12-26-2019, 12:57 | #1 (permalink) |
Freak Poster Join Date: Feb 2012 Location: iran
Member: 1724300 Status: Offline Thanks Meter: 42 | j610f rpmb , but hmac mismatch after change cpu Merry Christmas and a Happy New Year this one samsung j610f after chang cpu cpu is dead error phone rpmb , but hmac mismatch mr layder how to Troubleshooting log ---------- eMMC Device Information ---------- eMMC CID : 150100475836424D420017F6060C9521 eMMC CSD : D02701320F5903FFF6DBFFEF8E40400D eMMC Manufacturer ID: 0015 , OEM ID: 0100 eMMC Date: 09/2018 Rev.0x0 eMMC NAME: GX6BMB , S/N: 401999372 eMMC NAME (HEX): 475836424D42 EMMC ROM1 (Main User Data) Capacity: 29820 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 kB EMMC RPMB is programmed and written 83 times EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG: 0x38] Boot from:ROM1 (Main User Area) Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x38. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: GX6BMB_ 401999372_20191226_1526.extcsd Found valid GPT with protective MBR; using GPT. Real (Hardware) Disk/Image size: 3A3E000 sectors 29.1 GiB Soft (Partitioned) Disk/Image size: 3A3DFBC sectors 29.1 GiB Disk identifier (GUID): 98101B32-BBE2-4BF2-A06E-2BB33D000C20 Logical sector size: 0x200 bytes ,First/Last usable sector: 34,61071326 Partition info successfully found ------ Detected 53 partitions ------ P0 (SBL1) [0x400000 0x80000] Size: 512.0KB P1 (SBL1BAK) [0x480000 0x80000] Size: 512.0KB P2 (DDR) [0x500000 0x8000] Size: 32.0KB P3 (LIMITS) [0x508000 0x8000] Size: 32.0KB P4 (ABOOT) [0x510000 0x200000] Size: 2.0MB P5 (RPM) [0x710000 0x80000] Size: 512.0KB P6 (TZ) [0x790000 0x200000] Size: 2.0MB P7 (HYP) [0x990000 0x80000] Size: 512.0KB P8 (DEVCFG) [0xa10000 0x40000] Size: 256.0KB P9 (FSG) [0xa50000 0x300000] Size: 3.0MB P10 (SEC) [0xd50000 0x4000] Size: 16.0KB P11 (KEYMASTER) [0xd54000 0x80000] Size: 512.0KB P12 (CMNLIB) [0xdd4000 0x40000] Size: 256.0KB P13 (CMNLIB64) [0xe14000 0x40000] Size: 256.0KB P14 (LKSECAPP) [0xe54000 0x80000] Size: 512.0KB P15 (APDP) [0xed4000 0x40000] Size: 256.0KB P16 (MDSAP) [0xf14000 0x40000] Size: 256.0KB P17 (PAD) [0xf54000 0xac000] Size: 688.0KB P18 (MODEMST1) [0x1000000 0x300000] Size: 3.0MB P19 (MODEMST2) [0x1300000 0x300000] Size: 3.0MB P20 (PARAM) [0x1600000 0xa00000] Size: 10.0MB P21 (EFS) [0x2000000 0xe00000] Size: 14.0MB P22 (BOOT) [0x2e00000 0x2000000] Size: 32.0MB P23 (RECOVERY) [0x4e00000 0x2000000] Size: 32.0MB P24 (DTBO) [0x6e00000 0x800000] Size: 8.0MB P25 (BOTA) [0x7600000 0x700000] Size: 7.0MB P26 (FOTA) [0x7d00000 0x500400] Size: 5.0MB P27 (BACKUP) [0x8200400 0x5fec00] Size: 5.995MB P28 (FSC) [0x87ff000 0x300000] Size: 3.0MB P29 (SSD) [0x8aff000 0x2000] Size: 8.0KB P30 (PERSIST) [0x8b01000 0x2000000] Size: 32.0MB P31 (PERSISTENT) [0xab01000 0x100000] Size: 1.0MB P32 (MISC) [0xac01000 0x100000] Size: 1.0MB P33 (STEADY) [0xad01000 0x400000] Size: 4.0MB P34 (KEYSTORE) [0xb101000 0x80000] Size: 512.0KB P35 (CONFIG) [0xb181000 0x8000] Size: 32.0KB P36 (MOTA) [0xb189000 0x80000] Size: 512.0KB P37 (DPO) [0xb209000 0x40000] Size: 256.0KB P38 (MDTP) [0xb249000 0x10000] Size: 64.0KB P39 (DIP) [0xb259000 0x100000] Size: 1.0MB P40 (OEM) [0xb359000 0x10000] Size: 64.0KB P41 (MCFG) [0xb369000 0x400000] Size: 4.0MB P42 (DSP) [0xb769000 0x1000000] Size: 16.0MB P43 (MODEM) [0xc769000 0x5b97000] Size: 91.589MB P44 (APNHLOS) [0x12300000 0x3200000] Size: 50.0MB P45 (RESERVED2) [0x15500000 0x300000] Size: 3.0MB P46 (SYSTEM) [0x15800000 0xca800000] Size: 3.164GB P47 (VENDOR) [0xe0000000 0x1e000000] Size: 480.0MB P48 (ODM) [0xfe000000 0xf000000] Size: 240.0MB P49 (CACHE) [0x10d000000 0x12c00000] Size: 300.0MB P50 (HIDDEN) [0x11fc00000 0x6400000] Size: 100.0MB P51 (OMR) [0x126000000 0x1400000] Size: 20.0MB P52 (USERDATA) [0x127400000 0x6207fb000] Size: 24.506GB ------------------------------------ ------ Android information ------ Detected LINUX(Android) SYSTEM : 0x0015800000 (3.164GB) Short EXT fs info: Size: 3.97GB Block size: 4.0KB Inode size: 256 Inodes: 203200 Short Android info: Build ID: M1AJQ Display Build ID: M1AJQ.FA81_J610FXXU3ASG1 Release Incremental ID: FA81_J610FXXU3ASG1 Release Base ID: 8.1.0 Security Path: 2018-08-01 Device Model: SM-J610F Device Manufacturer: samsung Product ID: j6primelte Device Name A: j6primeltedd Device Name B: j6primelte Architecture ABI: armeabi-v7a Device manufacturer: samsung Build Description: j6primeltedd-user 8.1.0 M1AJQ FA81_J610FXXU3ASG1 release-keys PDA ver.: FA81_J610FXXU3ASG1 Samsung CPU: MSM8917 Backup saved: BuildProp_20191226_1526.txt --------------------------------------------- Detected USERDATA USERDATA : 0x0127400000 (24.506GB) Short EXT fs info: Size: 3.577GB Block size: 4.0KB Inode size: 256 Inodes: 234784 Short userdata info: Unable to read gesture.key , code 2 Done. |
12-26-2019, 13:00 | #2 (permalink) |
Member: 1724300 Status: Offline Thanks Meter: 42 | j610f screen shot http://www.mediafire.com/view/29cb58..._2292.JPG/file after flash combination file ****************************/view/n73wi..._2293.JPG/file |
12-26-2019, 14:40 | #3 (permalink) |
Product Supporter Join Date: Jun 2002 Location: Belarus Age: 47
Member: 13148 Status: Offline Thanks Meter: 2,948 | you need change eMMC with clean RPMB or change CPU-eMMC from another board |
The Following 2 Users Say Thank You to layder For This Useful Post: |
