Old 06-30-2019, 15:50   #1 (permalink)
Member: 2895768
Thanks Meter: 10
Xiaomi Mi account
How can i remove Xiaomi Mi account? With Easy Jtag?
The Following User Says Thank You to Gaelymateo2 For This Useful Post:
Old 06-30-2019, 16:28   #2 (permalink)
layder's Avatar
Member: 13148
Thanks Meter: 2,948
Mi account is stored at online Xiaomi servers.
To remove Mi account you need remove record from Xiaomi servers
The Following 7 Users Say Thank You to layder For This Useful Post:
Old 06-30-2019, 18:44   #3 (permalink)
Member: 2895768
Thanks Meter: 10
but for example, with UMT box I can do a bypass of that account, I just do not have to reset it or update it because the block would reappear, with Easy jtag there must be some option to do that bypass and I have seen that they do it with easy jtag, but I do not know what partition to delete
Old 06-30-2019, 20:01   #4 (permalink)
layder's Avatar
Member: 13148
Thanks Meter: 2,948
EasyJTAG box is make for repair eMMC content (boot area and other)
not for bypass brand online sevices
For some deviced where are found "patched" firmwares with "cutted" Mi services
The Following 5 Users Say Thank You to layder For This Useful Post:
Old 07-01-2019, 05:00   #5 (permalink)
faizafirdous's Avatar
Member: 1281866
Thanks Meter: 330
He is telling About bypass solution like other tools can do
The Following User Says Thank You to faizafirdous For This Useful Post:
Old 07-01-2019, 09:51   #6 (permalink)
layder's Avatar
Member: 13148
Thanks Meter: 2,948
The only workaround is to remove programs (Mi services), which connected to the Internet, connect to servers and check locks.
These are solutions from the discharge of the firmware patch.
We do not work in this direction. Making changes to device firmware is not our business.
Among other things, many users require for Mi services to remain working.
The Following 4 Users Say Thank You to layder For This Useful Post:
Old 07-05-2019, 13:39   #7 (permalink)
umar342's Avatar
Member: 1246696
Sonork: 100.1681950
Thanks Meter: 650
in some model only wright persist file
The Following 2 Users Say Thank You to umar342 For This Useful Post:
Old 07-09-2019, 10:24   #8 (permalink)
layder's Avatar
Member: 13148
Thanks Meter: 2,948
Only very old models
The Following 3 Users Say Thank You to layder For This Useful Post:
Old 08-03-2019, 17:55   #9 (permalink)
umar342's Avatar
Member: 1246696
Sonork: 100.1681950
Thanks Meter: 650
yes you r right i dont no this thing
but i want to know why dose not work persist file in new mi model
plese peply
The Following User Says Thank You to umar342 For This Useful Post:
Old 08-03-2019, 18:19   #10 (permalink)
Member: 2185549
Thanks Meter: 535
plese peply
security keeps geting updates btw mi account removal is a tweak of system img to remove some files that communitate to the mi server otherwise theres no way u can do it with out that hiwever some newer firmwares have been designed to have a relock system where files can be rebiult from other sectors
al stop frm here this is not xiaomi section but all in all just knw easyjtag's goals are in different direction whereas we are talking about somn else
its like doing im** repair jtag has the capacity to but thats not there intrest "if u can dig as deep as the rpmb sector on the emmc chip " what of modem or fsg or somn else
The Following 2 Users Say Thank You to ferouz kassim For This Useful Post:
Old 08-03-2019, 22:24   #11 (permalink)
layder's Avatar
Member: 13148
Thanks Meter: 2,948
new models is check lock at Xiaomi servers
olny way - create firmwares with removed "Mi" service (need Unlocked boot) or remove lock via Xiaomi service center (remove from servers)
Old 11-23-2019, 08:37   #12 (permalink)
Member: 704044
Thanks Meter: 212
Please add mi account reset
Dear product supporter please add mi account reset option .
Thanks in advance
The Following User Says Thank You to sekarrajan For This Useful Post:
Old 11-23-2019, 09:19   #13 (permalink)
layder's Avatar
Member: 13148
Thanks Meter: 2,948
Mi akk is stored at Xiaomi servers, as Apple
How we can removed it?
Old 11-26-2019, 04:21   #14 (permalink)
Member: 704044
Thanks Meter: 212
DEAR SUPPORTER I WANT TO ONE CLICK FORMAT ADDRESS TO ERASE MI ACCOUNT IN PARTITION
Sent from my iPhone using Tapatalk
Old 11-26-2019, 05:26   #15 (permalink)
Member: 818380
Thanks Meter: 56
1. If you erase the persist on a device with a fingerprint sensor, the device will not be able to use wifi and sensors, some time phone lost internal memory.
2. Disabling finddevice(delete or do some thing with finddevice.apk) on devices running miui 10 or later may cause continuous crashes, with devices running miui 11 after connecting the wifi the phone will automatically download finddevice.apk and install it after reboot. you can only install custom fw on your phone to hide mi services but that requires unlocking the device bootloader.
The Following 5 Users Say Thank You to duythangvn For This Useful Post:
Page generated in 0.33355 seconds with 8 queries
