04-14-2017, 20:00 | #3 (permalink) |
No Life Poster Join Date: Apr 2014 Location: west java
Member: 2162000 Status: Offline Sonork: 100.1670061 Thanks Meter: 205 | check your clock component after direct change or make bridge. use 8 or 16 gb write with 512 from support done. ps u need resize after that |
The Following User Says Thank You to solusi hp For This Useful Post: |
04-15-2017, 03:50 | #6 (permalink) |
Freak Poster Join Date: Dec 2006 Location: Philippines
Member: 405730 Status: Offline Thanks Meter: 184 | change emmc again to 4gb but same error heres the logs Loading eMMC Addon Firmware... IO: 2800 mV Box S/N: 0A01000FA6681181, ,FW Ver.: 01.58 CMD Pullup Level:2114 mV CMD Active Level:2423 mV Box IO Level:2800 mV CLK Rate:21000 khz HiPower mode is off! ---------- eMMC Device Information ---------- EMMC CID : 1501004A4A5330304103A2743B0D90A6 EMMC CSD : D02701320F5903FFF6DBFFE78A404056 EMMC Manufacturer ID: 0015 , OEM ID: 0100 EMMC Date: 09/2013 Rev.0x3 EMMC NAME: JJS00A , S/N: 2725526285 EMMC NAME (HEX): 4A4A5330304100 EMMC ROM1 (Main User Data) Capacity: 3724 MB EMMC ROM2 (Boot Partition 1) Capacity: 2048 kB EMMC ROM3 (Boot Partition 2) Capacity: 2048 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.5 (MMC 4.41) Boot configuration [PARTITION_CONFIG: 0x00] No boot partition configured. Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x00. H/W reset function [RST_N_FUNCTION]: 0x00 High-capacity W protect group size [HC_WP_GRP_SIZE: 0x00000000] Partitioning Support [PARTITIONING_SUPPORT]: 0x03 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: JJS00A_2725526285_20170415_1027.extcsd Done. Checking NAND Image : D:\EasyJtag\SAMSUNG Repair files\GT-I8190\512mb_OK_locked\512mb_OK_locked.bin Autodetected RAW data File successefuly loaded! Processing file...D:\EasyJtag\SAMSUNG Repair files\GT-I8190\512mb_OK_locked\512mb_OK_locked.bin Writing as RAW data Z3X EasyJtag Software ver. 2.5.0.8 Skip loading eMMC Addon Firmware CMD Pullup Level:2114 mV CMD Active Level:2423 mV Input file : D:\EasyJtag\SAMSUNG Repair files\GT-I8190\512mb_OK_locked\512mb_OK_locked.bin Writing 0020000000 bytes to 0000000000... ROM1 (USER ROM) Done. Write Speed: 634 kB/s |
04-15-2017, 10:06 | #8 (permalink) |
Freak Poster Join Date: Sep 2007 Age: 36
Member: 579725 Status: Offline Sonork: 100.1675677 Thanks Meter: 96 | first try to check with new emmc ,, becuz i dont think so u have any problem to change emmc one more time then fash with fectory firmware , if stil u have same ishuu then bro check charging ic ,, also audio ic , in samsung thay have problem some times |
04-16-2017, 13:40 | #9 (permalink) | |
No Life Poster Join Date: Feb 2008 Location: Brunei Age: 34
Member: 704097 Status: Offline Sonork: 100.1607742 Thanks Meter: 820 | sorry for late refly https://www.4shared.com/rar/-eR-hKv-...90_512mb.html? try it: *update emmc firmware *set config Quote:
*flash repair file if still the same try to change cmd resistor(kuha ka sa cmd ng ibang board,pwede mo rin subukan jumper) | |
The Following User Says Thank You to Sniper_04 For This Useful Post: |
04-17-2017, 06:09 | #10 (permalink) |
Member: 405730 Status: Offline Thanks Meter: 184 | solved! cant find any 8gb emmc so i used 16gb emmc EasyJtag Suite Classic ver.: 2.5.0.8 / wxWidgets 3.1.0-W-U started. OS ver.: Windows 7 (build 7600). Admin rights FAIL undefined Android Explorer ver.: 1.0.0.23 eMMC ODIN ver.: 1.0.11.2 Successfully connected to box on COM9 Box S/N: 0A01000FA6681181, ,FW Ver.: 01.58 Box Working Mode: JTAG Box. Box Drivers version: 3.0.1.0, are OK Z3X Card Serial : AA1D-8D87 , ver: 22 Z3X Card Activation [LG] : NOT ACTIVATED Z3X Card Activation [SAMS] : ACTIVATED Z3X Card Activation [JTAG] : ACTIVATED Z3X EasyJtag Software ver. 2.5.0.8 Loading eMMC Addon Firmware... IO: 2800 mV Box S/N: 0A01000FA6681181, ,FW Ver.: 01.58 CMD Pullup Level:1815 mV CMD Active Level:2784 mV Box IO Level:2800 mV CLK Rate:21000 khz HiPower mode is off! ---------- eMMC Device Information ---------- EMMC CID : 1501004D4147344642F1011E9E617FEC EMMC CSD : D02701320F5903FFF6DBFFFF8E40406C EMMC Manufacturer ID: 0015 , OEM ID: 0100 EMMC Date: 07/2012 Rev.0xF1 EMMC NAME: MAG4FB , S/N: 18783841 EMMC NAME (HEX): 4D414734464200 EMMC ROM1 (Main User Data) Capacity: 15028 MB EMMC ROM2 (Boot Partition 1) Capacity: 2048 kB EMMC ROM3 (Boot Partition 2) Capacity: 2048 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.6 (MMC 4.5) Boot configuration [PARTITION_CONFIG: 0x00] No boot partition configured. Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x00. H/W reset function [RST_N_FUNCTION]: 0x00 High-capacity W protect group size [HC_WP_GRP_SIZE: 0x00000000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: MAG4FB_ 18783841_20170417_1218.extcsd Done. Checking NAND Image : C:\Users\Ralel\Downloads\Compressed\GT-I8190 512mb\GT-I8190 512mb\USERDATA.bin Autodetected RAW data File successefuly loaded! Processing file...C:\Users\Ralel\Downloads\Compressed\GT-I8190 512mb\GT-I8190 512mb\USERDATA.bin Writing as RAW data Z3X EasyJtag Software ver. 2.5.0.8 Skip loading eMMC Addon Firmware CMD Pullup Level:1815 mV CMD Active Level:2784 mV Input file : C:\Users\Ralel\Downloads\Compressed\GT-I8190 512mb\GT-I8190 512mb\USERDATA.bin Writing 0020000000 bytes to 0000000000... ROM1 (USER ROM) Retry writing adress 0x000F000000 (Attempt #0)... Retry Success! Done. Write Speed: 648 kB/s |
The Following User Says Thank You to ralel For This Useful Post: |
