04-02-2017, 19:39 | #1 (permalink) |
Freak Poster Join Date: Nov 2009
Member: 1168485 Status: Offline Thanks Meter: 36 | j100h repair boot but still dead eMMC_tool Suite ver. 1.0.0.43 Microsoft Windows 7 (64 bit) build 7601 (6.1.7600.16385) Looking for EasyJTAG box... EasyJTAG API ver. 2008 Setting IO Levels to 2.8V Setting frequence to 14 Mhz HiPower mode is OFF EasyJTAG Box Firmware = 01.58 Changelog: 09.03.2017 (ver 1.0.0.43) Fix: Bugs that have been found through your crash report Add: Some improvements Add: Write by vendor "Spreadtrum" (While only SC773X) Add: Search for tables nVidia Tegra Add: Completely rewritten Explorer HiPower mode is OFF CMD Pullup Level: 1784 mV CMD Active Level: 2526 mV EMMC Device Information : EMMC CID: 90014A48344732621101B371CCBE827A EMMC CSD: D07F01320F5903FFFFFFFFEF8A4040DA EMMC Manufacture Name: SKHYNIX EMMC NAME: H4G2b , S/N: B371CCBE , rev. 01 EMMC NAME (HEX): 483447326211 EMMC ROM 1 (Main User Data) Capacity: 3728 MB (0000E9000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Backup saved: H4G2b_B371CCBE_20170402_194506.extcsd EMMC Init completed. Opening file: J13G.pit Pit: J13G.pit Entry count: 29 The size of the last section has been updated BL_J100HXXU0AOA2_CL332283_QB3547216_REV01_user_low _ship.tar.md5 The list of files in the firmware: spl.img sboot.bin sboot2.bin param.lfs HiPower mode is OFF CMD Pullup Level: 1794 mV CMD Active Level: 2536 mV EMMC Device Information : EMMC CID: 90014A48344732621101B371CCBE827A EMMC CSD: D07F01320F5903FFFFFFFFEF8A4040DA EMMC Manufacture Name: SKHYNIX EMMC NAME: H4G2b , S/N: B371CCBE , rev. 01 EMMC NAME (HEX): 483447326211 EMMC ROM 1 (Main User Data) Capacity: 3728 MB (0000E9000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Backup saved: H4G2b_B371CCBE_20170402_194523.extcsd EMMC Init completed. Operation: Write by vendor (Samsung) Creating GPT-partitioninig Writing PIT at address: 000000080000 GPT-partitioning done Unpacking file: spl.img Unpacking file: sboot.bin Unpacking file: sboot2.bin Unpacking file: param.lfs Partition name: BOOT Filename: spl.img , Offset: 000000000000 , filesize: 32768 bytes eMMC switching to ROM2 Erasing partition... Writing partition... Done writing partition. Write speed: 255.40 Kb/s Partition name: SBOOT Filename: sboot.bin , Offset: 000000400000 , filesize: 1573888 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1130.24 Kb/s Partition name: SBOOT2 Filename: sboot2.bin , Offset: 000000600000 , filesize: 1573888 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1131.19 Kb/s Partition name: PARAM Filename: param.lfs , Offset: 000002900000 , filesize: 634880 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 753.75 Kb/s All done AP_J100HXXU0AOA2_CL332283_QB3547216_REV01_user_low _ship_.tar.md5 The list of files in the firmware: boot.img recovery.img system.img CP_J100HXXU0AOA3_CL332283_QB3609726_REV01_user_low _ship.tar.md5 The list of files in the firmware: sprdcp.img sprddsp.img nvitem.bin CSC_OJV_J100HOJV0AOA2_CL332283_QB3547216_REV01_use r_low_ship.tar.md5 The list of files in the firmware: j13g.pit cache.img hidden.img HiPower mode is OFF CMD Pullup Level: 2701 mV CMD Active Level: 2825 mV Can't init device. Reason: CMD Timeout Error Error: Previous operation is not finished yet. HiPower mode is OFF CMD Pullup Level: 1794 mV Error: Previous operation is not finished yet. CMD Active Level: 2526 mV Can't init device. Reason: OCR Ready Timeout Error [Check VCC or eMMC DEAD] HiPower mode is OFF CMD Pullup Level: 1784 mV CMD Active Level: 2371 mV Can't init device. Reason: OCR Ready Timeout Error [Check VCC or eMMC DEAD] HiPower mode is OFF CMD Pullup Level: 1773 mV CMD Active Level: 2557 mV EMMC Device Information : EMMC CID: 90014A48344732621101B371CCBE827A EMMC CSD: D07F01320F5903FFFFFFFFEF8A4040DA EMMC Manufacture Name: SKHYNIX EMMC NAME: H4G2b , S/N: B371CCBE , rev. 01 EMMC NAME (HEX): 483447326211 EMMC ROM 1 (Main User Data) Capacity: 3728 MB (0000E9000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Backup saved: H4G2b_B371CCBE_20170402_194845.extcsd EMMC Init completed. Operation: Write by vendor (Samsung) Creating GPT-partitioninig Writing PIT at address: 000000080000 GPT-partitioning done Unpacking file: spl.img Unpacking file: sboot.bin Unpacking file: sboot2.bin Unpacking file: nvitem.bin Unpacking file: sprddsp.img Unpacking