CID: 150100525831344D4200AC509B9484FA EMMC CSD: D02701320F5903FFF6DBFFEF8E40400C EMMC Manufacture : SAMSUNG , EMMC NAME: RX14MB , HEX: 525831344D42 , S/N: AC509B94 , rev. 0x00 EMMC ROM 1 (Main User Data) Capacity: 29820 MB (000747C00000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 0 , Response: Maybe not clean Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [179] / Boot Bus Config [177] / H/W Reset Function [162]: 0x48 / 0x04 / 0x01 Supported partition features [PARTITIONING_SUPPORT]: 0x07 Backup saved: RX14MB_AC509B94_20210220_222058.extcsd EMMC Init completed. Get firmware version Brand = samsung Manufacturer = samsung Device = j7maxlte Model = SM-G615F Phone platform = mt6757 CPU Abi = armeabi-v7a Mediatek platform = MT6757 Android release = 8.1.0 Security Patch = 2020-06-01 Firmware version = M1AJQ.G615FXXS2BTF2 Firmware date = Wed Jun 24 18:51:30 KST 2020 BUT PHONE IS STEAL DEAD .... I NEED HELP THANKS |
