Old 06-29-2020, 09:48   #1 (permalink)
Crazy Poster
Member: 1402783
Thanks Meter: 5
f11 pro error flashing easy jtag
https://imgur.com/udG6NSp
https://imgur.com/FBfIYVGeMMC_tool Suite ver. 1.6.3.0 (release date: 23.06.2020)
Microsoft Windows 7 (32 bit) build 7601 (6.1.7600.16385)
Changelog:
23.06.2020 (ver 1.6.3.0)
Fix: Bugs that have been found through your crash report
Operation: Extract OFP
Filename: CPH1969_11_A.05_190315_07454cfc.ofp
Header found
Extracting files. Please, wait ...
Extracted 35 files
All done
Setting interface to EasyJtag2/ISP_HiPower
Setting bus width to 1 Bit
HiPower mode is ON
Setting frequence to 24 MHz
CMD Pullup Level: 1010 mV
CMD Active Level: 1796 mV
Can't init device. Reason: CMD Timeout Error
HiPower mode is ON
CMD Pullup Level: 1697 mV
CMD Active Level: 1855 mV
HiPower mode is ON
CMD Pullup Level: 1700 mV
CMD Active Level: 1857 mV
HiPower mode is ON
CMD Pullup Level: 1701 mV
CMD Active Level: 1856 mV
HiPower mode is ON
HiPower mode is ON
CMD Pullup Level: 1715 mV
CMD Active Level: 1862 mV
HiPower mode is ON
CMD Pullup Level: 1805 mV
CMD Active Level: 1872 mV
EMMC Device Information :
EMMC CID: 15010033483643414202449BCC4516B3
EMMC CSD: D02701320F5903FFF6DBFFEF8E40400D
EMMC Manufacture : SAMSUNG , EMMC NAME: 3H6CAB , HEX: 334836434142 , S/N: 449BCC45 , rev. 0x02
EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 1/2019
EMMC ROM 1 (Main User Data) Capacity: 59640 MB (000E8F800000)
EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000)
EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 KB (000001000000) Counter: 1533 , Response: Not Clean
EMMC Permanent Write Protection: No
EMMC Temporary Write Protection: No
Extended CSD Information :
Extended CSD rev: 1.8 (MMC 5.1)
Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1)
Boot Bus Config: 0x02 , width 8bit
H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled
Supported partition features [PARTITIONING_SUPPORT]: 0x07
Device supports partitioning features
Device can have enhanced technological features in partitions and user data area
Device can have extended partitions attribute
Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00
Backup saved: 3H6CAB_449BCC45_20200629_161750.extcsd
EMMC Init completed.
Scanning soft partitions
GPT header is found and is valid
Partition: boot_para, [000000008000 - 000000108000], size: 000000100000 (1.00 MB)
Partition: recovery, [000000108000 - 000004108000], size: 000004000000 (64.0 MB)
Partition: para, [000004108000 - 000004188000], size: 000000080000 (512. KB)
Partition: opporeserve1, [000004188000 - 000004988000], size: 000000800000 (8.00 MB)
Partition: opporeserve2, [000004988000 - 000008988000], size: 000004000000 (64.0 MB)
Partition: opporeserve3, [000008988000 - 00000C988000], size: 000004000000 (64.0 MB)
Partition: oppo_custom, [00000C988000 - 00000CA88000], size: 000000100000 (1.00 MB)
Partition: expdb, [00000CA88000 - 00000DE88000], size: 000001400000 (20.0 MB)
Partition: frp, [00000DE88000 - 00000DF88000], size: 000000100000 (1.00 MB)
Partition: nvcfg, [00000DF88000 - 00000FF88000], size: 000002000000 (32.0 MB)
Partition: nvdata, [00000FF88000 - 000013F88000], size: 000004000000 (64.0 MB)
Partition: metadata, [000013F88000 - 000015F88000], size: 000002000000 (32.0 MB)
Partition: protect1, [000015F88000 - 000016788000], size: 000000800000 (8.00 MB)
Partition: protect2, [000016788000 - 000017000000], size: 000000878000 (8.47 MB)
Partition: seccfg, [000017000000 - 000017800000], size: 000000800000 (8.00 MB)
