05-06-2017, 13:17 | #1 (permalink) |
Freak Poster Join Date: May 2013 Location: algeria
Member: 1933548 Status: Offline Thanks Meter: 19 | help to programing i9195 new emmc i need correct configuration of i9195 emmc this is log info emmc check Z3X EasyJtag Software ver. 2.5.0.9 Loading eMMC Addon Firmware... IO: 3300 mV Box S/N: 0700100BE8057C5B, ,FW Ver.: 01.58 CMD Pullup Level:3186 mV CMD Active Level:3258 mV Box IO Level:3300 mV CLK Rate:14000 khz HiPower mode is ON! ---------- eMMC Device Information ---------- EMMC CID : 15010038574D423352009D026353518C EMMC CSD : D02701320F5903FFF6DBFFEF8E40400C EMMC Manufacturer ID: 0015 , OEM ID: 0100 EMMC Date: 05/2014 Rev.0x0 EMMC NAME: 8WMB3R , S/N: 2634179411 EMMC NAME (HEX): 38574D42335200 EMMC ROM1 (Main User Data) Capacity: 7456 MB EMMC ROM2 (Boot Partition 1) Capacity: 0 kB EMMC ROM3 (Boot Partition 2) Capacity: 0 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 0 kB EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.7 (MMC 5.0) Boot configuration [PARTITION_CONFIG: 0x00] No boot partition configured. Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x00. H/W reset function [RST_N_FUNCTION]: 0x00 High-capacity W protect group size [HC_WP_GRP_SIZE: 0x00000000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: 8WMB3R_2634179411_20170506_1305.extcsd --------------------------------------------- Done. and this is log after 1- movi nand format 2- movi nand format and reset 3-whrite extcsd 4-whrite I9195_Alive_BN file Z3X EasyJtag Software ver. 2.5.0.9 Loading eMMC Addon Firmware... IO: 3300 mV Box S/N: 0700100BE8057C5B, ,FW Ver.: 01.58 CMD Pullup Level:3186 mV CMD Active Level:3258 mV Box IO Level:3300 mV CLK Rate:14000 khz HiPower mode is ON! ---------- eMMC Device Information ---------- EMMC CID : 15010038574D423352009D026353518C EMMC CSD : D02701320F5903FFF6DBFFEF8E40400C EMMC Manufacturer ID: 0015 , OEM ID: 0100 EMMC Date: 05/2014 Rev.0x0 EMMC NAME: 8WMB3R , S/N: 2634179411 EMMC NAME (HEX): 38574D42335200 EMMC ROM1 (Main User Data) Capacity: 7456 MB EMMC ROM2 (Boot Partition 1) Capacity: 0 kB EMMC ROM3 (Boot Partition 2) Capacity: 0 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 0 kB EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.7 (MMC 5.0) Boot configuration [PARTITION_CONFIG: 0x00] No boot partition configured. Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x00. H/W reset function [RST_N_FUNCTION]: 0x00 High-capacity W protect group size [HC_WP_GRP_SIZE: 0x00000000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: 8WMB3R_2634179411_20170506_1305.extcsd --------------------------------------------- Done. Processing file...C:\Users\PC\Downloads\Compressed\I9195_Aliv e_BN\I9195_Alive_BN.bin Writing as RAW data Z3X EasyJtag Software ver. 2.5.0.9 Skip loading eMMC Addon Firmware CMD Pullup Level:3186 mV CMD Active Level:3258 mV Input file : C:\Users\PC\Downloads\Compressed\I9195_Alive_BN\I9 195_Alive_BN.bin Writing 0008000000 bytes to 0000000000... ROM1 (USER ROM) Done. Write Speed: 1093 kB/s Z3X EasyJtag Software ver. 2.5.0.9 Loading eMMC Addon Firmware... IO: 3300 mV Box S/N: 0700100BE8057C5B, ,FW Ver.: 01.58 CMD Pullup Level:3186 mV CMD Active Level:3258 mV Box IO Level:3300 mV CLK Rate:14000 khz HiPower mode is ON! ---------- eMMC Device Information ---------- EMMC CID : 15010038574D423352009D026353518C EMMC CSD : D02701320F5903FFF6DBFFEF8E40400C EMMC Manufacturer ID: 0015 , OEM ID: 0100 EMMC Date: 05/2014 Rev.0x0 EMMC NAME: 8WMB3R , S/N: 2634179411 EMMC NAME (HEX): 38574D42335200 EMMC ROM1 (Main User Data) Capacity: 7456 MB EMMC ROM2 (Boot Partition 1) Capacity: 0 kB EMMC ROM3 (Boot Partition 2) Capacity: 0 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 0 kB EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.7 (MMC 5.0) Boot configuration [PARTITION_CONFIG: 0x00] No boot partition configured. Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x00. H/W reset function [RST_N_FUNCTION]: 0x00 High-capacity W protect group size [HC_WP_GRP_SIZE: 0x00000000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: 8WMB3R_2634179411_20170506_1305.extcsd --------------------------------------------- Done. Processing file...C:\Users\PC\Downloads\Compressed\I9195_Aliv e_BN\I9195_Alive_BN.bin Writing as RAW data Z3X EasyJtag Software ver. 2.5.0.9 Skip loading eMMC Addon Firmware CMD Pullup Level:3186 mV CMD Active Level:3258 mV Input file : C:\Users\PC\Downloads\Compressed\I9195_Alive_BN\I9 195_Alive_BN.bin Writing 0008000000 bytes to 0000000000... ROM1 (USER ROM) Done. Write Speed: 1093 kB/s Z3X EasyJtag Software ver. 2.5.0.9 Loading eMMC Addon Firmware... IO: 3300 mV Box S/N: 0700100BE8057C5B, ,FW Ver.: 01.58 CMD Pullup Level:3186 mV CMD Active Level:3269 mV Box IO Level:3300 mV CLK Rate:14000 khz HiPower mode is ON! ---------- eMMC Device Information ---------- EMMC CID : 15010038574D423352009D026353518C EMMC CSD : D02701320F5903FFF6DBFFEF8E40400C EMMC Manufacturer ID: 0015 , OEM ID: 0100 EMMC Date: 05/2014 Rev.0x0 EMMC NAME: 8WMB3R , S/N: 2634179411 EMMC NAME (HEX): 38574D42335200 EMMC ROM1 (Main User Data) Capacity: 7456 MB EMMC ROM2 (Boot Partition 1) Capacity: 0 kB EMMC ROM3 (Boot Partition 2) Capacity: 0 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 0 kB EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.7 (MMC 5.0) Boot configuration [PARTITION_CONFIG: 0x00] No boot partition configured. Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x00. H/W reset function [RST_N_FUNCTION]: 0x00 High-capacity W protect group size [HC_WP_GRP_SIZE: 0x00000000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: 8WMB3R_2634179411_20170506_1316.extcsd --------------------------------------------- Done. |
02-27-2019, 14:41 | #3 (permalink) | |
No Life Poster Join Date: Oct 2005
Member: 194907 Status: Offline Thanks Meter: 114 | Quote:
old emmc sandisk | |
