12-02-2020, 12:30 | #1 (permalink) |
No Life Poster Join Date: Mar 2010 Location: djerba
Member: 1269161 Status: Offline Thanks Meter: 119 | help in oppo a31 2020 cph2015 stuck in mediatek usb port !!! any help to repair this oppo cph2015 after reset password i have phone dead and connected in usb show mediatek usb port info with emmc : Code: Z3X EasyJtag Software ver. 3.7.0.11 Loading eMMC GEN1 Firmware... IO: 2800 mV Box S/N: 04040B05853D1B89, ,FW Ver.: 01.63 CMD Pullup Level:2000 mV CMD Active Level:2619 mV Box IO Level:2800 mV CLK Rate:21000 kHz Bus Width:1bit,SDR HiPower mode is ON! ---------- eMMC Device Information ---------- eMMC CID : 15010044483644414202C236685457C2 eMMC CSD : D02701320F5903FFF6DBFFEF8E40400C eMMC Manufacturer ID: 0015 , OEM ID: 0100 eMMC Date: 05/2020 Rev.0x2 eMMC NAME: DH6DAB , S/N: 3258345556 eMMC NAME (HEX): 444836444142 EMMC ROM1 (Main User Data) Capacity: 59640 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 kB EMMC RPMB is programmed and written 735 times EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG: 0x00] No boot partition configured. Boot bus config [177]: 0x02 , width 8bits , Partition config [179]: 0x00. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: DH6DAB_3258345556_20201202_1221.extcsd Found valid GPT with protective MBR; using GPT. Real (Hardware) Disk/Image size: 747C000 sectors 58.2 GiB Soft (Partitioned) Disk/Image size: 747BFBC sectors 58.2 GiB Disk identifier (GUID): 00000000-0000-0000-0000-000000000000 Logical sector size: 0x200 bytes ,First/Last usable sector: 34,122142686 Partition info successfully found ------ Android information ------ Detected LINUX(Android) SYSTEM : 0x0081000000 (6.0GB) Short EXT fs info: Size: 5.904GB Block size: 4.0KB Inode size: 256 Inodes: 387072 Short Android info: Unable to read prop.plist , code : 2 --------------------------------------------- Detected USERDATA USERDATA : 0x021C800000 (49.738GB) Unable to mount USERDATA , code : 95 Userdata Superblock contents:: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 ................................; 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 ................................; 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 ................................; 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 ................................; 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 ................................; 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 ................................; 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 ................................; 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 ................................; Done. thx |
12-02-2020, 16:23 | #2 (permalink) |
Member: 1269161 Status: Offline Thanks Meter: 119 | how flash oppo cph2015 via isp pinout? hi any help to flash oppo a31 2020 cph2015(Mediatek MT6765V/CB Helio P35 ) via isp pinout with easyjtag or easyjtagplus !! or flash only boot file ! i have rom in .ofp thx plz admin delete first threat thx Last edited by .:B-A-G:.; 12-02-2020 at 16:32. |
12-02-2020, 17:21 | #3 (permalink) |