file: sprdcp.img Unpacking file: param.lfs Unpacking file: boot.img Unpacking file: recovery.img Unpacking file: cache.img Unpacking file: system.img Unpacking file: hidden.img Partition name: BOOT Filename: spl.img , Offset: 000000000000 , filesize: 32768 bytes eMMC switching to ROM2 Erasing partition... Writing partition... Done writing partition. Write speed: 254.55 Kb/s Partition name: SBOOT Filename: sboot.bin , Offset: 000000400000 , filesize: 1573888 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1131.52 Kb/s Partition name: SBOOT2 Filename: sboot2.bin , Offset: 000000600000 , filesize: 1573888 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1119.68 Kb/s Partition name: WFIXNV2 Filename: nvitem.bin , Offset: 000000900000 , filesize: 174856 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 822.77 Kb/s Partition name: WDSP Filename: sprddsp.img , Offset: 000000C00000 , filesize: 1968128 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1189.88 Kb/s Partition name: MODEM Filename: sprdcp.img , Offset: 000001000000 , filesize: 7375844 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 903.74 Kb/s Partition name: PARAM Filename: param.lfs , Offset: 000002900000 , filesize: 634880 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 742.62 Kb/s Partition name: KERNEL Filename: boot.img , Offset: 000004500000 , filesize: 5661696 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 905.77 Kb/s Partition name: RECOVERY Filename: recovery.img , Offset: 000005500000 , filesize: 6992896 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 917.51 Kb/s Partition name: CSC Filename: cache.img , Offset: 000006500000 , filesize: 22569232 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Sparse image found v.1.0 Total chunks: 15 Done writing partition. Write speed: 1004.38 Kb/s Partition name: SYSTEM Filename: system.img , Offset: 000012D00000 , filesize: 986538384 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Sparse image found v.1.0 Total chunks: 23 Error writing at address: 000026D00000 ... Retry #1 Done writing partition. Write speed: 869.42 Kb/s Partition name: HIDDEN Filename: hidden.img , Offset: 000053D00000 , filesize: 7762160 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Sparse image found v.1.0 Total chunks: 13 Done writing partition. Write speed: 1135.72 Kb/s All done |
04-02-2017, 19:41 | #2 (permalink) |
Member: 1168485 Status: Offline Thanks Meter: 36 | j100h repair boot but still dead Z3X EasyJtag Software ver. 2.5.0.8 Loading eMMC Addon Firmware... IO: 2800 mV CMD Pullup Level:1773 mV CMD Active Level:2567 mV Box IO Level:2800 mV CLK Rate:14000 khz HiPower mode is off! ---------- eMMC Device Information ---------- EMMC CID : 90014A48344732621101B371CCBE827A EMMC CSD : D07F01320F5903FFFFFFFFEF8A4040DA EMMC Manufacturer ID: 0090 , OEM ID: 014A EMMC Date: 08/2015 Rev.0x1 EMMC NAME: H4G2b , S/N: 3010579646 EMMC NAME (HEX): 48344732622000 EMMC ROM1 (Main User Data) Capacity: 3728 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.6 (MMC 4.5) Boot configuration [PARTITION_CONFIG: 0x08] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x08. H/W reset function [RST_N_FUNCTION]: 0x00 High-capacity W protect group size [HC_WP_GRP_SIZE: 0x00000000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: H4G2b _3010579646_20170402_2035.extcsd Done. Checking NAND Image : C:\Users\abou mhamad\Desktop\SM-J100h_J100HXCU0AOD4_ROM1_OK.bin File successefuly loaded! Checking NAND Image : C:\Program Files\Z3X\EASYJTAG\Backups\H4G2b _3010579646_20170402_1924.extcsd File successefuly loaded! Processing file...C:\Program Files\Z3X\EASYJTAG\Backups\H4G2b _3010579646_20170402_1924.extcsd ROM1 Are not selected , skip writing ROM1 Processing file...C:\Users\abou mhamad\Desktop\SM-J100h_J100HXCU0AOD4_ROM1_OK.bin ROM3 Are not selected , skip writing ROM3 Running:Repair extCSD... Z3X EasyJtag Software ver. 2.5.0.8 Skip loading eMMC Addon Firmware CMD Pullup Level:1773 mV CMD Active Level:2567 mV Box IO Level:2800 mV CLK Rate:14000 khz Writing... Done. Z3X EasyJtag Software ver. 2.5.0.8 Skip loading eMMC Addon Firmware CMD Pullup Level:1773 mV CMD Active Level:2567 mV Input file : C:\Users\abou mhamad\Desktop\SM-J100h_J100HXCU0AOD4_ROM1_OK.bin Writing 0000400000 bytes to 0000000000 ...ROM2 (BOOT1 ROM) Done. Write Speed: 1184 kB/s Report Post |
