07-13-2020, 20:32 | #1 (permalink) |
No Life Poster Join Date: Nov 2015 Location: DHAKA
Member: 2489690 Status: Offline Thanks Meter: 289 | j260f dead boot repair done Setting bus width to 1 Bit Setting frequence to 36 MHz CMD Pullup Level: 457 mV CMD Active Level: 1740 mV EMMC Device Information : EMMC CID: 150100464E36324D42005D71D3C9859F EMMC CSD: D02701320F5903FFF6DBFFEF8E40400D EMMC Manufacture : SAMSUNG , EMMC NAME: FN62MB , HEX: 464E36324D42 , S/N: 5D71D3C9 , rev. 0x00 EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 8/2018 EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 2 , Response: Not Clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x01 , width 4bit H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: FN62MB_5D71D3C9_20200713_211940.extcsd EMMC Init completed. Operation: Universal Factory Format Please, wait ... Successfully Setting interface to EasyJtag2/ISP Setting bus width to 1 Bit Setting frequence to 36 MHz CMD Pullup Level: 458 mV CMD Active Level: 1739 mV EMMC Device Information : EMMC CID: 150100464E36324D42005D71D3C9859F EMMC CSD: D02701320F5903FFF6DBFFEF8E40400D EMMC Manufacture : SAMSUNG , EMMC NAME: FN62MB , HEX: 464E36324D42 , S/N: 5D71D3C9 , rev. 0x00 EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 8/2018 EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 2 , Response: Not Clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x01 , width 4bit H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: FN62MB_5D71D3C9_20200713_212058.extcsd EMMC Init completed. Operation: Writing all eMMC Regions... Writing to: ROM2 , start: 0x000000000000 , size: 0x000000400000 Filename: SAMSUNG_SM-J260F_emmc_dump_ROM2_SAMSUNG_FN62MB.BIN eMMC switching to ROM2 Writing partition... Done writing partition. Write speed: 642.65 KB/s Writing to: ROM3 , start: 0x000000000000 , size: 0x000000400000 Filename: SAMSUNG_SM-J260F_emmc_dump_ROM3_SAMSUNG_FN62MB.BIN eMMC switching to ROM3 Writing partition... Done writing partition. Write speed: 645.84 KB/s Writing to: ROM1 , start: 0x000000000000 , size: 0x00006F100000 Filename: SAMSUNG_SM-J260F_emmc_dump_ROM1_2GB_SAMSUNG_FN62MB.bin eMMC switching to ROM1 Writing partition... Done writing partition. Write speed: 3594.07 KB/s All done time: [00:08:42:737] |
The Following 3 Users Say Thank You to chadzar For This Useful Post: |
