09-09-2017, 10:58 | #1 (permalink) |
No Life Poster Join Date: Oct 2007 Location: chennai Age: 38
Member: 616909 Status: Offline Sonork: 1672125 Thanks Meter: 648 | motorola g4 frp latest build done OS ver.: Windows 7 (build 7601, Service Pack 1). Admin rights FAIL undefined Android Explorer ver.: 1.0.0.23 eMMC ODIN ver.: 1.0.11.2 Successfully connected to box on COM3 Box S/N: 010070222EE63D88, ,FW Ver.: 01.60 Box Working Mode: JTAG Box. Box Drivers version: 3.0.1.0, are OK Z3X Card Serial : AA1A-28FD , ver: 22 Z3X Card Activation [LG] : NOT ACTIVATED Z3X Card Activation [SAMS] : NOT ACTIVATED Z3X Card Activation [JTAG] : ACTIVATED Compression is ON Z3X EasyJtag Software ver. 2.6.0.1 Loading eMMC GEN1 Firmware... IO: 2800 mV Compression is ON Box S/N: 010070222EE63D88, ,FW Ver.: 01.60 CMD Pullup Level:2031 mV CMD Active Level:2361 mV Box IO Level:2800 mV CLK Rate:21000 khz HiPower mode is ON! ---------- eMMC Device Information ---------- EMMC CID : 150100525831424D420752D6CEDA73EC EMMC CSD : D02701320F5903FFF6DBFFEF8E40400C EMMC Manufacturer ID: 0015 , OEM ID: 0100 EMMC Date: 07/2016 Rev.0x7 EMMC NAME: RX1BMB , S/N: 1389809370 EMMC NAME (HEX): 525831424D4200 EMMC ROM1 (Main User Data) Capacity: 29820 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG: 0x38] Boot from:ROM1 (Main User Area) Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x38. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity W protect group size [HC_WP_GRP_SIZE: 0x00000000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: RX1BMB_1389809370_20170909_1512.extcsd Partition table scan: GPT: present Found valid GPT with protective MBR; using GPT. Real (Hardware) Disk/Image size: 3A3E000 sectors 29.1 GiB Soft (Partitioned) Disk/Image size: 3A3DFBC sectors 29.1 GiB Logical sector size: 0x200 bytes Disk identifier (GUID): 98101B32-BBE2-4BF2-A06E-2BB33D000C20 First usable sector: 34 Last usable sector: 61071326 Found Data areas (firmware parts) count is: 48 Partition info successfully found --------------------------------------------- P0 (MODEM) [0x20000 0x6400000] Size: 100.0MB P1 (FSC) [0x6420000 0x400] Size: 1.0KB P2 (SSD) [0x6420400 0x2000] Size: 8.0KB P3 (SBL1) [0x6422400 0x80000] Size: 512.0KB P4 (SBL1BAK) [0x64a2400 0x80000] Size: 512.0KB P5 (RPM) [0x6522400 0x36000] Size: 216.0KB P6 (RPMBAK) [0x65a2400 0x36000] Size: 216.0KB P7 (TZ) [0x6622400 0xe3000] Size: 908.0KB P8 (TZBAK) [0x67a2400 0xe3000] Size: 908.0KB P9 (HYP) [0x6922400 0x18000] Size: 96.0KB P10 (HYPBAK) [0x69a2400 0x18000] Size: 96.0KB P11 (DSP) [0x6a22400 0x1000000] Size: 16.0MB P12 (MODEMST1) [0x7a22400 0x200000] Size: 2.0MB P13 (MODEMST2) [0x7c22400 0x200000] Size: 2.0MB P14 (DDR) [0x7e40000 0x8000] Size: 32.0KB P15 (FSG) [0x7e48000 0x800000] Size: 8.0MB P16 (SEC) [0x8648000 0x4000] Size: 16.0KB P17 (ABOOT) [0x8660000 0x177000] Size: 1.464MB P18 (ABOOTBAK) [0x87e0000 0x177000] Size: 1.464MB P19 (LOGS) [0x8960000 0x200000] Size: 2.0MB P20 (UTAGS) [0x8b60000 0x80000] Size: 512.0KB P21 (UTAGSBACKUP) [0x8be0000 0x80000] Size: 512.0KB P22 (CID) [0x8c60000 0x20000] Size: 128.0KB P23 (LOGO) [0x8c80000 0x1000000] Size: 16.0MB P24 (CLOGO) [0x9c80000 0x1000000] Size: 16.0MB P25 (METADATA) [0xac80000 0x80000] Size: 512.0KB P26 (KPAN) [0xad00000 0x800000] Size: 8.0MB P27 (BOOT) [0xb500000 0x1000000] Size: 16.0MB P28 (RECOVERY) [0xc500000 