07-21-2020, 07:25 | #1 (permalink) |
No Life Poster Join Date: Feb 2008 Location: Hell..... Bcoz i am devil_king Age: 38
Member: 696623 Status: Offline Sonork: 100.1601050 Thanks Meter: 526 | [HELP] mi note 6 pro pin lock reset without data loss mi note 6 pro pin lock reset without data loss is this possible , if then how .......... Code: Checking security ... Running:Reset PIN/PASS/GESTURE Locks Z3X EasyJtag Software ver. 3.7.0.17 Loading eMMC GEN2 Firmware... IO: 1800 mV Box S/N: 3F**************, ,FW Ver.: 02.52 CMD Pullup Level:1823 mV CMD Active Level:1885 mV Box IO Level:1800 mV CLK Rate:24000 kHz Bus Width:1bit,SDR HiPower mode is off! ---------- eMMC Device Information ---------- eMMC CID : 90014A68433861503E0361B175D9165F eMMC CSD : D02700328F5903FFFFFFFFEF8E400043 eMMC Manufacturer ID: 0090 , OEM ID: 014A eMMC Date: 01/2019 Rev.0x3 eMMC NAME: hC8aP> , S/N: 1639019993 eMMC NAME (HEX): 68433861503E EMMC ROM1 (Main User Data) Capacity: 59640 MB , 0x747C000 pages , 0xE8F800000 bytes EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 kB EMMC RPMB is programmed and written 60738 times EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG: 0x00] No boot partition configured. Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x00. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- The protective MBR's 0xEE partition is oversized! Auto-repairing. Found valid GPT with protective MBR; using GPT. Real (Hardware) Disk/Image size: 747C000 sectors 58.2 GiB Soft (Partitioned) Disk/Image size: 747BFBC sectors 58.2 GiB Disk identifier (GUID): 68BF5895-74EB-9675-291A-86486F45A6F9 Logical sector size: 0x200 bytes ,First/Last usable sector: 34,122142686 Partition info successfully found ------ Android information ------ Detected LINUX(Android) USERDATA : 0x01B8000000 (51.366GB) Mount EXT4 fs... Unable to mount USER , code : 95 --------------------------------------------- Done. |