Partition: persist, [000017800000 - 00001A800000], size: 000003000000 (48.0 MB)
Partition: sec1, [00001A800000 - 00001AA00000], size: 000000200000 (2.00 MB)
Partition: proinfo, [00001AA00000 - 00001AD00000], size: 000000300000 (3.00 MB)
Partition: md1img, [00001AD00000 - 000021100000], size: 000006400000 (100. MB)
Partition: spmfw, [000021100000 - 000021200000], size: 000000100000 (1.00 MB)
Partition: scp1, [000021200000 - 000021800000], size: 000000600000 (6.00 MB)
Partition: scp2, [000021800000 - 000021E00000], size: 000000600000 (6.00 MB)
Partition: sspm_1, [000021E00000 - 000021F00000], size: 000000100000 (1.00 MB)
Partition: sspm_2, [000021F00000 - 000022000000], size: 000000100000 (1.00 MB)
Partition: cam_vpu1, [000022000000 - 000022F00000], size: 000000F00000 (15.0 MB)
Partition: cam_vpu2, [000022F00000 - 000023E00000], size: 000000F00000 (15.0 MB)
Partition: cam_vpu3, [000023E00000 - 000024D00000], size: 000000F00000 (15.0 MB)
Partition: gz1, [000024D00000 - 000025D00000], size: 000001000000 (16.0 MB)
Partition: gz2, [000025D00000 - 000026D00000], size: 000001000000 (16.0 MB)
Partition: nvram, [000026D00000 - 00002AD00000], size: 000004000000 (64.0 MB)
Partition: lk, [00002AD00000 - 00002B200000], size: 000000500000 (5.00 MB)
Partition: lk2, [00002B200000 - 00002B700000], size: 000000500000 (5.00 MB)
Partition: boot, [00002B700000 - 00002D700000], size: 000002000000 (32.0 MB)
Partition: logo, [00002D700000 - 00002E700000], size: 000001000000 (16.0 MB)
Partition: dtbo, [00002E700000 - 00002F700000], size: 000001000000 (16.0 MB)
Partition: tee1, [00002F700000 - 00002FC00000], size: 000000500000 (5.00 MB)
Partition: tee2, [00002FC00000 - 000030800000], size: 000000C00000 (12.0 MB)
Partition: odm, [000030800000 - 000040800000], size: 000010000000 (256. MB)
Partition: vendor, [000040800000 - 000083800000], size: 000043000000 (1.05 GB)
Partition: system, [000083800000 - 0001D0800000], size: 00014D000000 (5.20 GB)
Partition: cache, [0001D0800000 - 0001EB800000], size: 00001B000000 (432. MB)
Partition: userdata, [0001EB800000 - 000E8BCFBE00], size: 000CA04FBE00 (50.5 GB)
Partition: otp, [000E8BCFBE00 - 000E8E7FBE00], size: 000002B00000 (43.0 MB)
Partition: flashinfo, [000E8E7FBE00 - 000E8F7FBE00], size: 000001000000 (16.0 MB)
GPT header successfully parsed
HiPower mode is ON
Backup saved: 3H6CAB_449BCC45_20200629_161802.extcsd
Opening file: MT6771_Android_scatter.txt
The new format of scatter
config_version: V1.1.2
platform: MT6771
preloader_oppo6771_18531.bin
Found 10 supported eMMC CID:
name = 'DV6DMB' hex = 0x445636444D42 [SAMSUNG]
name = '3V6CMB' hex = 0x335636434D42 [SAMSUNG]
name = '3H6CAB' hex = 0x334836434142 [SAMSUNG]
name = 'hC8aP>' hex = 0x68433861503E [SKHYNIX]
name = 'S0J9K9' hex = 0x53304A394B39 [MICRON]
name = 'DH6DAB' hex = 0x444836444142 [SAMSUNG]
name = 'S0J9K8' hex = 0x53304A394B38 [MICRON]
name = 'S0J9M9' hex = 0x53304A394D39 [MICRON]
Maybe external DRAM detected
The size of the last section has been updated
HiPower mode is ON
CMD Pullup Level: 1806 mV
CMD Active Level: 1873 mV
Backup saved: 3H6CAB_449BCC45_20200629_161824.extcsd
Operation: Write by vendor (MediaTek)
Creating GPT-partitioninig
Writing PrimaryGPT at address: 000000000000
Writing BackupGPT at address: 000E8F7FBE00
GPT-partitioning done
Partition name: preloader
Filename: preloader_oppo6771_18531.bin , Offset: 000000000000 , filesize: 265004 bytes
eMMC switching to ROM3
Erasing partition...
Writing partition...