0x1019000] Size: 16.97MB P29 (PERSIST) [0xd520000 0x2000000] Size: 32.0MB P30 (MISC) [0xf520000 0x100000] Size: 1.0MB P31 (CONFIG) [0xf620000 0x8000] Size: 32.0KB P32 (LIMITS) [0xf640000 0x8000] Size: 32.0KB P33 (MOTA) [0xf660000 0x100000] Size: 1.0MB P34 (DEVCFG) [0xf760000 0x40000] Size: 256.0KB P35 (DIP) [0xf7a0000 0x100000] Size: 1.0MB P36 (SYSCFG) [0xf8a0000 0x80000] Size: 512.0KB P37 (CMNLIB) [0xf920000 0x31000] Size: 196.0KB P38 (KEYMASTER) [0xf960000 0x37000] Size: 220.0KB P39 (FRP) [0xf9a0000 0x80000] Size: 512.0KB P40 (PADC) [0xfa20000 0x15e0000] Size: 21.875MB P41 (SP) [0x11000000 0x800000] Size: 8.0MB P42 (HW) [0x11800000 0x800000] Size: 8.0MB P43 (CUSTOMIZE) [0x12000000 0x2000000] Size: 32.0MB P44 (OEM) [0x14000000 0x29000000] Size: 656.0MB P45 (CACHE) [0x3d000000 0x10000000] Size: 256.0MB P46 (SYSTEM) [0x4d000000 0xa0000000] Size: 2.500GB P47 (USERDATA) [0xed000000 0x658be0000] Size: 25.385GB ------ Android information ------ Detected LINUX(Android) SYSTEM : 0x004D000000 (2.500GB) Build ID: NPJS25.93-14-8 Release ID: 7.0 Device Model: Moto G (4) Device Name: athene_retail Architecture ABI: armeabi-v7a Device manufacturer: motorola Device Platform: msm8952 Product ID: athene --------------------------------------------- Done. Z3X EasyJtag Software ver. 2.6.0.1 Loading eMMC GEN1 Firmware... IO: 2800 mV Box S/N: 010070222EE63D88, ,FW Ver.: 01.60 CMD Pullup Level:2031 mV CMD Active Level:2567 mV Box IO Level:2800 mV CLK Rate:21000 khz HiPower mode is ON! ---------- eMMC Device Information ---------- EMMC CID : 150100525831424D420752D6CEDA73EC EMMC CSD : D02701320F5903FFF6DBFFEF8E40400C EMMC Manufacturer ID: 0015 , OEM ID: 0100 EMMC Date: 07/2016 Rev.0x7 EMMC NAME: RX1BMB , S/N: 1389809370 EMMC NAME (HEX): 525831424D4200 EMMC ROM1 (Main User Data) Capacity: 29820 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG: 0x38] Boot from:ROM1 (Main User Area) Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x38. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity W protect group size [HC_WP_GRP_SIZE: 0x00000000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: RX1BMB_1389809370_20170909_1512.extcsd Partition table scan: GPT: present Found valid GPT with protective MBR; using GPT. Real (Hardware) Disk/Image size: 3A3E000 sectors 29.1 GiB Soft (Partitioned) Disk/Image size: 3A3DFBC sectors 29.1 GiB Logical sector size: 0x200 bytes Disk identifier (GUID): 98101B32-BBE2-4BF2-A06E-2BB33D000C20 First usable sector: 34 Last usable sector: 61071326 Found Data areas (firmware parts) count is: 48 Partition info successfully found --------------------------------------------- P0 (MODEM) [0x20000 0x6400000] Size: 100.0MB P1 (FSC) [0x6420000 0x400] Size: 1.0KB P2 (SSD) [0x6420400 0x2000] Size: 8.0KB P3 (SBL1) [0x6422400 0x80000] Size: 512.0KB P4 (SBL1BAK) [0x64a2400 0x80000] Size: 512.0KB P5 (RPM) [0x6522400 0x36000] Size: 216.0KB P6 (RPMBAK) [0x65a2400 0x36000] Size: 216.0KB P7 (TZ) [0x6622400 0xe3000] Size: 908.0KB P8 (TZBAK) [0x67a2400 0xe3000] Size: 908.0KB P9 (HYP) [0x6922400 0x18000] Size: 96.0KB P10 (HYPBAK) [0x69a2400 0x18000] Size: 96.0KB P11 (DSP) [0x6a22400 0x1000000] Size: 16.0MB P12 (MODEMST1) [0x7a22400 0x200000] Size: 2.0MB P13 (MODEMST2) [0x7c22400 0x200000] Size: 2.0MB P14 (DDR) [0x7e40000 0x8000] Size: 32.0KB P15 (FSG) [0x7e48000 0x800000] Size: 