03-21-2017, 05:45 | #1 (permalink) |
Freak Poster Join Date: Nov 2006 Location: sa bahay namin Age: 42
Member: 392861 Status: Offline Thanks Meter: 46 | Can't init device, Reason: CMD Timeout Error it's 4 days since i buy my easy jtag metal box i need explanation from experts and hopefully from product supporter why i can't detect even a single unit with or without pullup resistor i always receve this error Can't init device, Reason: CMD Timeout Error here's the logs Loading eMMC Addon Firmware... IO: 1850 mV Box S/N: 120110093ECEB894, ,FW Ver.: 01.58 CMD Pullup Level:1753 mV CMD Active Level:1845 mV Box IO Level:1850 mV CLK Rate:14000 khz HiPower mode is off! Can't init device, Reason: CMD Timeout Error Done. Z3X EasyJtag Software ver. 2.5.0.8 Loading eMMC Addon Firmware... IO: 1850 mV Box S/N: 120110093ECEB894, ,FW Ver.: 01.58 CMD Pullup Level:1753 mV CMD Active Level:1835 mV Box IO Level:1850 mV CLK Rate:14000 khz HiPower mode is off! Can't init device, Reason: CMD Timeout Error Done. Z3X EasyJtag Software ver. 2.5.0.8 Loading eMMC Addon Firmware... IO: 1850 mV Box S/N: 120110093ECEB894, ,FW Ver.: 01.58 CMD Pullup Level:1742 mV CMD Active Level:1835 mV Box IO Level:1850 mV CLK Rate:14000 khz HiPower mode is off! Can't init device, Reason: CMD Timeout Error Done. i'm very sure that may connection in board is correct and soldered correctly because i tried in atf using same adapter picture is posted below and unit is detected and always error in easy jtag only sorry for mentioning the other box here i just need explanation |
03-21-2017, 08:43 | #4 (permalink) |
No Life Poster Join Date: Jan 2006 Location: E a r T h
Member: 216094 Status: Offline Thanks Meter: 321 | this is adpater problem i have same adpater and same problem some time data error use green one. use this adpater 100% ok https://multi-com.eu/,details,id_pr,...smenu,gsm.html |
The Following User Says Thank You to naushad09 For This Useful Post: |
03-21-2017, 10:48 | #6 (permalink) |
Member: 392861 Status: Offline Thanks Meter: 46 | thankyou for the reply i tried again with shorter wire and swap the vcc vccq because vcc have 1.8v only and vccq have 3.3v so i swap the supply and shortened the wires and bingo!! it detect!! it was adapter fault. here's the log Z3X EasyJtag Software ver. 2.5.0.8 Loading eMMC Addon Firmware... IO: 1850 mV Box S/N: 120110093ECEB894, ,FW Ver.: 01.58 CMD Pullup Level:1763 mV CMD Active Level:1825 mV Box IO Level:1850 mV CLK Rate:14000 khz HiPower mode is off! ---------- eMMC Device Information ---------- EMMC CID : 90014A483447326211012D09B925326C EMMC CSD : D02701320F5903FFFFFFFFEF8A4040D2 EMMC Manufacturer ID: 0090 , OEM ID: 014A EMMC Date: 03/2015 Rev.0x1 EMMC NAME: H4G2b , S/N: 755611941 EMMC NAME (HEX): 48344732622000 EMMC ROM1 (Main User Data) Capacity: 3728 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.6 (MMC 4.5) Boot configuration [PARTITION_CONFIG: 0x00] No boot partition configured. Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x00. H/W reset function [RST_N_FUNCTION]: 0x00 High-capacity W protect group size [HC_WP_GRP_SIZE: 0x00000000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x01 --------------------------------------------- Backup saved: H4G2b _ 755611941_20170321_1723.extcsd Done. my new question why in atf can detect using same adapter and cmd time out error in easy jtag? |
The Following User Says Thank You to ching_gsmX For This Useful Post: |
03-29-2017, 08:03 | #7 (permalink) |
Freak Poster Join Date: Dec 2013 Location: Olympus
Member: 2090936 Status: Offline Thanks Meter: 27 | up this thread i have same error "HiPower mode is OFF CMD Pullup Level: 453 mV CMD Active Level: 1402 mV Can't init device. Reason: CMD Timeout Error" i put pullup resistor but same same to ching_gsmX i cut the jtag wire to shorten but i'm not lucky as ching_gsmX i got the same error, i got that error in lg g4 h818n but in samsung j100h it woks fine!! any one cane gave exact solution to our problem thanks |
03-29-2017, 15:48 | #8 (permalink) |
Junior Member Join Date: Feb 2017
Member: 2685630 Status: Offline Thanks Meter: 6 | hi.. mr. kratos I think it's may either wrong pinout or dead emmc try following may help 1. plug device battery and hit power button... check VCC and VCCQ shown in pinout image... if it's righ pinout must be VCC around 2.8 - 3.1V and vccq around 1.8v . this is for make sure vcc and vccq are not reversed. if it's not helped. go on to following. 2. Keep plug in battery and USB , unsolder VCC and VCCQ wire from board.. check Hi-power clock drive mode option. try to init emmc... not helped too? next.. 3. Using two 100R resistor and connect to 1.8 Volt and CMD and D0 each.. init emmc and try to switch eMMC voltage in software... if not working try to connect resistor to 2.8v instead of 1.8 |
The Following 4 Users Say Thank You to jimmygyl For This Useful Post: |
06-26-2020, 13:50 | #9 (permalink) |
Freak Poster Join Date: Jul 2014
Member: 2220699 Status: Offline Thanks Meter: 143 | Hi everyone. I got easy jtag currently... And I got Can't init devices, reason CMD time out error. Plz help. I'm trying to repair boot of I8200... But I didn't get connection between cell and pc |
02-08-2022, 17:25 | #11 (permalink) | |
No Life Poster Join Date: Aug 2007 Location: jinja,uganda
Member: 562975 Status: Offline Sonork: better tomorow Thanks Meter: 249 | Quote:
ever since I bought this box I had never used it for any work since 2019 eMMC_tool ver. 2.0.0.0 (release date: 30.12.2020) Microsoft Windows 10 (64 bit) build 19042 (10.0.19041.1151) Looking for EasyJTAG box... EasyJTAG API ver. 3403 EasyJTAG Box Serial = 0F00D01145720891 Card Serial = AA03CEFD EasyJTAG Box Firmware = 1.6300 Changelog: 30-12-2020 (ver 1.6.4.0) Add: New keys for Oppo unpack Fix: Fix LG Parser Fix: Bugs that have been found through your crash report Add: new version 2.0.0.0 (qualcomm, samsung) Operation: Connect to Z3X EasyJtag Setting Interface to EasyJtag1/ISP Setting IO Levels to 1.8V Setting Frequence to 21 Mhz Setting BusWidth to 1 Bit CMD Pullup Level: 1691 mV CMD Active Level: 1773 mV Setting HS Timing to Enabled Can't init device. Error: -1. Reason: CMD Timeout Error | |
02-08-2022, 18:26 | #12 (permalink) | |
No Life Poster Join Date: Mar 2007 Location: Factory Reset Protection (FRP) Age: 13
Member: 459784 Status: Offline Sonork: +91-9179403087 Thanks Meter: 1,543 | Quote:
Try voltage change 1.8-2.8-3.0 And have to connected vccq? | |
