07-23-2019, 23:50 | #1 (permalink) |
No Life Poster Join Date: Aug 2010 Location: Inside Logic Age: 37
Member: 1377783 Status: Offline Sonork: 100.1611724 Thanks Meter: 3,336 | LG P768 Reborn by Easy Jtag Box V1 Loading eMMC GEN1 Firmware... IO: 3300 mV Box S/N: , ,FW Ver.: 01.63 CMD Pullup Level:1949 mV CMD Active Level:2485 mV Box IO Level:3300 mV CLK Rate:21000 kHz Bus Width:1bit,SDR HiPower mode is ON! ---------- eMMC Device Information ---------- eMMC CID : 90014A483447316404860400189CA0C2 eMMC CSD : D02701320F5903FFFFFFFFE78A4040E2 eMMC Manufacturer ID: 0090 , OEM ID: 014A eMMC Date: 10/2013 Rev.0x86 eMMC NAME: H4G1d , S/N: 67115164 eMMC NAME (HEX): 483447316420 EMMC ROM1 (Main User Data) Capacity: 3696 MB EMMC ROM2 (Boot Partition 1) Capacity: 2048 kB EMMC ROM3 (Boot Partition 2) Capacity: 2048 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 2048 kB EMMC RPMB is not yet programmed (clear) or RPMB General failure EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.5 (MMC 4.41) Boot configuration [PARTITION_CONFIG: 0x00] No boot partition configured. Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x00. H/W reset function [RST_N_FUNCTION]: 0x00 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00002000] Partitioning Support [PARTITIONING_SUPPORT]: 0x03 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: H4G1d_ 67115164_20190723_1839.extcsd Done. Pinout for some LG Devices requires be Fixed... Need Ground connection and USB connection for 5v as VCC power Best Regards Shensohau |
