05-07-2017, 13:58 | #1 (permalink) |
Freak Poster Join Date: Jun 2007 Location: Chittagong, Bangladesh, Age: 41
Member: 537240 Status: Offline Sonork: 100.1660416 Thanks Meter: 233 | J700H dead boot repair ( emmc repair) repair done by "MUKTI TELECOM" here log:- Z3X EasyJtag Software ver. 2.5.0.9 Loading eMMC Addon Firmware... IO: 2800 mV Box S/N: 0B00100EE1608FB2, ,FW Ver.: 01.58 CMD Pullup Level:1062 mV CMD Active Level:2134 mV Box IO Level:2800 mV CLK Rate:21000 khz HiPower mode is off! ---------- eMMC Device Information ---------- EMMC CID : 11010034303030373300A937260BA2FE EMMC CSD : D07E00320F5903FFFFFFFFE78A4000D0 EMMC Manufacturer ID: 0011 , OEM ID: 0100 EMMC Date: 10/2015 Rev.0x0 EMMC NAME: 400073 , S/N: 2838963723 EMMC NAME (HEX): 34303030373300 EMMC ROM1 (Main User Data) Capacity: 15028 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.7 (MMC 5.0) Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x01 , width 4bits , Partition config [179]: 0x48. H/W reset function [RST_N_FUNCTION]: 0x00 High-capacity W protect group size [HC_WP_GRP_SIZE: 0x00000000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: 400073_2838963723_20170424_1527.extcsd Partition table scan: GPT: present Found valid GPT with protective MBR; using GPT. Real (Hardware) Disk/Image size: 1D5A000 sectors 14.7 GiB Soft (Partitioned) Disk/Image size: 1D59FBC sectors 14.7 GiB Logical sector size: 0x200 bytes Disk identifier (GUID): 52444E41-494F-2044-4D4D-43204449534B First usable sector: 34 Last usable sector: 30777310 Partition info successfully found --------------------------------------------- P0 (BOTA0) [0x400000 0x400000] Size: 4.0MB P1 (BOTA1) [0x800000 0x400000] Size: 4.0MB P2 (EFS) [0xc00000 0x1400000] Size: 20.0MB P3 (CPEFS) [0x2000000 0x800000] Size: 8.0MB P4 (M9KEFS1) [0x2800000 0x400000] Size: 4.0MB P5 (M9KEFS2) [0x2c00000 0x400000] Size: 4.0MB P6 (M9KEFS3) [0x3000000 0x400000] Size: 4.0MB P7 (CARRIER) [0x3400000 0x100000] Size: 1.0MB P8 (PARAM) [0x3500000 0x800000] Size: 8.0MB P9 (BOOT) [0x3d00000 0x2000000] Size: 32.0MB P10 (RECOVERY) [0x5d00000 0x2600000] Size: 38.0MB P11 (OTA) [0x8300000 0x800000] Size: 8.0MB P12 (CDMA-RADIO) [0x8b00000 0x400000] Size: 4.0MB P13 (RADIO) [0x8f00000 0x5800000] Size: 88.0MB P14 (TOMBSTONES) [0xe700000 0x100000] Size: 1.0MB P15 (DNT) [0xe800000 0x100000] Size: 1.0MB P16 (PERSISTENT) [0xe900000 0x80000] Size: 512.0KB P17 (PERSDATA) [0xe980000 0xc00000] Size: 12.0MB P18 (RESERVED2) [0xf580000 0x280000] Size: 2.500MB P19 (SYSTEM) [0xf800000 0x83800000] Size: 2.54GB P20 (CACHE) [0x93000000 0xc800000] Size: 200.0MB P21 (HIDDEN) [0x9f800000 0x2800000] Size: 40.0MB P22 (USERDATA) [0xa2000000 0x309000000] Size: 12.140GB ------ Android information ------ Detected LINUX(Android) SYSTEM : 0x000F800000 (2.54GB) Build ID: LMY48B Display Build ID: LMY48B.J700HXXU1AOG9 Release ID: 5.1.1 Device Model: SM-J700H Device Name: j7e3gxx Architecture ABI: armeabi-v7a Device manufacturer: samsung Device Platform: exynos5 Product ID: j7e3g Build Description: j7e3gxx-user 5.1.1 LMY48B J700HXXU1AOG9 release-keys Samsung CPU: exynos7580 --------------------------------------------- Done. |
The Following 3 Users Say Thank You to ALI_MAFIA For This Useful Post: |
