Old 01-26-2019, 17:46   #1 (permalink)
Member: 975554
Sonork: KG state:prenormal
Thanks Meter: 213
htc 10 easy jtag dump
Setting interface to EasyJtag2/ISP
Setting bus width to 1 Bit
Setting frequence to 36 Mhz
CMD Pullup Level: 1579 mV
CMD Active Level: 1879 mV
EMMC Device Information :
EMMC CID: 450100444634303332012244755A53D3
EMMC CSD: D00F00328F5903FFFFFFFFEF8A404023
EMMC Manufacture : SANDISK , EMMC NAME: DF4032 , HEX: 444634303332 , S/N: 2244755A , rev. 0x01
EMMC Manufacture ID: 0x45 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 5/2016
EMMC ROM 1 (Main User Data) Capacity: 29820 MB (000747C00000)
EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000)
EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000)
EMMC Permanent Write Protection: No
EMMC Temporary Write Protection: No
Extended CSD Information :
Extended CSD rev: 1.8 (MMC 5.1)
Boot configuration [PARTITION_CONFIG]: 0x38 , Boot from: ROM1 (Main User Area)
Boot Bus Config: 0x00 , width 1bit
H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled
Supported partition features [PARTITIONING_SUPPORT]: 0x07
Device supports partitioning features
Device can have enhanced technological features in partitions and user data area
Device can have extended partitions attribute
Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00
Backup saved: DF4032_2244755A_20190126_155801.extcsd
EMMC Init completed.
https://www.4shared.com/rar/Odv8rO6Eda/htc_10.html
password: sunrisegsm
press thanks if it works..
The Following 3 Users Say Thank You to simpleprince49 For This Useful Post:
Old 03-21-2019, 18:54   #2 (permalink)
Member: 2901369
Can you please Give me EMMC pinout for HTC 10
Old 03-21-2019, 20:28   #3 (permalink)
Member: 2034628
Thanks Meter: 4
EMMC pinout please
Old 03-23-2019, 12:53   #4 (permalink)
Member: 975554
Thanks Meter: 213
pinout pm me..z3x will ban me if i post here i think
Old 03-25-2019, 15:02   #5 (permalink)
Member: 1911593
Sonork: 100.1645151
Thanks Meter: 130
The Following User Says Thank You to love edition For This Useful Post:
Old 03-26-2019, 19:24   #6 (permalink)
Member: 515130
Thanks Meter: 304
Setting frequence to 21 Mhz
CMD Pullup Level: 1959 mV
CMD Active Level: 2145 mV
EMMC CID: 450100444634303332011EDA7AA273D0
EMMC CSD: D00F00328F5903FFFFFFFFEF8A404022
EMMC Manufacture : SANDISK , EMMC NAME: DF4032 , HEX: 444634303332 , S/N: 1EDA7AA2 , rev. 0x01
EMMC Manufacture ID: 0x45 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 7/2016
Backup saved: DF4032_1EDA7AA2_20190326_225144.extcsd
Get firmware version
CMD Pullup Level: 1938 mV
Backup saved: DF4032_1EDA7AA2_20190326_225207.extcsd
Operation: Writing all eMMC Regions...
Operation: Writing BootConfig ...
Reg: 179 Value: 0x38
Reg: 177 Value: 0x00
Reg: 162 Value: 0x01
Done
Writing to: ROM1 , start: 0x000000000000 , size: 0x000040000000
Filename: EMMC__ROM1_000000000000_000040000000.bin
eMMC switching to ROM1
Writing partition...
Done writing partition. Write speed: 676.54 KB/s
All done time: [00:25:50:508]
dump write done but phone still dead .phone in qualmqoum mode 9008 what to do next do we need rom 2 or rom3 as well .???
if u have rom 2 rom3 please share
Old 03-28-2019, 15:18   #7 (permalink)
Member: 515130
Thanks Meter: 304
problem solve dump working
after write dump remove TP phone power on
The Following 2 Users Say Thank You to shahzad-0004 For This Useful Post:
Old 04-19-2020, 23:21   #8 (permalink)
Member: 2953860
Thanks Meter: 3
thank you sir
when i write the dump my phone still dead in the mode of hs usb qloader 9008
no power on
i do factory format
the size of my partitions is different than yours
Old 04-19-2020, 23:36   #9 (permalink)
Member: 2953860
Thanks Meter: 3
eMMC NAME: DF4032 , S/N: 574911834
eMMC NAME (HEX): 444634303332
EMMC ROM1 (Main User Data) Capacity: 15028 MB
EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB
EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB
EMMC RPMB (Replay Protected Memory Block) Capacity: 512 kB
EMMC RPMB is not yet programmed (clear) or RPMB General failure
Old 04-20-2020, 03:34   #10 (permalink)
Member: 1972033
Thanks Meter: 31
make smart report then log it here and as u see theres problem with rpmb partition
The Following User Says Thank You to nour2014 For This Useful Post:
Powered by Searchlight © 2022 Axivo Inc.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2022 DragonByte Technologies Ltd.
Page generated in 0.16317 seconds with 7 queries