Member: 1269161 Status: Offline Thanks Meter: 119 | this is info read by emmc file manager Code: Source: EasyJtag Port [EMMC/SD/MMC] Generation: PMT [MTK GENERIC] Box Voltage set to: 2800 mV Scanner Thread Created.. Config: 1011111111101111 Setup HiPower CLK: OFF Connecting To EasyJtag Box: 2800mV/21MHz/1BIT EasyJtag Box Found! Result: 0/OK CMD Pullup Level: 1990 mV CMD Active Level: 2557 mV EasyJtag S/N: 04040B05853D1B89 EasyJtag Box FirmWare: 1.63 Box Bus Width = 1 BIT Box Hardware = EasyJtag 1st Generation Search EMMC Chip... EMMC Chip Found! 0/OK EMMC CID: 15010044483644414202C236685457C2 EMMC CSD: D02701320F5903FFF6DBFFEF8E40400C EMMC VENDOR: SAMSUNG EMMC NAME: DH6DAB EMMC SERIAL: C2366854 EMMC REVISION: 02 EMMC ROM1 Size: 122142720 Block(s)/59640 MB EMMC ROM2/3 Size: 8192 Block(s)/4096 KB EMMC RPMB Size: 32768 Block(s)/16384 KB EMMC RPMB Counter: 735 EMMC RPMB Answer: 0/OK Switch To ROM1 Part: 0/OK EMMC REV: 1.8 (for MMC v5.1) EMMC VER: MMC 5.1 EMMC DEV Life Time: 0x01 -> Normal EMMC MLC Life Time: 0x01 -> 0% - 10% Life Time Used EMMC SLC Life Time: 0x01 -> 0% - 10% Life Time Used EMMC Boot Config: 0x00/0x02/0x01 ExtCSD Automatically Saved.. Scanning Data From EMMC. Please wait.. Scanning GUID Partition Table from ROM1 GUID Partition Table is Found. Max Parts: 128 GPT: GPT [000000000000 - 000000004400] Size: 17,00 KB GPT: BOOT_PARA [000000008000 - 000000100000] Size: 1,00 MB GPT: RECOVERY [000000108000 - 000002000000] Size: 32,00 MB GPT: PARA [000002108000 - 000000080000] Size: 512,00 KB GPT: OPPORESERVE1 [000002188000 - 000000800000] Size: 8,00 MB GPT: OPPORESERVE2 [000002988000 - 000004000000] Size: 64,00 MB GPT: OPPORESERVE3 [000006988000 - 000004000000] Size: 64,00 MB GPT: OPPO_CUSTOM [00000A988000 - 000000100000] Size: 1,00 MB GPT: EXPDB [00000AA88000 - 000001400000] Size: 20,00 MB GPT: FRP [00000BE88000 - 000000100000] Size: 1,00 MB GPT: NVCFG [00000BF88000 - 000002000000] Size: 32,00 MB GPT: NVDATA [00000DF88000 - 000004000000] Size: 64,00 MB GPT: METADATA [000011F88000 - 000002000000] Size: 32,00 MB GPT: PROTECT1 [000013F88000 - 000000800000] Size: 8,00 MB GPT: PROTECT2 [000014788000 - 000000878000] Size: 8,47 MB GPT: SECCFG [000015000000 - 000000800000] Size: 8,00 MB GPT: PERSIST [000015800000 - 000003000000] Size: 48,00 MB GPT: SEC1 [000018800000 - 000000200000] Size: 2,00 MB GPT: PROINFO [000018A00000 - 000000300000] Size: 3,00 MB GPT: MD1IMG [000018D00000 - 000006400000] Size: 100,00 MB GPT: SPMFW [00001F100000 - 000000100000] Size: 1,00 MB GPT: SCP1 [00001F200000 - 000000100000] Size: 1,00 MB GPT: SCP2 [00001F300000 - 000000100000] Size: 1,00 MB GPT: SSPM_1 [00001F400000 - 000000100000] Size: 1,00 MB GPT: SSPM_2 [00001F500000 - 000000100000] Size: 1,00 MB GPT: GZ1 [00001F600000 - 000001000000] Size: 16,00 MB GPT: GZ2 [000020600000 - 000001000000] Size: 16,00 MB GPT: NVRAM [000021600000 - 000004000000] Size: 64,00 MB GPT: LK [000025600000 - 000000500000] Size: 5,00 MB GPT: LK2 [000025B00000 - 000000500000] Size: 5,00 MB GPT: BOOT [000026000000 - 000002000000] Size: 32,00 MB GPT: LOGO [000028000000 - 000001000000] Size: 16,00 MB GPT: DTBO [000029000000 - 000001000000] Size: 16,00 MB GPT: TEE1 [00002A000000 - 000000500000] Size: 5,00 MB GPT: TEE2 [00002A500000 - 000000B00000] Size: 11,00 MB GPT: ODM [00002B000000 - 000010000000] Size: 256,00 MB GPT: VENDOR [00003B000000 - 000046000000] Size: 1,09 GB GPT: SYSTEM [000081000000 - 000180000000] Size: 6,00 GB GPT: VBMETA [000201000000 - 000000800000] Size: 8,00 MB GPT: CACHE [000201800000 - 00001B000000] Size: 432,00 MB GPT: USERDATA [00021C800000 - 000C6F4FBE00] Size: 49,74 GB GPT: OTP [000E8BCFBE00 - 000002B00000] Size: 43,00 MB GPT: FLASHINFO [000E8E7FBE00 - 000001000000] Size: 16,00 MB GPT: BACKUP_GPT [000E8F7FBE00 - 000000004200] Size: 16,50 KB Reading Table Completed Scanning GUID Partition Table from ROM2 GPT Signature Not Found. Break.. Scanning GUID Partition Table from ROM3 GPT Signature Not Found. Break.. Partition #9 mount as [/mnt/vendor/opporeserve] -> 64,00 MB Partition #14 mount as [/mnt/vendor/nvcfg] -> 32,00 MB Partition #15 mount as [/mnt/vendor/nvdata] -> 64,00 MB Partition #17 mount as [/mnt/vendor/protect_f] -> 8,00 MB Partition #18 mount as [/mnt/vendor/protect_s] -> 8,47 MB Partition #20 mount as [/mnt/vendor/persist] -> 48,00 MB Partition #39 mount as [/dev_39] -> 256,00 MB Partition #40 mount as [/dev_40] -> 1,09 GB Partition #41 mount as [/dev_41] -> 6,00 GB EmptyCheck: EMPTY -> #11 - [EXPDB] EMPTY -> #12 - [FRP] EMPTY -> #15 - [METADATA] EMPTY -> #20 - [SEC1] EMPTY -> #28 - [GZ1] EMPTY -> #29 - [GZ2] EMPTY -> #42 - [CACHE] EMPTY -> #43 - [USERDATA] EMPTY -> #44 - [OTP] EmptyCheck: Done Android Info: Platform = mt6765 Android Info: Vendor = OPPO CPU ABI = arm64-v8a Android Version = 9 Security Patch = 2020-06-05 Android Info: Brand = OPPO Device = OP4C7D Model = CPH2015 Product = CPH2015 Firm Version = CPH2015EX_11_A.37 Inc. Version = 1591774286 Firm Date = Wed Jun 10 15:31:26 CST 2020 OPPO Name = OPPO A31 Scanner Thread Terminated Elapsed: 00:00:23:300 Found 47 Partition(s).. Scan Done. Init Main Engine... Resetting EasyJtag Box. Wait.. CMD Pullup Level: 2000 mV CMD Active Level: 2557 mV Reader Engine Initialized.. 0/OK Source: EasyJtag Port [EMMC/SD/MMC] Generation: PMT [MTK GENERIC] Operation Done: [Init Engine], Elapsed: 00:00:02:052 and this is info of emmc Code: Read Emmc Info.. EMMC CID : 15010044483644414202C236685457C2 EMMC CSD : D02701320F5903FFF6DBFFEF8E40400C EMMC Vendor ID : 0x15 EMMC Vendor : SAMSUNG EMMC Name : DH6DAB EMMC Name HEX : 444836444142 EMMC S/N : C2366854 EMMC Revision : 0x02 EMMC OEM ID : 0x00 EMMC Dev Type : BGA (Discrete embedded) EMMC Version : MMC 5.1 EMMC Date : 5/2020 Temp WR Protect : No Perm WR Protect : No EMMC ROM 1 Size : 59640 MB (0x000E8F800000) EMMC ROM 2/3 Size : 4096 KB (0x000000400000) EMMC RPMB Size : 16384 KB (0x000001000000) EXTCSD REV : Revision 1.8 (for MMC v5.1) EMMC Boot Config : 0x00/0x02/0x01 [PARTITION_CONFIG] : 0x00 [PARTITION_ACCESS] : No access to boot partition [PARTITION_ENABLE] : Device not boot enabled [BOOT_ACK] : No [BOOT_BUS_WIDTH] : x8 (sdr/ddr) bus width H/W Reset Function : 0x01, RST_n signal is permanently enabled Partition Features : 0x07 [PART SET_COMPLETED] : 0x00 Min GPx Size : 8,00 MB EMMC DEV Life Time : 0x01 -> Normal EMMC MLC Life Time : 0x01 -> 0% - 10% Life Time Used EMMC SLC Life Time : 0x01 -> 0% - 10% Life Time Used |
