Originally Posted by ali1803 hi
i try to update frimware on a001 but get error.i test in 3 emmc but same problem.i do in new emmc and cuse to dead it.any way to update this model whit easy jtag?)sorry bad english)
Setup firmware update mode, wait 2..30 sec...
Success!
Sending eMMC firmware...
Success!
Verifying eMMC firmware...
Success!
Flashing eMMC firmware...
Success!
Repairing eMMC CID...
Can't init device, Reason: OCR Ready Timeout Error [Check VCC or eMMC DEAD]
Done. |
PHP Code:
[COLOR="Red"]Z3X EasyJtag Software ver. 3.6.2.3
Loading eMMC GEN1 Firmware... IO: 3300 mV
Box S/N: 1201401CBB19DC97, ,FW Ver.: 01.63
CMD Pullup Level:1227 mV
CMD Active Level:2114 mV
Box IO Level:3300 mV
CLK Rate:21000 kHz
Bus Width:1bit,SDR
HiPower mode is off!
Can't init device, Reason: CMD Timeout Error
Done.
CMD Pullup Level:2340 mV
CMD Active Level:2897 mV
CLK Rate:21000 kHz
Bus Width:1bit,SDR
---------- eMMC Device Information ----------
eMMC CID : 1501003030303030305620110726589C
eMMC CSD : 902701320F5903FFF6DBFFEF8A404022
eMMC Manufacturer ID: 0015 , OEM ID: 0100
eMMC Date: 05/2005 Rev.0x56
eMMC NAME: 000000 , S/N: 537986854
eMMC NAME (HEX): 303030303030
EMMC ROM1 (Main User Data) Capacity: 16384 MB
EMMC ROM2 (Boot Partition 1) Capacity: 512 kB
EMMC ROM3 (Boot Partition 2) Capacity: 512 kB
EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB
EMMC RPMB is not yet programmed (clear) or RPMB Authentication key not yet programmed
EMMC Permanent Write Protection: No
EMMC Temporary Write Protection: No
EMMC Password Locked: No
Extended CSD rev 1.5 (MMC 4.41)
Boot configuration [PARTITION_CONFIG: 0x00] No boot partition configured.
Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x00.
H/W reset function [RST_N_FUNCTION]: 0x00
High-capacity WP group size [HC_WP_GRP_SIZE: 0x00024000]
Partitioning Support [PARTITIONING_SUPPORT]: 0x03
Device support partitioning feature
Device can have enhanced tech.
Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00
Backup saved: 000000_ 537986854_20200616_1212.extcsd
Partition info not found
Done.
Skip loading eMMC Addon Firmware
CLK Rate:14000 kHz
Using firmware file : C:\Program Files\Z3X\EASYJTAG\eMMC Firmware\KLMAG2GE4A-A002.bin
Firmware EP Offset:00040000
Update Firmware ID Hash:602D2FD4C378C7574BFB775878D3C3A4
Success!
Success!
Success!
Success!
Done.
CLK Rate:14000 kHz
Success!
Success!
Success!
Success!
Done.
Loading eMMC GEN1 Firmware... IO: 2800 mV
CMD Pullup Level:2371 mV
CMD Active Level:1815 mV
Box IO Level:2800 mV
CLK Rate:21000 kHz
Bus Width:1bit,SDR
eMMC CID : 1501003030303030301F20130129D18E
eMMC CSD : D02701320F5903FFF6DBFFFF8A404006
eMMC Date: 13/2014 Rev.0x1F
eMMC NAME: 000000 , S/N: 538116393
EMMC ROM1 (Main User Data) Capacity: 15028 MB
EMMC ROM2 (Boot Partition 1) Capacity: 2048 kB
EMMC ROM3 (Boot Partition 2) Capacity: 2048 kB
EMMC RPMB is not yet programmed (clear) or RPMB General failure
High-capacity WP group size [HC_WP_GRP_SIZE: 0x00014000]
Backup saved: 000000_ 538116393_20200616_1214.extcsd
Done.
CLK Rate:14000 kHz
Success!
Success!
Success!
Success!
Success!
eMMC firmware is updated now!
Please reconnect all eMMC lines before next operation!
Please don't forget to repair extCSD from backup!
Please don't forget to configure BOOT sizes!
Done.
