06-07-2022, 21:03 | #1 (permalink) |
No Life Poster Join Date: Sep 2013 Location: INSIDE YOUR MIND
Member: 2025428 Status: Offline Thanks Meter: 445 | WHAT could be the problem of this Error ERROR -113/ERROR_UFS_UPIU_NOP_RESULT_FAIL Build: 1.22.0.1187 Build Date/Time: May 25 2022 11:46:56 Box API Version: 3505 FS Driver Version: 04012021 SQLite Version: 3.37.1 FSCK Engine Version: 04012021 ESE DB Version: 04012021 System Util Version: 04012021 System: Windows NT 6.2 (Build 9200) / 64 BIT CPU: Intel(R) Core(TM) i7-7600U CPU @ 2.80GHz Total RAM: 15.63 GB System Date: 6/7/2022 8:56:34 PM Official Site: https://efm.easy-jtag.com/ Site: https://emmc-fm.com/ Telegram Russian Support: https://t.me/z3xefm FRP Apps: https://efm.easy-jtag.com/frp/ Z3X Card Serial: XXXXXX EasyJtag Plus Box Found at: COM13 EasyJtag Plus Box Firmware: 2.53.2 Source: EasyJtag Port [UFS] Generation: GPT [QC/SAMS/BCM/INTEL/MTK] UFS Power Mode: LOW Scanner Thread Created.. Running EasyJtag UFS Mode... UFS ISP Mode: OFF UFS Safe Mode: ON Initialize UFS Engine Fail. Code: -113/ERROR_UFS_UPIU_NOP_RESULT_FAIL Scanner Thread Terminated Elapsed: 00:00:10:542 Found 0 Partition(s).. Search Partitions Fail.. Check Socket/UFS Chip and Try Again.. Source: EasyJtag Port [UFS] Generation: GPT [QC/SAMS/BCM/INTEL/MTK] UFS Power Mode: LOW Scanner Thread Created.. Running EasyJtag UFS Mode... UFS ISP Mode: OFF UFS Safe Mode: ON Initialize UFS Engine Fail. Code: -113/ERROR_UFS_UPIU_NOP_RESULT_FAIL Scanner Thread Terminated Elapsed: 00:00:08:388 Found 0 Partition(s).. Search Partitions Fail.. Check Socket/UFS Chip and Try Again.. THINGS I HAVE TRIED SO FAR BELOW 1.. JUMPER TWO RESISTOR =NOT CONNECT 2.. REPLACE RESISTORS WITH 22R 0402 RESISTORS =NOT CONNECT AM USING ORIGINAL Z3X UFS 254 ADAPTER |
03-29-2024, 11:48 | #2 (permalink) |
Freak Poster Join Date: Sep 2009 Location: NEPAL
Member: 1128042 Status: Offline Sonork: 100.1666710 Thanks Meter: 155 | Z3X EasyJtag EMMC File Manager v 1.24 Started.. Build: 1.23.0.1250 Build Date/Time: Mar 15 2024 16:51:40 Box API Version: 3505 FS Driver Version: 04012021 SQLite Version: 3.39.0 FSCK Engine Version: 04012021 ESE DB Version: 04012021 System Util Version: 04012021 System: Windows NT 6.2 (Build 9200) / 64 BIT CPU: Intel(R) Core(TM) i3-2350M CPU @ 2.30GHz Total RAM: 7.95 GB System Date: 2024/03/29 4:06:38 PM Official Site: https://emmc-fm.com/ Telegram Russian Support: https://t.me/z3xefm FRP Apps: https://emmc-fm.com/frp/ Z3X Card Serial: AAAC6737 Z3X Box Serial: DFCB2A983E849B4D EasyJtag Plus Box Found at: COM16 EasyJtag Plus Box Firmware: 2.53.2 Source: EasyJtag Port [UFS] Generation: GPT [QC/SAMS/BCM/INTEL/MTK] UFS Power Mode: LOW Scanner Thread Created.. Running EasyJtag UFS Mode... UFS ISP Mode: ON UFS Safe Mode: ON UFS: Socket Info: S/N: 0x01236504F0B4F1D1EE Desc: EasyJTAG UFS Socket BGA-254 by EasyJTAG 26.11.21 Type: EasyJtag UFS Socket