01-25-2017, 15:23 | #1 (permalink) |
Freak Poster Join Date: Feb 2015 Location: Syria-Aleppo
Member: 2346672 Status: Offline Sonork: 1671045 :Abdohurbli Thanks Meter: 25 | HTC 616 eMMC Replace I need To Replace the eMMC For the Desire 616 but Non Works ... What I've Tried To Do is : Replace it with Samsung eMMC 4 GB Write Full Dump " Also Write the Scatter File With Easy Jtag Plus " No boot Tried to Flash it ," Error make sure Target is matched " So I wanna know My Mistake is The Type of eMMC ? or The Way I Flash the Dump ? " Note : Also I have Read Dump From Working Device with the EXT file " The Same Error When Flash it Any Suggest ? or Solution ? Thanks BR |
The Following User Says Thank You to Abdohurbli For This Useful Post: |
01-25-2017, 16:33 | #3 (permalink) |
Member: 2346672 Status: Offline Sonork: 1671045 :Abdohurbli Thanks Meter: 25 | Aha But ... __________________________________________________ ________ ok Thank for the Info but The eMMC that U Telling me about is : Skyhnix eMMc the Same eMMC on the 616 board .... I Don't have this eMMC ,I can't replace it with other one like Samsung eMMC ? thank so much for info . BR |
01-25-2017, 18:04 | #4 (permalink) | |
No Life Poster Join Date: Jan 2005 Location: Iran Age: 36
Member: 103435 Status: Offline Thanks Meter: 49 | Quote:
and 2 mg RPMB partition change boot config to rom2 and patch your samsung emmc cid to this cid 90014A4834473164040507A168484182 | |
01-25-2017, 21:47 | #5 (permalink) | |
Member: 2346672 Status: Offline Sonork: 1671045 :Abdohurbli Thanks Meter: 25 | Thax U sir ... But Please Quote:
I did the same u said and here is the Log : eMMC_tool Suite ver. 1.0.0.42 Microsoft Windows 10 (64 bit) build 14393 (10.0.14393.206) Looking for EasyJTAG box... EasyJTAG API ver. 2008 Setting IO Levels to 3.3V Setting frequence to 14 Mhz HiPower mode is OFF EasyJTAG Box Serial = 0600201ED5F073BD Card Serial = AA73-030A EasyJTAG Box Firmware = 01.56 Changelog: 11.12.2016 (ver 1.0.0.42) Fix: Fixed force erase timeouts detection (Universal Factory Format) 08.12.2016 (ver 1.0.0.41) Fix: Bugs that have been found through your crash report 02.12.2016 (ver 1.0.0.40) Fix: Bug with switching ROM Fix: Bug with access to GP-partitions Fix: Bug when searching for FRP Add: Generic / Universal Factory Format (Toshiba, Hynix, etc.) 30.11.2016 (ver 1.0.0.39) Fix: Bug with the smart card at the start of the program Fix: Bug when processing sparse image Fix: Bug with extract data from contacts2.db Fix: Writing for some MTK images Fix: Bug when opening MTK-partitions in the Explorer Add: Reading tables from emmc on the Factory tab (for writing partitions if you do not have a header file) Add: Support GP-partitions Add: Option "Write all eMMC Regions at once" Add: Automatically sending crash reports Add: Button "Sending crash report for the current log" Add: Notification in the system tray Add: Adding ROM2 when reading from the image Add: Automatic writing configuration for MTK after flashing Add: Some GUI changes HiPower mode is OFF CMD Pullup Level: 2949 mV CMD Active Level: 3176 mV EMMC Device Information : EMMC CID: 90014A4834473164040507A168484182 EMMC CSD: D02701320F5903FFF6DBFFEF8E40400C EMMC Manufacture Name: SKHYNIX EMMC NAME: H4G1d , S/N: 07A16848 , rev. 05 EMMC NAME (HEX): 483447316404 EMMC ROM 1 (Main User Data) Capacity: 3728 MB (0000E9000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 2048 KB (000000200000) EMMC RPMB (Replay Protected Memory Block) Capacity: 2048 KB (000000200000) Backup saved: H4G1d_07A16848_20170125_215348.extcsd EMMC Init completed. HiPower mode is OFF CMD Pullup Level: 3093 mV CMD Active Level: 3217 mV EMMC Device Information : EMMC CID: 90014A4834473164040507A168484182 EMMC CSD: D02701320F5903FFF6DBFFEF8E40400C EMMC Manufacture Name: SKHYNIX EMMC NAME: H4G1d , S/N: 07A16848 , rev. 05 EMMC NAME (HEX): 483447316404 EMMC ROM 1 (Main User Data) Capacity: 3728 MB (0000E9000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 