cheddihouse | 04-24-2017 00:34 | how can i unlock sony m4 counter 0 with a backup from a working device i have a sony m4 with 0 counter i want to unlock it with direct emmc usine a backup from how to do that or what partition to write?
info Code:
eMMC_tool Suite ver. 1.0.0.43
Microsoft Windows 7 (64 bit) build 7601 (6.1.7601.18015)
Looking for EasyJTAG box...
EasyJTAG API ver. 2008
Setting IO Levels to 3.3V
Setting frequence to 21 Mhz
HiPower mode is OFF
EasyJTAG Box Serial = xxxxxxxx
Card Serial = xxxxxxxxxxxx
EasyJTAG Box Firmware = 01.58
Changelog:
09.03.2017 (ver 1.0.0.43)
Fix: Bugs that have been found through your crash report
Add: Some improvements
Add: Write by vendor "Spreadtrum" (While only SC773X)
Add: Search for tables nVidia Tegra
Add: Completely rewritten Explorer
HiPower mode is OFF
CMD Pullup Level: 1815 mV
CMD Active Level: 1680 mV
EMMC Device Information :
EMMC CID: 90014A48414732650503110790A9133A
EMMC CSD: D02701320F5903FFFFFFFFEF8A4040D2
EMMC Manufacture Name: SKHYNIX
EMMC NAME: HAG2e , S/N: 110790A9 , rev. 03
EMMC NAME (HEX): 484147326505
EMMC ROM 1 (Main User Data) Capacity: 15032 MB (0003AB800000)
EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000)
EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000)
Backup saved: HAG2e_110790A9_20170424_011554.extcsd
EMMC Init completed.
Operation: Find table from emmc
Vendor: Qualcomm
Searching GPT ...
GPT header is found and is valid
Checking for ROM2 ...
ROM2 is blank
GPT header successfully parsed
HiPower mode is OFF
CMD Pullup Level: 1804 mV
Backup saved: HAG2e_110790A9_20170424_011618.extcsd
Backup partition: 8xxx_msimage
Address: 000000004400, size: 00000001BC00
eMMC switching to ROM1
Reading partition...
Done reading partition. Read speed: 560,26 Kb/s
8xxx image is blank. Skipped
XML-file created successfully
Backup partition: PrimaryGPT
Address: 000000000000, size: 000000004400
GPTHeader is valid
Partition name: TA
Address: 000000020000, size: 000000200000
Done reading partition. Read speed: 1373,84 Kb/s
Partition name: sbl1
Address: 000000220000, size: 000000080000
Done reading partition. Read speed: 968,83 Kb/s
Partition name: s1sbl
Address: 0000002A0000, size: 000000040000
Done reading partition. Read speed: 742,34 Kb/s
Partition name: aboot
Address: 0000002E0000, size: 000000100000
Done reading partition. Read speed: 1038,89 Kb/s
Partition name: rpm
Address: 0000003E0000, size: 000000080000
Done reading partition. Read speed: 1152,33 Kb/s
Partition name: tz
Address: 000000460000, size: 000000080000
Done reading partition. Read speed: 837,51 Kb/s
Partition name: hyp
Address: 0000004E0000, size: 000000080000
Done reading partition. Read speed: 1466,67 Kb/s
Partition name: alt_sbl1
Address: 000000560000, size: 000000080000
Done reading partition. Read speed: 967,50 Kb/s
Partition name: alt_s1sbl
Address: 0000005E0000, size: 000000040000
Done reading partition. Read speed: 741,55 Kb/s
Partition name: alt_aboot
Address: 000000620000, size: 000000100000
Done reading partition. Read speed: 1038,87 Kb/s
Partition name: alt_rpm
Address: 000000720000, size: 000000080000
Done reading partition. Read speed: 1150,88 Kb/s
Partition name: alt_tz
Address: 0000007A0000, size: 000000080000
Done reading partition. Read speed: 840,75 Kb/s
Partition name: alt_hyp
Address: 000000820000, size: 000000080000
Done reading partition. Read speed: 1463,36 Kb/s
Partition name: fsg
Address: 000000C00000, size: 000000180000
Done reading partition. Read speed: 1534,30 Kb/s
Partition name: modemst1
Address: 000001000000, size: 000000180000
Done reading partition. Read speed: 832,50 Kb/s
Partition name: modemst2
Address: 000001400000, size: 000000180000
Done reading partition. Read speed: 833,21 Kb/s
Partition name: persist
Address: 000001800000, size: 000002000000
Done reading partition. Read speed: 1502,31 Kb/s
Address: 000003800000, size: 000004000000
Done reading partition. Read speed: 796,40 Kb/s
Partition name: boot
Address: 000007800000, size: 000002800000
Done reading partition. Read speed: 920,05 Kb/s
Partition name: rdimage
Address: 00000A000000, size: 000002000000
Done reading partition. Read speed: 1533,22 Kb/s
Partition name: FOTAKernel
Address: 00000C000000, size: 000002800000
Done reading partition. Read speed: 799,22 Kb/s
Partition name: ssd
Address: 00000E800000, size: 000000002000
Done reading partition. Read speed: 237,05 Kb/s
Partition name: DDR
Address: 00000E802000, size: 000000008000
Done reading partition. Read speed: 675,24 Kb/s
Partition name: config
Address: 00000E80A000, size: 000000080000
Done reading partition. Read speed: 1537,95 Kb/s
Partition name: LTALabel
Address: 00000E88A000, size: 000001000000
Done reading partition. Read speed: 1413,60 Kb/s
Partition name: apps_log
Address: 00000FC00000, size: 000000800000
Done reading partition. Read speed: 1516,59 Kb/s
Partition name: oem
Address: 000010400000, size: 00000F800000
Done reading partition. Read speed: 1527,49 Kb/s
Partition name: cache
Address: 00001FC00000, size: 00000C800000
Done reading partition. Read speed: 1469,26 Kb/s
All done https://scontent.fmad3-3.fna.fbcdn.n...68&oe=58FFB725 https://scontent.fmad3-3.fna.fbcdn.n...cd&oe=58FFA953 |
