04-24-2017, 00:34 | #1 (permalink) |
Freak Poster Join Date: Nov 2012 Location: batna.algeria
Member: 1834802 Status: Offline Sonork: 100.1659078 Thanks Meter: 89 | how can i unlock sony m4 counter 0 with a backup from a working device info Code: eMMC_tool Suite ver. 1.0.0.43 Microsoft Windows 7 (64 bit) build 7601 (6.1.7601.18015) Looking for EasyJTAG box... EasyJTAG API ver. 2008 Setting IO Levels to 3.3V Setting frequence to 21 Mhz HiPower mode is OFF EasyJTAG Box Serial = xxxxxxxx Card Serial = xxxxxxxxxxxx EasyJTAG Box Firmware = 01.58 Changelog: 09.03.2017 (ver 1.0.0.43) Fix: Bugs that have been found through your crash report Add: Some improvements Add: Write by vendor "Spreadtrum" (While only SC773X) Add: Search for tables nVidia Tegra Add: Completely rewritten Explorer HiPower mode is OFF CMD Pullup Level: 1815 mV CMD Active Level: 1680 mV EMMC Device Information : EMMC CID: 90014A48414732650503110790A9133A EMMC CSD: D02701320F5903FFFFFFFFEF8A4040D2 EMMC Manufacture Name: SKHYNIX EMMC NAME: HAG2e , S/N: 110790A9 , rev. 03 EMMC NAME (HEX): 484147326505 EMMC ROM 1 (Main User Data) Capacity: 15032 MB (0003AB800000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Backup saved: HAG2e_110790A9_20170424_011554.extcsd EMMC Init completed. Operation: Find table from emmc Vendor: Qualcomm Searching GPT ... GPT header is found and is valid Checking for ROM2 ... ROM2 is blank GPT header successfully parsed HiPower mode is OFF CMD Pullup Level: 1804 mV CMD Active Level: 1680 mV EMMC Device Information : EMMC CID: 90014A48414732650503110790A9133A EMMC CSD: D02701320F5903FFFFFFFFEF8A4040D2 EMMC Manufacture Name: SKHYNIX EMMC NAME: HAG2e , S/N: 110790A9 , rev. 03 EMMC NAME (HEX): 484147326505 EMMC ROM 1 (Main User Data) Capacity: 15032 MB (0003AB800000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Backup saved: HAG2e_110790A9_20170424_011618.extcsd EMMC Init completed. Backup partition: 8xxx_msimage Address: 000000004400, size: 00000001BC00 eMMC switching to ROM1 Reading partition... Done reading partition. Read speed: 560,26 Kb/s 8xxx image is blank. Skipped XML-file created successfully Backup partition: PrimaryGPT Address: 000000000000, size: 000000004400 GPTHeader is valid Partition name: TA Address: 000000020000, size: 000000200000 eMMC switching to ROM1 Reading partition... Done reading partition. Read speed: 1373,84 Kb/s Partition name: sbl1 Address: 000000220000, size: 000000080000 eMMC switching to ROM1 Reading partition... Done reading partition. Read speed: 968,83 Kb/s Partition name: s1sbl Address: 0000002A0000, size: 000000040000 eMMC switching to ROM1 Reading partition... Done reading partition. Read speed: 742,34 Kb/s Partition name: aboot Address: 0000002E0000, size: 000000100000 eMMC switching to ROM1 Reading partition... Done reading partition. Read speed: 1038,89 Kb/s Partition name: rpm Address: 0000003E0000, size: 000000080000 eMMC switching to ROM1 Reading partition... Done reading partition. Read speed: 1152,33 Kb/s Partition name: tz Address: 000000460000, size: 000000080000 eMMC switching to ROM1 Reading partition... Done reading partition. Read speed: 837,51 Kb/s Partition name: hyp Address: 0000004E0000, size: 000000080000 eMMC switching to ROM1 Reading partition... Done reading partition. Read speed: 1466,67 Kb/s Partition name: alt_sbl1 Address: 000000560000, size: 000000080000 eMMC switching to ROM1 Reading partition... Done reading partition. Read speed: 967,50 Kb/s Partition name: alt_s1sbl Address: 0000005E0000, size: 000000040000 eMMC switching to ROM1 Reading partition... Done reading partition. Read speed: 741,55 Kb/s Partition name: alt_aboot Address: 000000620000, size: 000000100000 eMMC switching to ROM1 Reading partition... Done reading partition. Read speed: 1038,87 Kb/s Partition name: alt_rpm Address: 000000720000, size: 000000080000 eMMC switching to ROM1 Reading partition... Done reading partition. Read speed: 1150,88 Kb/s Partition name: alt_tz Address: 0000007A0000, size: 000000080000 eMMC switching to ROM1 Reading partition... Done reading partition. Read speed: 840,75 Kb/s Partition name: alt_hyp Address: 000000820000, size: 000000080000 eMMC switching to ROM1 Reading partition... Done reading partition. Read speed: 1463,36 Kb/s Partition name: fsg Address: 000000C00000, size: 000000180000 eMMC switching to ROM1 Reading partition... Done reading partition. Read speed: 1534,30 Kb/s Partition name: modemst1 Address: 000001000000, size: 000000180000 eMMC switching to ROM1 Reading partition... Done reading partition. Read speed: 832,50 Kb/s Partition name: modemst2 Address: 000001400000, size: 000000180000 eMMC switching to ROM1 Reading partition... Done reading partition. Read speed: 833,21 Kb/s Partition name: persist Address: 000001800000, size: 000002000000 eMMC switching to ROM1 Reading partition... Done reading partition. Read speed: 1502,31 Kb/s Partition name: modem Address: 000003800000, size: 000004000000 eMMC switching to ROM1 Reading partition... Done reading partition. Read speed: 796,40 Kb/s Partition name: boot Address: 000007800000, size: 000002800000 eMMC switching to ROM1 Reading partition... Done reading partition. Read speed: 920,05 Kb/s Partition name: rdimage Address: 00000A000000, size: 000002000000 eMMC switching to ROM1 Reading partition... Done reading partition. Read speed: 1533,22 Kb/s Partition name: FOTAKernel Address: 00000C000000, size: 000002800000 eMMC switching to ROM1 Reading partition... Done reading partition. Read speed: 799,22 Kb/s Partition name: ssd Address: 00000E800000, size: 000000002000 eMMC switching to ROM1 Reading partition... Done reading partition. Read speed: 237,05 Kb/s Partition name: DDR Address: 00000E802000, size: 000000008000 eMMC switching to ROM1 Reading partition... Done reading partition. Read speed: 675,24 Kb/s Partition name: config Address: 00000E80A000, size: 000000080000 eMMC switching to ROM1 Reading partition... Done reading partition. Read speed: 1537,95 Kb/s Partition name: LTALabel Address: 00000E88A000, size: 000001000000 eMMC switching to ROM1 Reading partition... Done reading partition. Read speed: 1413,60 Kb/s Partition name: apps_log Address: 00000FC00000, size: 000000800000 eMMC switching to ROM1 Reading partition... Done reading partition. Read speed: 1516,59 Kb/s Partition name: oem Address: 000010400000, size: 00000F800000 eMMC switching to ROM1 Reading partition... Done reading partition. Read speed: 1527,49 Kb/s Partition name: cache Address: 00001FC00000, size: 00000C800000 eMMC switching to ROM1 Reading partition... Done reading partition. Read speed: 1469,26 Kb/s All done |