Done writing partition. Write speed: 796.30 KB/s
eMMC switching to ROM2
Done writing partition. Write speed: 792.73 KB/s
Partition name: recovery
Filename: recovery.img , Offset: 000000108000 , filesize: 35857264 bytes
eMMC switching to ROM1
Done writing partition. Write speed: 2605.11 KB/s
Partition name: opporeserve2
Filename: opporeserve2.img , Offset: 000004988000 , filesize: 5300372 bytes
Sparse image found v.1.0 Total chunks: 10
Done writing partition. Write speed: 2663.26 KB/s
Partition name: md1img
Filename: md1img.img , Offset: 00001AD00000 , filesize: 87854112 bytes
Error writing at address: 00001F120000 , error: -8, DATA SND CRC Error(Small ROM Size, maybe) ... Retry #1
Error writing at address: 00001F120000 , error: -1, CMD Timeout Error ... Retry #2
Done writing partition. Write speed: 2666.96 KB/s
Partition name: spmfw
Filename: spmfw.img , Offset: 000021100000 , filesize: 40576 bytes
Done writing partition. Write speed: 621.96 KB/s
Partition name: scp1
Filename: scp.img , Offset: 000021200000 , filesize: 585888 bytes
Done writing partition. Write speed: 2020.31 KB/s
Partition name: scp2
Filename: scp.img , Offset: 000021800000 , filesize: 585888 bytes
Done writing partition. Write speed: 2591.43 KB/s
Partition name: sspm_1
Filename: sspm.img , Offset: 000021E00000 , filesize: 496464 bytes
Done writing partition. Write speed: 2198.86 KB/s
Partition name: sspm_2
Filename: sspm.img , Offset: 000021F00000 , filesize: 496464 bytes
Done writing partition. Write speed: 2580.13 KB/s
Partition name: cam_vpu1
Filename: cam_vpu1.img , Offset: 000022000000 , filesize: 1652768 bytes
Done writing partition. Write speed: 2484.19 KB/s
Partition name: cam_vpu2
Filename: cam_vpu2.img , Offset: 000022F00000 , filesize: 14225552 bytes
Done writing partition. Write speed: 2717.12 KB/s
Partition name: cam_vpu3
Filename: cam_vpu3.img , Offset: 000023E00000 , filesize: 6027760 bytes
Done writing partition. Write speed: 2656.94 KB/s
Partition name: lk
Filename: lk.img , Offset: 00002AD00000 , filesize: 1123344 bytes
Done writing partition. Write speed: 2362.60 KB/s
Partition name: lk2
Filename: lk.img , Offset: 00002B200000 , filesize: 1123344 bytes
Done writing partition. Write speed: 2586.40 KB/s
Partition name: boot
Filename: boot.img , Offset: 00002B700000 , filesize: 10595184 bytes
Done writing partition. Write speed: 2682.70 KB/s
Partition name: logo
Filename: logo.bin , Offset: 00002D700000 , filesize: 4089360 bytes
Done writing partition. Write speed: 2604.08 KB/s
Partition name: dtbo
Filename: dtbo.img , Offset: 00002E700000 , filesize: 185968 bytes
Done writing partition. Write speed: 1258.81 KB/s
Partition name: tee1
Filename: tee.img , Offset: 00002F700000 , filesize: 507216 bytes
Done writing partition. Write speed: 1953.60 KB/s
Partition name: tee2
Filename: tee.img , Offset: 00002FC00000 , filesize: 507216 bytes
Done writing partition. Write speed: 2458.36 KB/s
Partition name: odm
Filename: odm.img , Offset: 000030800000 , filesize: 6398160 bytes
Sparse image found v.1.0 Total chunks: 15
Done writing partition. Write speed: 2652.91 KB/s
Partition name: vendor
Filename: vendor.img , Offset: 000040800000 , filesize: 781947208 bytes
Error erasing at address: 000067360000 , error: -101, CARD Ready Timeout Error ... Retry #1
Sparse image found v.1.0 Total chunks: 25
Error writing at address: 0000479FA000 , error: -8, DATA SND CRC Error(Small ROM Size, maybe) ... Retry #1
Error writing at address: 0000479FA000 , error: -1, CMD Timeout Error ... Retry #2
Error writing at address: 0000479FA000 , error: -1, CMD Timeout Error ... Retry #3
Error writing at address: 0000525F7000 , error: -8, DATA SND CRC Error(Small ROM Size, maybe) ... Retry #1
Error writing at address: 0000525F7000 , error: -1, CMD Timeout Error ... Retry #2
Error writing at address: 0000525F7000 , error: -1, CMD Timeout Error ... Retry #3
Error writing at address: 00005CF7A000 , error: -8, DATA SND CRC Error(Small ROM Size, maybe) ... Retry #1
Error writing at address: 00005CF7A000 , error: -1, CMD Timeout Error ... Retry #2
Error writing at address: 00005CF7A000 , error: -1, CMD Timeout Error ... Retry #3
Error writing at address: 0000679B7000 , error: -1, CMD Timeout Error ... Retry #1
Error writing at address: 0000679B7000 , error: -1, CMD Timeout Error ... Retry #2
Error writing at address: 0000679B7000 , error: -1, CMD Timeout Error ... Retry #3
Done writing partition. Write speed: 2713.53 KB/s
Writing DL_Info...