BGA-254 ID: 7729 Initialize UFS Engine Fail. Code: -56/BOX: UFS Box Init Link T0 Scanner Thread Terminated Elapsed: 00:00:03:739 Found 0 Partition(s).. Search Partitions Fail.. Check Socket/UFS Chip and Try Again.. Source: EasyJtag Port [UFS] Generation: GPT [QC/SAMS/BCM/INTEL/MTK] UFS Power Mode: LOW Scanner Thread Created.. Running EasyJtag UFS Mode... UFS ISP Mode: ON UFS Safe Mode: ON Initialize UFS Engine Fail. Code: -113/ERROR_UFS_UPIU_NOP_RESULT_FAIL Scanner Thread Terminated Elapsed: 00:00:08:591 Found 0 Partition(s).. Search Partitions Fail.. Check Socket/UFS Chip and Try Again.. Source: EasyJtag Port [UFS] Generation: GPT [QC/SAMS/BCM/INTEL/MTK] UFS Power Mode: LOW Scanner Thread Created.. Running EasyJtag UFS Mode... UFS ISP Mode: ON UFS Safe Mode: ON Initialize UFS Engine Fail. Code: -113/ERROR_UFS_UPIU_NOP_RESULT_FAIL Scanner Thread Terminated Elapsed: 00:00:08:525 Found 0 Partition(s).. Search Partitions Fail.. Check Socket/UFS Chip and Try Again.. Source: EasyJtag Port [UFS] Generation: GPT [QC/SAMS/BCM/INTEL/MTK] UFS Power Mode: HIGH Scanner Thread Created.. Running EasyJtag UFS Mode... UFS ISP Mode: ON UFS Safe Mode: ON Initialize UFS Engine Fail. Code: -113/ERROR_UFS_UPIU_NOP_RESULT_FAIL Scanner Thread Terminated Elapsed: 00:00:08:533 Found 0 Partition(s).. Search Partitions Fail.. Check Socket/UFS Chip and Try Again.. Session is Closed.. Source: EasyJtag Port [UFS] Generation: GPT [QC/SAMS/BCM/INTEL/MTK] UFS Power Mode: HIGH Scanner Thread Created.. Running EasyJtag UFS Mode... UFS ISP Mode: OFF UFS Safe Mode: ON Initialize UFS Engine Fail. Code: -113/ERROR_UFS_UPIU_NOP_RESULT_FAIL Scanner Thread Terminated Elapsed: 00:00:08:577 Found 0 Partition(s).. Search Partitions Fail.. Check Socket/UFS Chip and Try Again.. Source: EasyJtag Port [UFS] Generation: GPT [QC/SAMS/BCM/INTEL/MTK] UFS Power Mode: LOW Scanner Thread Created.. Running EasyJtag UFS Mode... UFS ISP Mode: ON UFS Safe Mode: ON Init UFS Engine: 0/OK EasyJtag Plus S/N: DFCB2A983E849B4D EasyJtag Plus Box FirmWare: 2.53.2 Box Hardware = EasyJtag 2nd Generation UFS Socket Info: S/N: 0x01236504F0B4F1D1EE Desc: EasyJTAG UFS Socket BGA-254 by EasyJTAG 26.11.21 Type: EasyJtag UFS Socket BGA-254 ID: 7729 UFS Voltage Info: Mode: LOW VCC : 3309 mV, VCCQ2: 1916 mV 3v3 : 3366 mV, 1v2: 1207 mV UFS Memory Info: Connection: Socket BGA-153 Vendor: SAMSUNG Name: KLUDG4U1EA-B0C1 S/N: 0x3B4CA331193F7EC4B35CCEE6C081564848414137395530 OEM ID: SAMSUNG_OEM_ID Firm Version: 0.02 UFS Version: 2.1 Size: 0x001DCC800000/119.20 GB Max LUNs: 8 LUNs Cnt: 5 W-LUNs Cnt: 1 LUNs ReConfig: Disabled UFS RPMB Info: RPMB Counter: 4225 UFS Health Info: UFS Life Time A: 0x02 -> 10% - 20% Life Time Used UFS Life Time B: 0x02 -> 10% - 20% Life Time Used UFS Pre-EOL Info: 0x01 -> Used Less 80% of Reserved Blocks UFS LUNs Info: LUN 0 -> Size: 31236096 Block(s)/119.16 GB LUN 1 (Main Boot A) -> Size: 1024 