08-20-2020, 22:35 | #3 (permalink) |
No Life Poster Join Date: Sep 2006 Location: Allah is Greatest
Member: 358694 Status: Offline Sonork: 100.1597323 Thanks Meter: 994 | Kg Status Locked Dear Easy jtag team.. I have many phones with this problem. KG Status Locked in Download Mode. We cannot write combination or any other firmware. I connect successfully with jtag. Now can u please tell us step by step how can we fix it. |
08-21-2020, 20:34 | #4 (permalink) |
Moderator Join Date: Nov 2009 Location: €urope Age: 41
Member: 1162626 Status: Offline Sonork: 100.1591727 QQ:2337938173 Thanks Meter: 11,110 | A260F finally KG status lock remove done by easy JTAG Plus with in total 30 minutes A260F finally KG status lock remove done by easy JTAG Plus with in total 30 minutes But need some knowledge from Here also Creating gp1 partition eMMC_tool Suite ver. 1.6.3.0 (release date: 23.06.2020) Microsoft Windows 7 (32 bit) build 7601 (6.1.7600.16385) Looking for EasyJTAG box... EasyJTAG API ver. 3401 EasyJTAG Box Serial = F6F272D292237F2E Card Serial = AA2778BA EasyJTAG Box Firmware = 2.5301 Changelog: 23.06.2020 (ver 1.6.3.0) Fix: Bugs that have been found through your crash report Setting interface to EasyJtag2/ISP Setting bus width to 1 Bit Setting frequence to 18 MHz CMD Pullup Level: 416 mV CMD Active Level: 1169 mV EMMC Device Information : EMMC CID: 150100384754463452004DBDFAAEC6EB EMMC CSD: D02701320F5903FFF6DBFFEF8E40400D EMMC Manufacture : SAMSUNG , EMMC NAME: 8GTF4R , HEX: 384754463452 , S/N: 4DBDFAAE , rev. 0x00 EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 12/2019 EMMC ROM 1 (Main User Data) Capacity: 7376 MB (0001CD000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 2 , Response: Not Clean EMMC GP1 (GP Partition 1) Capacity: 40 MB , ENH , WR_REL (000002800000) EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x01 , width 4bit H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x01 Backup saved: 8GTF4R_4DBDFAAE_20200821_210945.extcsd EMMC Init completed. Opening file: A2CORELTE_MEA_OPEN.pit Pit: A2CORELTE_MEA_OPEN.pit Entry count: 31 The size of the last section has been updated BL_A260FXXU3ASF2_CL15641782_QB24253839_REV00_user_ low_ship.tar The list of files in the firmware: sboot.bin.lz4 param.bin.lz4 cm.bin.lz4 AP_A260FXXU3ASF2_CL15641782_QB24253839_REV00_user_ low_ship_meta.tar The list of files in the firmware: boot.img.lz4 recovery.img.lz4 system.img.lz4 userdata.img.lz4 vendor.img.lz4 meta-data/ meta-data/fota.zip CP_A260FJVU3ASF2_CP12997095_CL15641782_QB24253839_ REV00_user_low_ship.tar The list of files in the firmware: modem.bin.lz4 CSC_OMC_OJM_A260FOJM3ASF2_CL16223720_QB24253705_RE V00_user_low_ship.tar The list of files in the firmware: a2corelte_mea_open.pit cache.img.lz4 odm.img.lz4 omr.img.lz4 hidden.img.lz4 Setting interface to EasyJtag2/ISP_HiPower Setting bus width to 1 Bit HiPower mode is ON Setting interface to EasyJtag2/ISP_HiPower Setting bus width to 1 Bit HiPower mode is ON Setting frequence to 24 MHz CMD Pullup Level: 416 mV CMD Active Level: 1169 mV EMMC Device Information : EMMC CID: 150100384754463452004DBDFAAEC6EB EMMC CSD: D02701320F5903FFF6DBFFEF8E40400D EMMC Manufacture : SAMSUNG , EMMC NAME: 8GTF4R , HEX: 384754463452 , S/N: 4DBDFAAE , rev. 0x00 EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 12/2019 EMMC ROM 1 (Main User Data) Capacity: 7376 MB (0001CD000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 2 , Response: Not Clean EMMC GP1 (GP Partition 1) Capacity: 40 MB , ENH , WR_REL (000002800000) EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x01 , width 4bit H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x01 Backup saved: 8GTF4R_4DBDFAAE_20200821_211016.extcsd EMMC Init completed. Operation: Write by vendor (Samsung) Creating GPT-partitioninig Writing PrimaryGPT at address: 000000000000 Writing BackupGPT at address: 0001CCFFBE00 Writing PIT at address: 000000004400 GPT-partitioning done Unpacking file: cm.bin Unpacking Lz4: cm.bin.lz4 Unpacking file: sboot.bin Unpacking Lz4: sboot.bin.lz4 Unpacking file: param.bin Unpacking Lz4: param.bin.lz4 Unpacking file: boot.img Unpacking Lz4: boot.img.lz4 Unpacking