Writing DL_Info done
Writing eMMC Register ...
Reg: 179 Value: 0x48
Reg: 177 Value: 0x00
Reg: 162 Value: 0x01
All done time: [00:07:05:000]
HiPower mode is ON
CMD Active Level: 1871 mV
Boot Bus Config: 0x00 , width 1bit
Backup saved: 3H6CAB_449BCC45_20200629_162549.extcsd
Partition name: system
Filename: system.img , Offset: 000083800000 , filesize: 3819930552 bytes
Error erasing at address: 00010EAE0000 , error: -101, CARD Ready Timeout Error ... Retry #1
Error erasing at address: 000196DA0000 , error: -101, CARD Ready Timeout Error ... Retry #1
Sparse image found v.1.0 Total chunks: 77
Error writing at address: 0000888CB000 , error: -8, DATA SND CRC Error(Small ROM Size, maybe) ... Retry #1
Error writing at address: 0000888CB000 , error: -1, CMD Timeout Error ... Retry #2
Error writing at address: 0000888CB000 , error: -1, CMD Timeout Error ... Retry #3
Error writing at address: 00009352B000 , error: -8, DATA SND CRC Error(Small ROM Size, maybe) ... Retry #1
Error writing at address: 00009352B000 , error: -1, CMD Timeout Error ... Retry #2
Error writing at address: 00009352B000 , error: -1, CMD Timeout Error ... Retry #3
Too many errors. Writing has been stopped
HiPower mode is ON
Backup saved: 3H6CAB_449BCC45_20200629_163052.extcsd
HiPower mode is ON
Backup saved: 3H6CAB_449BCC45_20200629_163057.extcsd
Error erasing at address: 000087D60000 , error: -101, CARD Ready Timeout Error ... Retry #1
Error erasing at address: 00010FE40000 , error: -101, CARD Ready Timeout Error ... Retry #1
Error erasing at address: 000195FE0000 , error: -101, CARD Ready Timeout Error ... Retry #1
Error writing at address: 00008878B000 , error: -8, DATA SND CRC Error(Small ROM Size, maybe) ... Retry #1
Error writing at address: 00008878B000 , error: -1, CMD Timeout Error ... Retry #2
Error writing at address: 00008878B000 , error: -1, CMD Timeout Error ... Retry #3
Error writing at address: 00009334B000 , error: -8, DATA SND CRC Error(Small ROM Size, maybe) ... Retry #1
Error writing at address: 00009334B000 , error: -1, CMD Timeout Error ... Retry #2
Error writing at address: 00009334B000 , error: -1, CMD Timeout Error ... Retry #3
HiPower mode is ON
Backup saved: 3H6CAB_449BCC45_20200629_163533.extcsd
Partition name: userdata
Filename: userdata.img , Offset: 0001EB800000 , filesize: 4452308076 bytes
Error erasing at address: 000256100000 , error: -1, CMD Timeout Error ... Retry #1
Error erasing at address: 000256100000 , error: -1, CMD Timeout Error ... Retry #2
Error erasing at address: 000256100000 , error: -1, CMD Timeout Error ... Retry #3
Too many errors. Erasing has been stopped
Old 06-29-2020, 11:22   #2 (permalink)
Member: 1972033
Thanks Meter: 32
make smart report bro
Old 06-29-2020, 16:01   #3 (permalink)
layder's Avatar
Member: 13148
Thanks Meter: 2,948
MTK devices have problem with ISP connection.
For best result - desolder eMMC and use Socket connection
Old 06-30-2020, 07:33   #4 (permalink)
rayaan786's Avatar
Member: 2593918
Thanks Meter: 50
Changelog:
remove emmc try brother
Page generated in 0.24278 seconds with 8 queries
