Old 01-27-2022, 18:13   #1 (permalink)
Member: 1984825
Thanks Meter: 222
Remove password oppo a7 with easy king
EasyJtag Suite Classic ver.: 3.7.0.24 / wxWidgets 3.1.3-W-U started.
OS ver.: Windows 10 (build 19044), 64-bit edition. Admin rights FAIL
Autorun Agent ver:1.0.0.0
Crash Reporting ver:1.4.0.3
EasyJTAG SPI Plugin ver:1.1.1.13
Android ADB API ver:2.0.0.0
FTDI API ver:3.2.4.0
LibUSB API ver:1.2.6.0
Visual C++ Runtime ver:10.0.30319.1
Setting box Pinout ...
Box Drivers version: 10.0.19041.1202
Z3X Card Serial : AAC7-581A , ver: 22
Z3X Card Activation [JTAGPLUS] : ACTIVATED
Z3X Card Activation [LG] : NOT ACTIVATED
Z3X Card Activation [SAMS] : NOT ACTIVATED
Z3X Card Activation [JTAG] : ACTIVATED
For more information press F1 to open local help or visit our wiki
Found 4 serial devices
COM30 USB\VID_1781&PID_AAAC&REV_0100&MI_00 Périphérique série USB (COM30)
COM3 Intel(R) Active Management Technology - SOL (COM3)
COM22 root\rimports RIM Virtual Serial Port v2 (COM22)
COM23 root\rimports RIM Virtual Serial Port v2 (COM23)
Selected pinout: GEN2 High Speed Pinout
Change EasyJTAG Pinout OK
Selected pinout: GEN2 ISP Pinout
Z3X EasyJtag Software ver. 3.7.0.24
Loading eMMC GEN2 Firmware... IO: 2800 mV
Box S/N: 00000000000000, ,FW Ver.: 02.53
CMD Pullup Level:869 mV
CMD Active Level:1967 mV
Box IO Level:2800 mV
CLK Rate:24000 kHz
Bus Width:1bit,SDR
HiPower mode is off!
Can't init device, Reason: CMD Timeout Error
Done.
Box S/N: 0000000000000000, ,FW Ver.: 02.53
CMD Pullup Level:2127 mV
CMD Active Level:2340 mV
CLK Rate:24000 kHz
Bus Width:1bit,SDR
Done.
Loading eMMC GEN2 Firmware... IO: 1800 mV
Box S/N: 000000000000E384, ,FW Ver.: 02.53
CMD Pullup Level:1867 mV
CMD Active Level:1862 mV
Box IO Level:1800 mV
CLK Rate:24000 kHz
Bus Width:1bit,SDR
Done.
CMD Active Level:2354 mV
CLK Rate:24000 kHz
Bus Width:1bit,SDR
Done.
Box S/N: 00000000000004, ,FW Ver.: 02.53
CMD Pullup Level:2128 mV
CLK Rate:24000 kHz
Bus Width:1bit,SDR
Done.
Loading eMMC GEN2 Firmware... IO: 3000 mV
CMD Pullup Level:2139 mV
CMD Active Level:2521 mV
Box IO Level:3000 mV
CLK Rate:24000 kHz
Bus Width:1bit,SDR
Done.
Box S/N: 000000000000000, ,FW Ver.: 02.53
CMD Active Level:2355 mV
CLK Rate:36000 kHz
Bus Width:1bit,SDR
Done.
Box S/N: 000000000000, ,FW Ver.: 02.53
CMD Pullup Level:358 mV
CMD Active Level:1027 mV
CLK Rate:36000 kHz
Bus Width:1bit,SDR
Done.
CMD Pullup Level:2105 mV
CMD Active Level:2268 mV
CLK Rate:36000 kHz
Bus Width:1bit,SDR
---------- eMMC Device Information ----------
eMMC CID : 150100524836344142055B1C9A15B5EF
eMMC CSD : D02701320F5903FFF6DBFFEF8E40400D
eMMC Manufacturer ID: 0015 , OEM ID: 0100
eMMC Date: 11/2018 Rev.0x5
eMMC NAME: RH64AB , S/N: 1528601109
eMMC NAME (HEX): 524836344142
IC Name: Samsung , KMRH60014A-B614 , Firmware is Updatable
EMMC ROM1 (Main User Data) Capacity: 59640 MB
EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB
EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB
EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB
EMMC RPMB is programmed and written 62163 times
EMMC Permanent Write Protection: No
EMMC Temporary Write Protection: No
EMMC Password Locked: No
Extended CSD rev 1.8 (MMC 5.1)
Boot configuration [PARTITION_CONFIG: 0x38] Boot from:ROM1 (Main User Area)
Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x38.
