03-29-2024, 15:33 | #1 (permalink) |
Freak Poster Join Date: Jun 2003 Location: www.elektronika-s.hr Age: 53
Member: 30623 Status: Offline Thanks Meter: 68 | hyunix h9tq64a8gtac read dump Is it possible read dump from EMCP if detected like "eMMC is unusable" Here is log Code: 29.3.2024. 11:09:30> Looking for EasyJTAG box... 29.3.2024. 11:09:30> EasyJTAG API ver. 3800 29.3.2024. 11:09:30> OpenUSB return = 0 29.3.2024. 11:09:30> EasyJTAG Box Serial = xxxxx 29.3.2024. 11:09:30> Card Serial = xxxx 29.3.2024. 11:09:30> EasyJTAG Box Firmware = 2,5302 29.3.2024. 11:09:30> 29.3.2024. 11:09:30> Firehose loaders: 427 29.3.2024. 11:09:30> 29.3.2024. 11:09:30> 29.3.2024. 11:09:30> 29.3.2024. 11:09:50> Operation: Connect to Z3X EasyJtagPlus 29.3.2024. 11:09:50> 29.3.2024. 11:09:51> Setting Interface to EasyJtag2/E-Socket 29.3.2024. 11:09:51> Setting IO Levels to 2.8V 29.3.2024. 11:09:51> Setting Frequence to 42 Mhz 29.3.2024. 11:09:51> Setting BusWidth to Auto 29.3.2024. 11:09:51> Setting HS Timing to Disabled 29.3.2024. 11:09:51> 29.3.2024. 11:09:58> EMMC Device Information : 29.3.2024. 11:09:58> EMMC CID: 65646F4D204D4F5212A10000 6154431 29.3.2024. 11:09:58> EMMC CSD: D07FFF32 F59007FF6DB80001E40001D 29.3.2024. 11:09:58> Manufacturer: UNKNOWN , NAME: MMOR , HEX: 4D004D4F5200 , S/N: 00000615 , Rev: A1 29.3.2024. 11:09:58> Manufacturer ID: 65 , OEM ID: 6F , Device Type: Device (removable) , Date: 4/2017 29.3.2024. 11:09:58> EMMC ROM 1 (Main User Data) Capacity: 2095982 MB (0x01FFB6E00000) 29.3.2024. 11:09:58> EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 2048 KB (0x000000200000) 29.3.2024. 11:09:58> EMMC RPMB Capacity: 128 KB (0x000000020000) , Counter: 0 , Response: Maybe not Clean 29.3.2024. 11:09:58> Extended CSD Information : 29.3.2024. 11:09:58> Extended CSD rev: 1.5 (MMC 4.41) 29.3.2024. 11:09:58> Boot configuration [PARTITION_CONFIG]: 0x78 , User area enabled for boot , Boot ACK 29.3.2024. 11:09:58> Boot Bus Config: 0x00 , x1 (sdr) or x4 (ddr) bus width in boot operation mode 29.3.2024. 11:09:58> H/W Reset Function [RST_N_FUNCTION]: 0x00 , RST_n signal is temporarily disabled 29.3.2024. 11:09:58> Supported partition features [PARTITIONING_SUPPORT]: 0x03 29.3.2024. 11:09:58> Device supports partitioning features Device can have enhanced technological features in partitions and user data area 29.3.2024. 11:09:58> Partition settings [PARTITION_SETTING_COMPLETED]: 0x00 29.3.2024. 11:24:45> EMMC Init completed 29.3.2024. 11:24:45> Extcsd backup saved: MMOR_00000615_20240329_102433.extcsd (old backup) 29.3.2024. 11:24:45> Warning: Maybe your EMMC is damaged 29.3.2024. 11:24:45> 29.3.2024. 11:24:45> eMMC is unusable 29.3.2024. 11:24:45> 29.3.2024. 11:24:45> Error: Could not connect to device |