2048 KB (000000200000) EMMC RPMB (Replay Protected Memory Block) Capacity: 2048 KB (000000200000) Backup saved: H4G1d_07A16848_20170125_215401.extcsd EMMC Init completed. Writing eMMC Register ... Reg: 179 Value: 0x48 Reg: 177 Value: 0x00 Reg: 162 Value: 0x01 Successfully HiPower mode is OFF CMD Pullup Level: 3083 mV CMD Active Level: 3217 mV EMMC Device Information : EMMC CID: 90014A4834473164040507A168484182 EMMC CSD: D02701320F5903FFF6DBFFEF8E40400C EMMC Manufacture Name: SKHYNIX EMMC NAME: H4G1d , S/N: 07A16848 , rev. 05 EMMC NAME (HEX): 483447316404 EMMC ROM 1 (Main User Data) Capacity: 3728 MB (0000E9000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 2048 KB (000000200000) EMMC RPMB (Replay Protected Memory Block) Capacity: 2048 KB (000000200000) Backup saved: H4G1d_07A16848_20170125_215406.extcsd EMMC Init completed. HiPower mode is OFF CMD Pullup Level: 3083 mV CMD Active Level: 3217 mV EMMC Device Information : EMMC CID: 90014A4834473164040507A168484182 EMMC CSD: D02701320F5903FFF6DBFFEF8E40400C EMMC Manufacture Name: SKHYNIX EMMC NAME: H4G1d , S/N: 07A16848 , rev. 05 EMMC NAME (HEX): 483447316404 EMMC ROM 1 (Main User Data) Capacity: 3728 MB (0000E9000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 2048 KB (000000200000) EMMC RPMB (Replay Protected Memory Block) Capacity: 2048 KB (000000200000) Backup saved: H4G1d_07A16848_20170125_215447.extcsd EMMC Init completed. Opening file: MT6592_Android_scatter.txt The new format of scatter config_version: V1.1.2 platform: MT6592 preloader_wt98518.bin Found 2 supported eMMC CID: name = 'H4G1d' hex = 0x483447316404 [SKHYNIX] name = 'K5XVMB' hex = 0x4B3558564D42 [SAMSUNG] The size of the last section has been updated HiPower mode is OFF CMD Pullup Level: 3083 mV CMD Active Level: 3217 mV EMMC Device Information : EMMC CID: 90014A4834473164040507A168484182 EMMC CSD: D02701320F5903FFF6DBFFEF8E40400C EMMC Manufacture Name: SKHYNIX EMMC NAME: H4G1d , S/N: 07A16848 , rev. 05 EMMC NAME (HEX): 483447316404 EMMC ROM 1 (Main User Data) Capacity: 3728 MB (0000E9000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 2048 KB (000000200000) EMMC RPMB (Replay Protected Memory Block) Capacity: 2048 KB (000000200000) Backup saved: H4G1d_07A16848_20170125_215458.extcsd EMMC Init completed. Operation: Write by vendor (MediaTek) Partition name: MBR Filename: MBR , Offset: 000000000000 , filesize: 512 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 43.77 Kb/s Partition name: PRELOADER Filename: preloader_wt98518.bin , Offset: 000000000000 , filesize: 121876 bytes eMMC switching to ROM2 Erasing partition... Writing partition... Done writing partition. Write speed: 306.82 Kb/s Partition name: EBR1 Filename: EBR1 , Offset: 000000080000 , filesize: 512 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 57.74 Kb/s Partition name: UBOOT Filename: lk.bin , Offset: 000001D40000 , filesize: 241396 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 843.81 Kb/s Partition name: BOOTIMG Filename: boot.img , Offset: 000001DA0000 , filesize: 5132288 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 957.85 Kb/s Partition name: RECOVERY Filename: recovery.img , Offset: 000002DA0000 , filesize: 5474304 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 959.25 Kb/s Partition name: SEC_RO Filename: secro.img , Offset: 000003DA0000 , filesize: 135168 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1471.62 Kb/s Partition name: LOGO Filename: logo.bin , Offset: 000004420000 , filesize: 513195 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 854.33 Kb/s Partition name: EBR2 Filename: EBR2 , Offset: 000004C20000 , filesize: 512 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 61.74 Kb/s Partition name: ANDROID Filename: system.img , Offset: 000007800000 , filesize: 1164460856 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Sparse image found v.1.0 Total chunks: 1773 Done writing partition. Write speed: 901.63 Kb/s Partition