Block(s)/4.00 MB LUN 2 (Boot B) -> Size: 1024 Block(s)/4.00 MB LUN 3 -> Size: 2048 Block(s)/8.00 MB LUN 4 -> Size: 2048 Block(s)/8.00 MB W-LUN 0xC4 (RPMB) -> Size: 65536 Block(s)/16.00 MB UFS Init OK Scanning Data From UFS Chip. Please wait.. Scanning GUID Partition Table from LUN 0 GUID Partition Table is Found. Max Parts: 128 GPT: GPT [000000000000 - 000000006000] Size: 24.00 KB GPT: EFS [000000400000 - 000001400000] Size: 20.00 MB GPT: SEC_EFS [000001800000 - 000001400000] Size: 20.00 MB GPT: PARAM [000002C00000 - 000000800000] Size: 8.00 MB GPT: UP_PARAM [000003400000 - 000000800000] Size: 8.00 MB GPT: BOTA [000003C00000 - 000001E00000] Size: 30.00 MB GPT: KEYSTORAGE [000005A00000 - 000000080000] Size: 512.00 KB GPT: STEADY [000005A80000 - 000000400000] Size: 4.00 MB GPT: UH [000005E80000 - 000000200000] Size: 2.00 MB GPT: UHCFG [000006080000 - 000000400000] Size: 4.00 MB GPT: DTBO [000006480000 - 000000800000] Size: 8.00 MB GPT: BLCMD [000006C80000 - 000000010000] Size: 64.00 KB GPT: BOOT [000006C90000 - 000003B00000] Size: 59.00 MB GPT: RECOVERY [00000A790000 - 0000043D0000] Size: 67.81 MB GPT: RADIO [00000EB60000 - 000004600000] Size: 70.00 MB GPT: CP_DEBUG [000013160000 - 000000500000] Size: 5.00 MB GPT: NAD_REFER [000013660000 - 000000100000] Size: 1.00 MB GPT: PERSISTENT [000013760000 - 000000080000] Size: 512.00 KB GPT: MISC [0000137E0000 - 000000100000] Size: 1.00 MB GPT: KEYREFUGE [0000138E0000 - 000001000000] Size: 16.00 MB GPT: KEYDATA [0000148E0000 - 000001000000] Size: 16.00 MB GPT: DQMDBG [0000158E0000 - 000001000000] Size: 16.00 MB GPT: VBMETA [0000168E0000 - 000000010000] Size: 64.00 KB GPT: VBMETA_SAMSUNG [0000168F0000 - 000000010000] Size: 64.00 KB GPT: METADATA [000016900000 - 000002000000] Size: 32.00 MB GPT: SUPER [000018900000 - 000197800000] Size: 6.37 GB GPT: PRISM [0001B0100000 - 000032000000] Size: 800.00 MB GPT: OPTICS [0001E2100000 - 000001400000] Size: 20.00 MB GPT: CACHE [0001E3500000 - 00000C800000] Size: 200.00 MB GPT: OMR [0001EFD00000 - 000003200000] Size: 50.00 MB GPT: SPU [0001F2F00000 - 000003200000] Size: 50.00 MB GPT: NAD_FW [0001F6100000 - 000001400000] Size: 20.00 MB GPT: USERDATA [0001F7500000 - 001BD2400000] Size: 111.29 GB GPT Backup Header Not Found Reading Table Completed Scanning GUID Partition Table from LUN 1 GPT Signature Not Found. Break.. Scanning GUID Partition Table from LUN 2 GPT Signature Not Found. Break.. Scanning GUID Partition Table from LUN 3 GUID Partition Table is Found. Max Parts: 128 GPT: GPT [000000000000 - 000000006000] Size: 24.00 KB GPT: CPEFS [000000016000 - 000000600000] Size: 6.00 MB GPT: BACKUP_GPT [0000007FB000 - 000000005000] Size: 20.00 KB Reading Table Completed Scanning GUID Partition Table from LUN 4 GPT Signature Not Found. Break.. Reading Initial Data. Please Wait.. META: SUPER, Ver: 10.0, Parts: 4, Used: 38, Not Used: -34 META: METADATA_LAYOUT [000018900000 - 