11-01-2017, 10:05 | #1 (permalink) |
Insane Poster Join Date: Jul 2014 Location: mahabad
Member: 2215298 Status: Offline Thanks Meter: 7 | ls996 mmc repair problem ls996 mmc repair problem need full dump for ls996 and the info after repair is correct or not? Compression is ON Z3X EasyJtag Software ver. 2.6.0.1 Loading eMMC GEN1 Firmware... IO: 2800 mV Box S/N: 19FFE00D100EFD04, ,FW Ver.: 01.60 CMD Pullup Level:2887 mV CMD Active Level:2815 mV Box IO Level:2800 mV CLK Rate:14000 khz HiPower mode is off! ---------- eMMC Device Information ---------- EMMC CID : 15010042474E44335201204E43021242 EMMC CSD : D02701320F5903FFF6DBFFEF8E40400C EMMC Manufacturer ID: 0015 , OEM ID: 0100 EMMC Date: 01/2015 Rev.0x1 EMMC NAME: BGND3R , S/N: 541999874 EMMC NAME (HEX): 42474E44335200 EMMC ROM1 (Main User Data) Capacity: 29820 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.7 (MMC 5.0) Boot configuration [PARTITION_CONFIG: 0x00] No boot partition configured. Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x00. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity W protect group size [HC_WP_GRP_SIZE: 0x00000000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: BGND3R_ 541999874_20171101_1210.extcsd Partition table scan: GPT: present Found valid GPT with protective MBR; using GPT. Real (Hardware) Disk/Image size: 3A3E000 sectors 29.1 GiB Soft (Partitioned) Disk/Image size: 3A3DFBC sectors 29.1 GiB Logical sector size: 0x200 bytes Disk identifier (GUID): 98101B32-BBE2-4BF2-A06E-2BB33D000C20 First usable sector: 34 Last usable sector: 61071326 Found Data areas (firmware parts) count is: 49 Partition info successfully found --------------------------------------------- P0 (MODEM) [0x1000000 0x5000000] Size: 80.0MB P1 (PMIC) [0x6000000 0x80000] Size: 512.0KB P2 (SBL1) [0x6080000 0x100000] Size: 1.0MB P3 (TZ) [0x6180000 0x100000] Size: 1.0MB P4 (SDI) [0x6280000 0x80000] Size: 512.0KB P5 (HYP) [0x6300000 0x80000] Size: 512.0KB P6 (RPM) [0x6380000 0x80000] Size: 512.0KB P7 (ABOOT) [0x6400000 0x200000] Size: 2.0MB P8 (SBL1BAK) [0x6600000 0x100000] Size: 1.0MB P9 (PMICBAK) [0x6700000 0x80000] Size: 512.0KB P10 (TZBAK) [0x6780000 0x100000] Size: 1.0MB P11 (HYPBAK) [0x6880000 0x80000] Size: 512.0KB P12 (RPMBAK) [0x6900000 0x80000] Size: 512.0KB P13 (ABOOTBAK) [0x6980000 0x200000] Size: 2.0MB P14 (SDIBAK) [0x6b80000 0x80000] Size: 512.0KB P15 (LIMITS) [0x6c00000 0x80000] Size: 512.0KB P16 (DEVINFO) [0x6c80000 0x80000] Size: 512.0KB P17 (APDP) [0x6d00000 0x80000] Size: 512.0KB P18 (MSADP) [0x6d80000 0x80000] Size: 512.0KB P19 (DPO) [0x6e00000 0x80000] Size: 512.0KB P20 (MISC) [0x7000000 0x1000000] Size: 16.0MB P21 (PERSIST) [0x8000000 0x2000000] Size: 32.0MB P22 (MODEMST1) [0xa000000 0x180000] Size: 1.500MB P23 (MODEMST2) [0xa180000 0x180000] Size: 1.500MB P24 (FSG) [0xa300000 0x180000] Size: 1.500MB P25 (FSC) [0xa480000 0x80000] Size: 512.0KB P26 (SSD) [0xa500000 0x80000] Size: 512.0KB P27 (KEYSTORE) [0xa580000 0x80000] Size: 512.0KB P28 (DDR) [0xa600000 0x200000] Size: 2.0MB P29 (SEC) [0xa800000 0x80000] Size: 512.0KB P30 (ENCRYPT) [0xa880000 0x80000] Size: 512.0KB P31 (EKSST) [0xa900000 0x80000] Size: 512.0KB P32 (RCT) [0xa980000 0x80000] Size: 512.0KB P33 (PERSISTENT) [0xaa00000 0x200000] Size: 2.0MB P34 (LAF) [0xb000000 0x3000000] Size: 48.0MB P35 (BOOT) [0xe000000 0x2800000] Size: 40.0MB P36 (RECOVERY) [0x10800000 0x2800000] Size: 40.0MB P37 (DRM) [0x13000000 0x800000] Size: 8.0MB P38 (SNS) [0x13800000 0x800000] Size: 8.0MB P39 (MPT) [0x14000000 0x2000000] Size: 32.0MB P40 (CARRIER) [0x16000000 0x2800000] Size: 40.0MB P41 (FACTORY) [0x18800000 0x2e00000] Size: 46.0MB P42 (FOTA) [0x1b600000 0xa00000] Size: 10.0MB P43 (RAW_RESOURCES) [0x1c000000 0x400000] Size: 4.0MB P44 (RAW_RESOURCESBAK) [0x1c400000 0x400000] Size: 4.0MB P45 (SYSTEM) [0x1c800000 0xff000000] Size: 3.984GB P46 (CACHE) [0x11b800000 0x4d000000] Size: 1.203GB P47 (USERDATA) [0x168800000 0x5de800000] Size: 23.476GB P48 (GROW) [0x747000000 0xbfbe00] Size: 11.983MB ------ Android information ------ Detected LINUX(Android) SYSTEM : 0x001C800000 (3.984GB) Unable to read prop.plist , code 2 --------------------------------------------- Done. |
