Old 02-20-2021, 21:53   #1 (permalink)
Member: 1391134
Thanks Meter: 47
G615f dead boot
HI
G615F DEAD AFTER WRITE COMBINATION FOR BYPASS FRP
eMMC_tool Suite ver. 1.6.4.0 (release date: 30.12.2020)
Microsoft Windows 7 (64 bit) build 7601 (6.1.7601.18015)
Looking for EasyJTAG box...
EasyJTAG API ver. 3403
EasyJTAG Box Serial = 0A00E013F603DAEE
Card Serial = AAEC997E
EasyJTAG Box Firmware = 1.6300
Changelog:
30.12.2020 (ver 1.6.4.0)
Add: New keys for Oppo unpack
Fix: Fix LG Parser
Fix: Bugs that have been found through your crash report
Add: new version 2.0.0.0 (qualcomm, samsung)
Failed to connect to the server
HiPower mode is ON
Setting frequence to 7 MHz
CMD Pullup Level: 3258 mV
CMD Active Level: 3196 mV
EMMC Device Information :
EMMC CID: 150100525831344D4200AC509B9484FA
EMMC CSD: D02701320F5903FFF6DBFFEF8E40400C
EMMC Manufacture : SAMSUNG , EMMC NAME: RX14MB , HEX: 525831344D42 , S/N: AC509B94 , rev. 0x00
EMMC ROM 1 (Main User Data) Capacity: 29820 MB (000747C00000)
EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000)
EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 0 , Response: Maybe not clean
Extended CSD Information :
Extended CSD rev: 1.8 (MMC 5.1)
Boot configuration [179] / Boot Bus Config [177] / H/W Reset Function [162]: 0x48 / 0x04 / 0x01
Supported partition features [PARTITIONING_SUPPORT]: 0x07
Backup saved: RX14MB_AC509B94_20210220_183049.extcsd
EMMC Init completed.
Opening file: CSC_ODD_G615FODD2BTA1_CL17814974_QB28702658_REV00_ user_low_ship_MULTI_CERT.tar.md5
Unpacking PIT from CSC
Pit: J7MAXLTE_SWA_INS.pit
Entry count: 36
The size of the last section has been updated
BL_G615FXXS2BTF2_CL17814974_QB32389218_REV00_user_ low_ship_MULTI_CERT.tar.md5
The list of files in the firmware:
preloader.img.lz4
lk.bin.lz4
trustzone.bin.lz4
param.bin.lz4
efuse.img.lz4
AP_G615FXXS2BTF2_CL17814974_QB32389218_REV00_user_ low_ship_MULTI_CERT_meta.tar.md5
boot.img.lz4
recovery.img.lz4
system.img.lz4
meta-data/
meta-data/fota.zip
CP_G615FXXS2BTE1_CP16009679_CL17814974_QB31706879_ REV00_user_low_ship_MULTI_CERT.tar.md5
md1rom.img
j7maxlte_swa_ins.pit
cache.img.lz4
hidden.img.lz4
HiPower mode is ON
CMD Pullup Level: 3289 mV
Backup saved: RX14MB_AC509B94_20210220_183113.extcsd
Operation: Write by vendor (Samsung)
Creating GPT-partitioninig
Writing PrimaryGPT at address: 000000000000
Writing BackupGPT at address: 000747BFBE00
Writing PIT at address: 000000004400
GPT-partitioning done
Unpacking file: preloader.img
Unpacking Lz4: preloader.img.lz4
Unpacking file: lk.bin
Unpacking Lz4: lk.bin.lz4
Unpacking file: efuse.img
Unpacking Lz4: efuse.img.lz4
Unpacking file: trustzone.bin
Unpacking Lz4: trustzone.bin.lz4
Unpacking file: param.bin
Unpacking Lz4: param.bin.lz4
Unpacking file: recovery.img
Unpacking Lz4: recovery.img.lz4
Unpacking file: boot.img
Unpacking Lz4: boot.img.lz4
Unpacking file: md1rom.img
Unpacking file: system.img
Unpacking Lz4: system.img.lz4
Unpacking file: cache.img
Unpacking Lz4: cache.img.lz4
Unpacking file: hidden.img
Unpacking Lz4: hidden.img.lz4
Partition name: BOOTLOADER
Filename: preloader.img , Offset: 000000000000 , filesize: 221440 bytes
eMMC switching to ROM2
Erasing partition...
Writing partition...
Done writing partition. Write speed: 296.42 KB/s
Partition name: LK
Filename: lk.bin , Offset: 000000400000 , filesize: 1202320 bytes
eMMC switching to ROM1
Done writing partition. Write speed: 533.66 KB/s
Partition name: EFUSE
Filename: efuse.img , Offset: 000000700000 , filesize: 768 bytes
Done writing partition. Write speed: 23.09 KB/s
Partition name: TEE1
Filename: trustzone.bin , Offset: 000001000000 , filesize: 436672 bytes
Done writing partition. Write speed: 745.65 KB/s
Partition name: PARAM
Filename: param.bin , Offset: 000007800000 , filesize: 1658880 bytes
Done writing partition. Write speed: 761.48 KB/s
Partition name: RECOVERY
Filename: recovery.img , Offset: 000008000000 , filesize: 19767568 bytes
Done writing partition. Write speed: 779.75 KB/s
Filename: boot.img , Offset: 000009800000 , filesize: 12734736 bytes
Done writing partition. Write speed: 775.81 KB/s
Partition name: MD1IMG
Filename: md1rom.img , Offset: 00000B000000 , filesize: 96253552 bytes
Done writing partition. Write speed: 778.12 KB/s
Partition name: SYSTEM
Filename: system.img , Offset: 000013000000 , filesize: 2972671088 bytes
Sparse image found v.1.0 Total chunks: 4549
Done writing partition. Write speed: 763.25 KB/s
Partition name: CACHE
Filename: cache.img , Offset: 0000D3000000 , filesize: 97321344 bytes
Sparse image found v.1.0 Total chunks: 22
Done writing partition. Write speed: 774.95 KB/s
Partition name: HIDDEN
Filename: hidden.img , Offset: 0000EE000000 , filesize: 87089824 bytes
Sparse image found v.1.0 Total chunks: 40
Done writing partition. Write speed: 772.12 KB/s
Check BootConfig for the selected vendor
All done time: [01:13:36:662]
HiPower mode is ON
CMD Pullup Level: 3279 mV
CMD Active Level: 3186 mV
Backup saved: RX14MB_AC509B94_20210220_222058.extcsd
Get firmware version
Brand = samsung
Manufacturer = samsung
Device = j7maxlte
Model = SM-G615F
Phone platform = mt6757
CPU Abi = armeabi-v7a
Mediatek platform = MT6757
Android release = 8.1.0
Security Patch = 2020-06-01
Firmware version = M1AJQ.G615FXXS2BTF2
Firmware date = Wed Jun 24 18:51:30 KST 2020
BUT PHONE IS STEAL DEAD ....
I NEED HELP THANKS
Page generated in 0.14046 seconds with 8 queries