name: CACHE Filename: cache.img , Offset: 000055000000 , filesize: 5972176 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Sparse image found v.1.0 Total chunks: 15 Done writing partition. Write speed: 1565.11 Kb/s Partition name: USRDATA Filename: userdata.img , Offset: 000062000000 , filesize: 76059216 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Sparse image found v.1.0 Total chunks: 47 Done writing partition. Write speed: 1020.97 Kb/s Writing DL_Info... Writing DL_Info done Writing eMMC Register ... Reg: 179 Value: 0x48 Reg: 177 Value: 0x00 All done HiPower mode is OFF CMD Pullup Level: 3083 mV CMD Active Level: 3217 mV EMMC Device Information : EMMC CID: 90014A4834473164040507A168484182 EMMC CSD: D02701320F5903FFF6DBFFEF8E40400C EMMC Manufacture Name: SKHYNIX EMMC NAME: H4G1d , S/N: 07A16848 , rev. 05 EMMC NAME (HEX): 483447316404 EMMC ROM 1 (Main User Data) Capacity: 3728 MB (0000E9000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 2048 KB (000000200000) EMMC RPMB (Replay Protected Memory Block) Capacity: 2048 KB (000000200000) Backup saved: H4G1d_07A16848_20170125_222004.extcsd EMMC Init completed. MBR header is found. Analyzing data ... EBR detected at address: 000000080000 Partition: mmcblk0p0 [000000900400 - 000001300400], size: 000000A00000 Partition: mmcblk0p1 [000001300400 - 000001D00400], size: 000000A00000 Partition: mmcblk0p2 [000003DA0400 - 0000043A0400], size: 000000600000 Partition: mmcblk0p3 [000004CA0000 - 0000066A0000], size: 000001A00000 MBR header successfully parsed The Same Erorr ... No Boot , And Can't Flash the Device .. | |
01-26-2017, 16:40 | #9 (permalink) | |
Freak Poster Join Date: Jun 2014
Member: 2213928 Status: Offline Thanks Meter: 440 | Quote:
so donot west time and easy jtag sppoopter never anser abot mtk partion making | |
01-26-2017, 17:41 | #10 (permalink) | |
Member: 2346672 Status: Offline Sonork: 1671045 :Abdohurbli Thanks Meter: 25 | Quote:
Still have hope to c an Answer from the Easy Support to know where is the problem and Why It's Not Working ! __________________________________________________ ___________ | |
01-26-2017, 17:52 | #11 (permalink) |
Member: 131131 Status: Offline Sonork: 100.1606847 Thanks Meter: 4,475 | Hi try this: pickup H9TP32A8JDAC or KMK5X000VM-B314 select scatter then uncheck "android,cache,userdata" Now Press Write put back eMMC into pcb try flash with correct FW also SPFlash tools now if your phone not working maybe you need reball or change cpu |
The Following User Says Thank You to BABAK NURI For This Useful Post: |
01-26-2017, 18:21 | #12 (permalink) | |
Member: 2346672 Status: Offline Sonork: 1671045 :Abdohurbli Thanks Meter: 25 | here sir xD ... Quote:
thanks for the Great info .. But If I don't have these 2 eMMC I do Have : KMK5X000YM-B314 " U Said we Should use the VM and I have the YM " In Syria- Aleppo There no eMMC Shop And We Just have it From Brick Device so I wanna know Why & what is the different between these 2 eMMC. Note : I've Tried this eMMC " That I have and It failed " You Can c The Log here sir : LOGS thank You So much sir I will be waiting Your Answer ... BR | |
01-26-2017, 21:42 | #13 (permalink) |
Member: 131131 Status: Offline Sonork: 100.1606847 Thanks Meter: 4,475 | Hi I have no idea what is the difference between 2 emmc But as i know only thus emmc can work only Maybe you should pickup from another pcb like i8552 or g355h |
01-27-2017, 09:54 | #14 (permalink) | |
all petioion come on in emmcv but easy jtag puls have big bug for weting done peloder but it is fake wrrting after wting setter file alvesi 4032 essre in many phone if you doner nay phone whit youe self then post full delis wrting log and rediung emmc afrer log it make partistoion aor not | |
01-27-2017, 12:03 | #15 (permalink) | |
Member: 2346672 Status: Offline Sonork: 1671045 :Abdohurbli Thanks Meter: 25 | thanks u sir Quote:
thank u sir ... I will try to get this kind of eMMC and post the Result soon .. BR | |