000000004000] Size: 16.00 KB META: SYSTEM [000018A00000 - 0001110FA000] Size: 4.27 GB META: VENDOR [000137E00000 - 000023806000] Size: 568.02 MB META: PRODUCT [00015BC00000 - 000029072000] Size: 656.45 MB META: ODM [000184D00000 - 000000426000] Size: 4.15 MB Partition #2 - [EFS] mount as [/mnt/vendor/efs] -> 20.00 MB, Type: EXTx Partition #3 - [SEC_EFS] mount as [/efs] -> 20.00 MB, Type: EXTx Partition #25 - [METADATA] mount as [/metadata] -> 32.00 MB, Type: EXTx Partition #26 -> #2 - [SUPER -> SYSTEM] mount as [/dev_1] -> 4.27 GB, Type: EXTx Partition #26 -> #3 - [SUPER -> VENDOR] mount as [/vendor] -> 568.02 MB, Type: EXTx Partition #26 -> #4 - [SUPER -> PRODUCT] mount as [/product] -> 656.45 MB, Type: EXTx Partition #26 -> #5 - [SUPER -> ODM] mount as [/odm] -> 4.15 MB, Type: EXTx Partition #27 - [PRISM] mount as [/prism] -> 800.00 MB, Type: EXTx Partition #28 - [OPTICS] mount as [/optics] -> 20.00 MB, Type: EXTx Partition #29 - [CACHE] mount as [/cache] -> 200.00 MB, Type: EXTx Partition #30 - [OMR] mount as [/omr] -> 50.00 MB, Type: EXTx Partition #33 - [USERDATA] mount as [/USERDATA] -> 111.29 GB, Type: F2FS Partition #2 - [CPEFS] mount as [/mnt/vendor/cpefs] -> 6.00 MB, Type: EXTx EmptyCheck: EMPTY -> LUN0 -> Part #6 - [BOTA] EMPTY -> LUN0 -> Part #10 - [UHCFG] EMPTY -> LUN0 -> Part #12 - [BLCMD] EMPTY -> LUN0 -> Part #17 - [NAD_REFER] EMPTY -> LUN0 -> Part #19 - [MISC] EMPTY -> LUN0 -> Part #20 - [KEYREFUGE] EMPTY -> LUN0 -> Part #21 - [KEYDATA] EMPTY -> LUN0 -> Part #22 - [DQMDBG] EMPTY -> LUN0 -> Part #31 - [SPU] EMPTY -> LUN0 -> Part #32 - [NAD_FW] EmptyCheck: Done ================================= Warning! Device Blocked by FRP For Reset FRP Try to Tools Tab Press Reset FRP Button Partition: #18 -> LUN0 -> 'PERSISTENT' ================================= Android Info: Brand = samsung Vendor = samsung Device = a51 Model = SM-A515F Name ID = a51nsxx Product = a51 CPU ABI = arm64-v8a Android Version = 13 Firm Version = TP1A.220624.014.A515FXXU8HWI1 Inc. Version = A515FXXU8HWI1 Firm Date = Thu Sep 21 13:26:04 +07 2023 Security Patch = 2023-08-01 Platform = universal9611 FRP Path = /dev/block/persistent Samsung S/N = RZ8MC1263AT Scanner Thread Terminated Elapsed: 00:00:34:972 Found 37 Partition(s).. Scan Done. Init Main Engine... Use EasyJtag UFS Device: KLUDG4U1EA-B0C1 Reader Engine Initialized.. 0/OK Source: EasyJtag Port [UFS] Power Mode: LOW Generation: GPT [QC/SAMS/BCM/INTEL/MTK] Config: 1011111111101111 Operation Done: [Init Engine], Elapsed: 00:00:00:273 Reset Google FRP v2.0 Search Google FRP Partition.. Partition #18 -> 'PERSISTENT' is FRP. Erasing Partition. Please Wait.. Erasing Done Backup Saved as: D:\Program Files\Z3X\EmmcManager-1.24-15-03-2024\Backup\FRP_BACKUP_0x000013760000_0x20240329_1 61937.bin Reset Google FRP Done Elapsed Time: [00:00:13:633] Operation Done: [Reset FRP], Elapsed: 00:00:13:712 Session is Closed.. |