file: recovery.img Unpacking Lz4: recovery.img.lz4 Unpacking file: modem.bin Unpacking Lz4: modem.bin.lz4 Unpacking file: system.img Unpacking Lz4: system.img.lz4 Unpacking file: vendor.img Unpacking Lz4: vendor.img.lz4 Unpacking file: odm.img Unpacking Lz4: odm.img.lz4 Unpacking file: cache.img Unpacking Lz4: cache.img.lz4 Unpacking file: hidden.img Unpacking Lz4: hidden.img.lz4 Unpacking file: omr.img Unpacking Lz4: omr.img.lz4 Unpacking file: userdata.img Unpacking Lz4: userdata.img.lz4 Partition name: CM Filename: cm.bin , Offset: 000000000000 , filesize: 2445840 bytes eMMC switching to ROM3 Erasing partition... Writing partition... Done writing partition. Write speed: 988.94 KB/s Partition name: BOOTLOADER Filename: sboot.bin , Offset: 000000000000 , filesize: 1921552 bytes eMMC switching to ROM2 Erasing partition... Writing partition... Done writing partition. Write speed: 995.80 KB/s Partition name: PARAM Filename: param.bin , Offset: 000003500000 , filesize: 624640 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1295.93 KB/s Partition name: BOOT Filename: boot.img , Offset: 000003D00000 , filesize: 18078240 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 2577.95 KB/s Partition name: RECOVERY Filename: recovery.img , Offset: 000005D00000 , filesize: 22323744 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 2760.45 KB/s Partition name: RADIO Filename: modem.bin , Offset: 000008300000 , filesize: 38846736 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 2686.65 KB/s Partition name: SYSTEM Filename: system.img , Offset: 00000E800000 , filesize: 1232354276 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Sparse image found v.1.0 Total chunks: 2982 Done writing partition. Write speed: 2634.45 KB/s Partition name: VENDOR Filename: vendor.img , Offset: 000062800000 , filesize: 101888996 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Sparse image found v.1.0 Total chunks: 422 Done writing partition. Write speed: 2513.21 KB/s Partition name: ODM Filename: odm.img , Offset: 00006D800000 , filesize: 13483252 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Sparse image found v.1.0 Total chunks: 274 Done writing partition. Write speed: 2169.98 KB/s Partition name: CACHE Filename: cache.img , Offset: 000070800000 , filesize: 4882580 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Sparse image found v.1.0 Total chunks: 10 Done writing partition. Write speed: 2717.34 KB/s Partition name: HIDDEN Filename: hidden.img , Offset: 000073000000 , filesize: 6324384 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Sparse image found v.1.0 Total chunks: 11 Done writing partition. Write speed: 2701.78 KB/s Partition name: OMR Filename: omr.img , Offset: 000074100000 , filesize: 4612220 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Sparse image found v.1.0 Total chunks: 8 Done writing partition. Write speed: 2606.96 KB/s Partition name: USERDATA Filename: userdata.img , Offset: 000077200000 , filesize: 307468 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Sparse image found v.1.0 Total chunks: 20 Done writing partition. Write speed: 1724.62 KB/s Partition EFS : formatting as EXT4. Please wait ... Formatting completed Operation: Writing BootConfig ... Reg: 179 Value: 0x48 Reg: 177 Value: 0x01 Reg: 162 Value: 0x00 Done All done time: [00:11:20:798] Setting interface to EasyJtag2/ISP_HiPower Setting bus width to 1 Bit HiPower mode is ON Setting frequence to 24 MHz CMD Pullup Level: 417 mV CMD Active Level: 1169 mV EMMC Device Information : EMMC CID: 150100384754463452004DBDFAAEC6EB EMMC CSD: D02701320F5903FFF6DBFFEF8E40400D EMMC Manufacture : SAMSUNG , EMMC NAME: 8GTF4R , HEX: 384754463452 , S/N: 4DBDFAAE , rev. 0x00 EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 12/2019 EMMC ROM 1 (Main User Data) Capacity: 7376 MB (0001CD000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 2 , Response: Not Clean EMMC GP1 (GP Partition 1) Capacity: 40 MB , ENH , WR_REL (000002800000) EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x01 , width 4bit H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x01 Backup saved: 8GTF4R_4DBDFAAE_20200821_212242.extcsd