H/W reset function [RST_N_FUNCTION]: 0x01
High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000]
Partitioning Support [PARTITIONING_SUPPORT]: 0x07
Device support partitioning feature
Device can have enhanced tech.
Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00
Backup saved: RH64AB_1528601109_20220127_1730.extcsd
The protective MBR's 0xEE partition is oversized! Auto-repairing.
Found valid GPT with protective MBR; using GPT.
Real (Hardware) Disk/Image size: 747C000 sectors 58.2 GiB
Soft (Partitioned) Disk/Image size: 747BFBC sectors 58.2 GiB
Disk identifier (GUID): 98101B32-BBE2-4BF2-A06E-2BB33D000C20
Logical sector size: 0x200 bytes ,First/Last usable sector: 34,122142686
Partition info successfully found
------ Android information ------
Detected LINUX(Android) SYSTEM : 0x003E800000 (3.968GB)
Short EXT fs info:
Block size: 4.0KB
Inode size: 256
Inodes: 256000
Short Android info:
Build ID: OPM1.171019.026
Release Base ID: 8.1.0
Security Path: 2021-03-05
Architecture ABI: arm64-v8a
Device manufacturer: OPPO
Build Description: msm8953_64-user 8.1.0 OPM1.171019.026 eng.root.20210307.122638 release-keys
Backup saved: BuildProp_20220127_1730.txt
Detected USERDATA USERDATA : 0x017E800000 (52.264GB)
Unable to mount USERDATA , code : 95
Userdata Superblock contents::
DCDD263B 909B6A7E 2CEE5D62 F1987696 2C8A5E92 14F00DB4 EBD489F3 CEC1BA8B ÜÝ&;.›j~,î]bñ.v–,Š^’.ð.´ëÔ‰óÎÁº‹;
1C03BBB8 9BB6A4CF D899C079 2A43FDA1 67C15403 FAD3A464 1EF84D51 D626EC19 ..»¸›¶¤ÏØ.Ày*Cý¡gÁT.úÓ¤d.øMQÖ&ì.;
D44CD5FC DEDF8B9D 75E3275D 15124422 B44DAFC4 ADC157EC 7DD5818A 8EC81B61 ÔLÕüÞß‹.uã']..D"´M¯Ä*ÁWì}Õ.ŠŽÈ.a;
D96384F0 BAD1C1E7 C76D70F9 CEBEDDEC D44A4C4E 7B4689E9 BC67290C 82588A4A Ùc„ðºÑÁçÇmpùξÝìÔJLN{F‰é¼g).‚XŠJ;
D1602025 9AE2AF20 59E76E2C 743325DD CFCABE98 1662E596 C2833C90 3AC5ADF0 Ñ` %šâ¯ Yçn,t3%ÝÏʾ..bå–ƒ<.:Å*ð;
2803CC26 61CF2372 08110D51 25E64E63 E82FCB3C 6E4C150D 077F56CD ECD11D9E (.Ì&aÏ#r...Q%æNcè/Ë<nL....VÍìÑ.ž;
50C876AD 23722367 C575AF94 8A391CD3 AFCF68D0 A459C511 F4BE055C B341D04D PÈv*#r#gÅu¯”Š9.Ó¯ÏhФYÅ.ô¾.\³AÐM;
DF54318D 117F67B6 0362AA39 BA0A0BA6 95691B82 4313EED7 600C7AE1 5C628EA9 ßT1...g¶.bª9º..¦•i.‚C.î×`.zá\bŽ©;
Done.
CMD Pullup Level:2106 mV
CMD Active Level:2348 mV
CLK Rate:36000 kHz
Bus Width:1bit,SDR
Backup saved: RH64AB_1528601109_20220127_1732.extcsd
Short EXT fs info:
Block size: 4.0KB
Inode size: 256
Inodes: 256000
Short Android info:
Backup saved: BuildProp_20220127_1732.txt
Done.
Checking security ...
CMD Active Level:2349 mV
CLK Rate:36000 kHz
Bus Width:1bit,SDR
EMMC ROM1 (Main User Data) Capacity: 59640 MB , 0x747C000 pages , 0xE8F800000 bytes
Writing Recovery Command to MISC
Done.
CMD Pullup Level:2108 mV
CMD Active Level:2351 mV
CLK Rate:36000 kHz
Bus Width:1bit,SDR
Done.
CLK Rate:36000 kHz
Bus Width:1bit,SDR
Backup saved: RH64AB_1528601109_20220127_1733.extcsd
Short EXT fs info:
Block size: 4.0KB
Inode size: 256
Inodes: 256000
Short Android info:
Backup saved: BuildProp_20220127_1733.txt
Done.
Page generated in 0.16336 seconds with 8 queries