8.0MB P16 (SEC) [0x8648000 0x4000] Size: 16.0KB P17 (ABOOT) [0x8660000 0x177000] Size: 1.464MB P18 (ABOOTBAK) [0x87e0000 0x177000] Size: 1.464MB P19 (LOGS) [0x8960000 0x200000] Size: 2.0MB P20 (UTAGS) [0x8b60000 0x80000] Size: 512.0KB P21 (UTAGSBACKUP) [0x8be0000 0x80000] Size: 512.0KB P22 (CID) [0x8c60000 0x20000] Size: 128.0KB P23 (LOGO) [0x8c80000 0x1000000] Size: 16.0MB P24 (CLOGO) [0x9c80000 0x1000000] Size: 16.0MB P25 (METADATA) [0xac80000 0x80000] Size: 512.0KB P26 (KPAN) [0xad00000 0x800000] Size: 8.0MB P27 (BOOT) [0xb500000 0x1000000] Size: 16.0MB P28 (RECOVERY) [0xc500000 0x1019000] Size: 16.97MB P29 (PERSIST) [0xd520000 0x2000000] Size: 32.0MB P30 (MISC) [0xf520000 0x100000] Size: 1.0MB P31 (CONFIG) [0xf620000 0x8000] Size: 32.0KB P32 (LIMITS) [0xf640000 0x8000] Size: 32.0KB P33 (MOTA) [0xf660000 0x100000] Size: 1.0MB P34 (DEVCFG) [0xf760000 0x40000] Size: 256.0KB P35 (DIP) [0xf7a0000 0x100000] Size: 1.0MB P36 (SYSCFG) [0xf8a0000 0x80000] Size: 512.0KB P37 (CMNLIB) [0xf920000 0x31000] Size: 196.0KB P38 (KEYMASTER) [0xf960000 0x37000] Size: 220.0KB P39 (FRP) [0xf9a0000 0x80000] Size: 512.0KB P40 (PADC) [0xfa20000 0x15e0000] Size: 21.875MB P41 (SP) [0x11000000 0x800000] Size: 8.0MB P42 (HW) [0x11800000 0x800000] Size: 8.0MB P43 (CUSTOMIZE) [0x12000000 0x2000000] Size: 32.0MB P44 (OEM) [0x14000000 0x29000000] Size: 656.0MB P45 (CACHE) [0x3d000000 0x10000000] Size: 256.0MB P46 (SYSTEM) [0x4d000000 0xa0000000] Size: 2.500GB P47 (USERDATA) [0xed000000 0x658be0000] Size: 25.385GB ------ Android information ------ Detected LINUX(Android) SYSTEM : 0x004D000000 (2.500GB) Build ID: NPJS25.93-14-8 Release ID: 7.0 Device Model: Moto G (4) Device Name: athene_retail Architecture ABI: armeabi-v7a Device manufacturer: motorola Device Platform: msm8952 Product ID: athene --------------------------------------------- Done. Running:Format FRP Partition... Z3X EasyJtag Software ver. 2.6.0.1 Loading eMMC Addon Firmware... IO: 2800 mV Box S/N: 010070222EE63D88, ,FW Ver.: 01.60 CMD Pullup Level:2031 mV CMD Active Level:2588 mV Box IO Level:2800 mV CLK Rate:21000 khz HiPower mode is ON! ---------- eMMC Device Information ---------- EMMC CID : 150100525831424D420752D6CEDA73EC EMMC CSD : D02701320F5903FFF6DBFFEF8E40400C EMMC Manufacturer ID: 0015 , OEM ID: 0100 EMMC Date: 07/2016 Rev.0x7 EMMC NAME: RX1BMB , S/N: 1389809370 EMMC NAME (HEX): 525831424D4200 EMMC ROM1 (Main User Data) Capacity: 29820 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB High-capacity W protect group size [HC_WP_GRP_SIZE: 0x00000000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Searching for partition tables... Detected GPT over MBR... Medium UUID: 98101B32-BBE2-4BF2-A06E-2BB33D000C20 GPT Entries Count = 48 Searching for FRP Data... Marker of f9a0000 is: 19901873 FRP/Persistent Storage Format Success! Searching for KillSwitch Specific FRP Data... LG Custom Data is not found! Done. |
The Following User Says Thank You to umarmsn For This Useful Post: |
09-12-2017, 19:02 | #4 (permalink) |
No Life Poster Join Date: Jun 2010 Location: Xique-Xique-Bahia, Brasil Age: 46
Member: 1320000 Status: Offline Sonork: 100.1667898 Thanks Meter: 272 | Use search Burton. Here is http://forum.gsmhosting.com/vbb/f672...t1626-2255002/ |
The Following User Says Thank You to toninhosantos For This Useful Post: |