EMMC Init completed. Scanning soft partitions GPT header is found and is valid Partition: BOTA0, [000000400000 - 000000800000], size: 000000400000 (4.00 MB) Partition: BOTA1, [000000800000 - 000000C00000], size: 000000400000 (4.00 MB) Partition: EFS, [000000C00000 - 000002000000], size: 000001400000 (20.0 MB) Partition: CPEFS, [000002000000 - 000002800000], size: 000000800000 (8.00 MB) Partition: M9KEFS1, [000002800000 - 000002C00000], size: 000000400000 (4.00 MB) Partition: M9KEFS2, [000002C00000 - 000003000000], size: 000000400000 (4.00 MB) Partition: M9KEFS3, [000003000000 - 000003400000], size: 000000400000 (4.00 MB) Partition: NAD_REFER, [000003400000 - 000003500000], size: 000000100000 (1.00 MB) Partition: PARAM, [000003500000 - 000003D00000], size: 000000800000 (8.00 MB) Partition: BOOT, [000003D00000 - 000005D00000], size: 000002000000 (32.0 MB) Partition: RECOVERY, [000005D00000 - 000008300000], size: 000002600000 (38.0 MB) Partition: RADIO, [000008300000 - 00000DB00000], size: 000005800000 (88.0 MB) Partition: PERSISTENT, [00000DB00000 - 00000DB80000], size: 000000080000 (512. KB) Partition: STEADY, [00000DB80000 - 00000DF80000], size: 000000400000 (4.00 MB) Partition: MISC, [00000DF80000 - 00000E080000], size: 000000100000 (1.00 MB) Partition: DTBO, [00000E080000 - 00000E280000], size: 000000200000 (2.00 MB) Partition: RESERVED2, [00000E280000 - 00000E800000], size: 000000580000 (5.50 MB) Partition: SYSTEM, [00000E800000 - 000062800000], size: 000054000000 (1.31 GB) Partition: VENDOR, [000062800000 - 00006D800000], size: 00000B000000 (176. MB) Partition: ODM, [00006D800000 - 000070800000], size: 000003000000 (48.0 MB) Partition: CACHE, [000070800000 - 000073000000], size: 000002800000 (40.0 MB) Partition: HIDDEN, [000073000000 - 000074100000], size: 000001100000 (17.0 MB) Partition: OMR, [000074100000 - 000075900000], size: 000001800000 (24.0 MB) Partition: CP_DEBUG, [000075900000 - 000075E00000], size: 000000500000 (5.00 MB) Partition: NAD_FW, [000075E00000 - 000077200000], size: 000001400000 (20.0 MB) Partition: USERDATA, [000077200000 - 0001CCFFBE00], size: 000155DFBE00 (5.34 GB) GPT header successfully parsed Get firmware version Brand = samsung Manufacturer = samsung Device = a2corelte Model = SM-A260F CPU Abi = armeabi-v7a Android release = 8.1.0 Security Patch = 2019-06-01 Firmware version = OPR6.A260FXXU3ASF2 Firmware date = Thu Jun 13 19:06:25 KST 2019
__________________ -------------------------- Use Search Button to get Instant Result | Follow Forum Rules Avoid Spams in the forum to prevent ban your account. Last edited by ...:::::NP™:::::...; 08-21-2020 at 20:41. |
The Following 13 Users Say Thank You to ...:::::NP™:::::... For This Useful Post: |
08-22-2020, 06:38 | #6 (permalink) |
Member: 1162626 Status: Offline Sonork: 100.1591727 QQ:2337938173 Thanks Meter: 11,110 | I will make a video as soon as possible for this problem how the solved. Of course, Brother, the Phone B.B and network is perfect working. Special thanks to Easy JTAG team they fixed there bug for ISP programming.
__________________ -------------------------- Use Search Button to get Instant Result | Follow Forum Rules Avoid Spams in the forum to prevent ban your account. |
The Following 3 Users Say Thank You to ...:::::NP™:::::... For This Useful Post: |
08-24-2020, 23:51 | #9 (permalink) |
Member: 1162626 Status: Offline Sonork: 100.1591727 QQ:2337938173 Thanks Meter: 11,110 | Make a backup of phone security data before performing any serious operation.Then you need to erased / format the eMMC. It is better for you to watch the tutorial carefully. https://forum.gsmhosting.com/vbb/f67...-jtag-2890672/ Best of luck Sent from my MAR-LX2 using Tapatalk PRO
08-26-2020, 11:28 | #10 (permalink) |
Freak Poster Join Date: Jun 2010 Location: MEXICO
Member: 1318721 Status: Offline Thanks Meter: 166 | brother, the kg lock is on RPMB (Replay Protected Memory Block) I understand that it cannot be written or modified The new security lock is hosted in the controller of the emmc or emcp, thanks for your contribution |
The Following 2 Users Say Thank You to kzafquiel For This Useful Post: |