CMD Pullup Level:1237 mV
CMD Active Level:1804 mV
CLK Rate:21000 kHz
Bus Width:1bit,SDR
eMMC CID : 1501004D4147324741071C6D75D11196
eMMC Date: 01/2014 Rev.0x7
eMMC NAME: MAG2GA , S/N: 476935633
eMMC NAME (HEX): 4D4147324741
Possible eMMC NAME Mismatch
Possible IC Name[0]: Samsung , KLMAG2GE2A-A001/16GB @FBGA169
Possible IC Name[1]: Samsung , KLMAG2GE4A-A001/16GB @FBGA169
Possible IC Name[2]: Samsung , KLMAG2GE4A-A002/16GB @FBGA169
Backup saved: MAG2GA_ 476935633_20200616_1214.extcsd
Done.
Running:SAMSUNG: MoviNAND Reset + Format...
CLK Rate:14000 kHz
EMMC ROM2/3 (Boot Partitions) Capacity: 2048 kB
Sending Internal Reconfiguration Request...
Waiting configuration Apply!
Restoring configuration...
Wiping Card... Please do not touch it!
Done.
CMD Active Level:1784 mV
CLK Rate:21000 kHz
Bus Width:1bit,SDR
Backup saved: MAG2GA_ 476935633_20200616_1215.extcsd
Done.
CLK Rate:21000 kHz
Bus Width:1bit,SDR
Done.
CMD Pullup Level:1206 mV
CMD Active Level:1773 mV
CLK Rate:21000 kHz
Bus Width:1bit,SDR
Done.
0x00
------------Done parsing------------
Writing as extCSD 4.41
Done.
Input file : C:\Program Files\Z3X\EMMC_ROM2_MAG2GA_750257358_00000000_00200000.bin
Writing 0000200000 bytes to 0000000000 ...ROM2 (BOOT1 ROM)
Done, time taken: 2 sec. Average Write Speed: 733 kB/s
Input file : C:\Program Files\Z3X\EMMC_ROM3_MAG2GA_750257358_00000000_00200000.bin
Writing 0000200000 bytes to 0000000000 ...ROM3 (BOOT2 ROM)
Done, time taken: 2 sec. Average Write Speed: 729 kB/s
Input file : C:\Program Files\Z3X\pMC_ROM1_MAG2GA_750257358_00000000_10000000.bin
Writing 0010000000 bytes to 0000000000... ROM1 (USER ROM)
Done, time taken: 134 sec. Average Write Speed: 1995 kB/s
Done, time taken: 134 sec. Average Write Speed: 1991 kB/s[/COLOR]
its done after ad 2 resistor from v1.8 to data and cmd
[IMG]
[/IMG]
I ALWAYS COMPLAIN TO BOX FOR NOT DETECTED OPPO
BUTT TODAY ITS ALSO DONE AFTER ADD RESISTORS
Android Info:
Platform = mt6765
Android Info:
Vendor = OPPO
CPU ABI = arm64-v8a
Android Version = 9
Security Patch = 2020-03-05
Android Info:
Brand = OPPO
Device = OP486C
Model = CPH1923
Product = CPH1923
Firm Version = CPH1923EX_11_A.28
Inc. Version = 1584612014
Firm Date = Thu Mar 19 18:00:14 CST 2020
OPPO Name = OPPO A1k
Scanner Thread Terminated
Elapsed: 00:00:12:936
Found 47 Partition(s)..
Scan Done. Init Main Engine...
Resetting EasyJtag Box. Wait..
CMD Pullup Level: 1763 mV
CMD Active Level: 2609 mV
Reader Engine Initialized.. 0/OK
Source: EasyJtag Port [EMMC/SD/MMC]
Generation: GPT [QC/SAMS/BCM/INTEL/MTK]
Operation Done: [Init Engine], Elapsed: 00:00:01:883
Universal Wipe User Data v1.0
Wiping MISC Partition..
Partition MISC Not Found. Skip..
Wiping PARA Partition..
Partition #7 is '/PARA'. Erasing..
Wipe Mode: Oppo/Vivo Factory Reset
Wipe 'PARA' Partition Done..
Done Wiping Data..
Elapsed Time: [00:00:00:903]
Operation Done: [Universal Wipe Data], Elapsed: 00
